I have a question about steel tube. - JeepForum.com
post #1 of 6 Old 01-22-2011, 01:08 PM Thread Starter
chris_ce
I know the difference in DOM and ERW. I know that DOM is stronger.
My question is by how much.
Lets say I want to build a cage. Lets say it's going to be 1.75 tube.
I already have a stick of ERW 1.75 .134 wall. So how much weaker is this going to be when compared to 1.75 .120 wall DOM?
I have seen many threads comparing the two tubes but all listed the same size.
How much thicker does the ERW need to be to get close to the strength of DOM?
chris_ce is offline
post #2 of 6 Old 01-23-2011, 12:08 AM
TaterTott
1991 XJ Cherokee
build it strong by design, not by material...
i have a buddy that has a land cruiser with a cage build of 1.5" skeg 40 pipe.. and that rig TOPS my list of thrashings.... cage hasn't budged a bit..
i use EWS.. way way cheaper than DOM..
Nate Goodwin
"Tater2" - '91 2 door XJ. 4.0, AW4, NP231/Dana 300 Doubler, GM 60/70HD, 40" IROKs on H1s
TaterTott is offline
post #3 of 6 Old 01-23-2011, 08:00 AM
underpowered
Bouncin' on a Budget
underpowered's Avatar
is it Hot rolled or cold rolled EWS tube? that will be a difference as well.
but if you design it correctly, it will be plenty strong. my Cage is all cold rolled EWS tube. 1 5/8 x .134 wall.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #4 of 6 Old 01-23-2011, 08:14 AM
solarpower
This.
the actual strength differences are insignificant if the welds are crap or if the design of the cage is poor, those are the places it will fail first.
Dom is cleaner over-all so you pay up front to not have to remove scale, get material that bends cleaner, and is easier to give a top notch paint job too. When the steel is drawn over the mandrel (DOM) there is a certain amount of internal stress that is released from the steel and this in turn strengthens the steel and makes it ideal to bend and form...especially near the weld seam.
Pipe is generally dirtier, has some lower grades that you want to avoid, may have some ugliness on seams, and might not fit in your bender.. but is very inexpensive and plenty strong enough when built correctly.
Here is a link with some info..http://www.greatlakes4x4.com/showthread.php?t=1919 about what kind of pipe you want to look for.
If you are building a full blown buggy comp chassis that will see many multiple roll-overs then you should be worried about strength differences...but since your probably building a cage that should only be used once then getting a good solid design (triangulate) and good solid welds (penetrate) are what makes the biggest difference.
Splitting hairs over a couple thousand lbs of tensile strength and saving a few bucks is all the builders choice.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #5 of 6 Old 01-23-2011, 12:49 PM
TaterTott
1991 XJ Cherokee
http://www.davesport.com/cgi-bin/davesport/specs.html
Nate Goodwin
post #6 of 6 Old 01-25-2011, 05:26 PM Thread Starter
chris_ce
Thanks for the info. Think I will just use what I have to do the front cage parts.
chris_ce is offline
Question about the price of steel parag8or Fabrication Shop 15 03-28-2010 09:20 AM
Rim Question (steel vs. aluminum) CHIPPER10 Tires & Wheels 3 05-06-2008 02:40 PM
Steel Jeep rim question JMRD Tires & Wheels 2 12-10-2007 03:54 PM
Steel question.... HMTwin Fabrication Shop 14 02-20-2006 12:47 PM
Steel Question ctavel Fabrication Shop 2 03-24-2004 06:29 PM
