how to weld ford 8.8 tubes to housing? - Page 2 - JeepForum.com
post #16 of 49 Old 06-27-2010, 06:21 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
For the most part, the only thing I use my Lincoln Tombstone for is welding tubes to housings.. using Ni55 rods.. at about $50lb
1 rod will usually get me 4 good beads evenly spaced around a typical tube.
I've done housings/tubes with wire feed too.. both flux core and solid w/gas.
With any of the processes/rods/wire that you use, just looking for cracking. If it's gonna crack, it'll do it almost immediately after welding. If it does crack, just grind it out and hit it again. Most of the time, it won't crack the second time around.. not sure why.. maybe mixing of the metals?
I've also used a "bullet heater" to preheat the casting. After welding, I just move the heater away about an inch every few minutes or so (basically whenever I walk by it) until it's cool enough to touch.
BESRK is offline
post #17 of 49 Old 06-29-2010, 01:22 AM
NalinMFG
did my 44 the other day...tick tacked with my miller 211 and it turned out ok.
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #18 of 49 Old 06-29-2010, 05:55 PM
wushaw
Rockin jeep
wushaw's Avatar
Haven't done much welding...have ya? That bead looks great
wushaw is offline
post #19 of 49 Old 06-29-2010, 06:08 PM
vindicated
Did you miss me?
vindicated's Avatar
Holy ****! If welding is this involved forget it. I never thought there was that much to know about it. Maybe I can get a degree at community college or something.
Originally Posted by bradthebard
Vin's so hard core, he drinks the whole jug of STFU and then has a three hour conversation about it.
vindicated is offline
post #20 of 49 Old 06-29-2010, 06:32 PM
jason m
Nothing but the facts
jason m's Avatar
I cant coment on the 8.8 housings but the 14 bolts and dana 60's center sections are not a CAST steel there Nodular Iron. The outer C's are a forged steel, again maybe the 8.8's are different.
I used my MM250 set at 185IPM's and 19.5 volts with .035 wire. And ive also used a high knickle based repiar rod we use to use on final drive and engine blocks when I worked for CAT.
My 14 bolt with the MIG heated up around 200* and slowly air cooled.
Knickle rod, again heated up to around 200* and slowly air cooled.
Years of beating on the 14 bolt and no breakage yet.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #21 of 49 Old 06-30-2010, 09:12 PM
Ironworker709
Ironworker709's Avatar
Here is a few simple ways to test if it is cast steel,nodular/ductile iron( different names,same thing) or cast iron....
Use a grinder and do a spark test...
Cast Iron will produce short red streamers seen best in dim light.
Cast steel produces bright yellow sparks ,sometimes bursts at then end of the sparks depending on the carbon content in it.
Mild Steel produces dull yellow sparks
You can also use a file for a test,filing cast iron will produce some graphite,cast steel wont.
I find the grind test to be the best.
Any of the 8.8's i've welded tubes to center sections and welded brackets on for drag strip machines always indicated cast steel.
Here is a good read on the subject i just found,He does a pretty good job at explaining this subject in the way i have been trying to explain....
Cast Steel - JeepBBS
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #22 of 49 Old 06-30-2010, 10:23 PM Thread Starter
YJ89jeepTX
well we welded up the housing with flux core .035...no crackin during the welds...is penetration indicated by the length of that rainbow type marking the welds make on the surrounding area?
YJ89jeepTX is offline
post #23 of 49 Old 06-30-2010, 11:10 PM
NalinMFG
bout a year...bought a miller 211 last september and have been teaching myself.
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #24 of 49 Old 07-16-2010, 01:12 PM
JA66
My dad is the one that welded brackets onto my 8.8, and he just welded 4 short beads spaced around the tube, no preheat, no postheat. I have had no problems out of them, but then again, I have not really beat on it that much, but time will tell, gettin 488s and lockers soon. Im doing a waggy 44 front now, and I had to weld to the cast. Process I used was to preheat area to 450 or so, weld one side of tab, peen weld (no idea if that helps anything or not), heat up a bit more, weld other side of tab, peen again, keep torch on weld for a bit, then covered it in a welding blanket then a towel. I took little more than an hour to be able to touch the weld i think, though I didnt time it. After I uncovered it, I smacked the tab really hard and bent the 1/4" tab a bit, so I am satisfied with the weld. Used plain wire on a 220 machine.
JA66 is offline
post #25 of 49 Old 07-17-2010, 12:18 PM
bryanm
1978 CJ5
I agree with Ironworker preheat and postheat with the fluxcore you already have ---- from my experience most of these housings are cast steel not cast iron. I have even repaired some that were broken using the method Ironworker describes
bryanm is offline
post #26 of 49 Old 07-17-2010, 04:25 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Keep in mind fellas.. it's not like these tubes are loose and about to fall out.. They are pressed in and plug welded at the factory... and are pretty secure as is.
We're just adding some additional strenght to keep the pumpkin from spinning/moving on the axle tubes under severe use. Just thought I'd toss that out there..
BESRK is offline
post #27 of 49 Old 07-17-2010, 07:26 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Question to all about this particular one, and I'm in no way being critical, just asking: Is this really a good, strong weld, particularly for a housing? It's certainly nice-looking.
But according to your description and how it looks, it appears to be basically a bunch of individual welds. From everything I've read about doing this, I thought it was better to have a continuous weld, not keep starting and stopping like you do with sheet metal. Am I seeing this correctly?
Pacfanweb is offline
post #28 of 49 Old 07-18-2010, 07:18 AM
jason m
jason m's Avatar
Yep
And heres what a 14 bolt will do if its not weld and the only side holding the Anti warp bar on.
That was my old axle and was done with a 4.0. Buy the time we got off the trail the tube was moving in and out and up and down. Now I'm linked and the tube's are welded, 5 hard years no problems
Jason.
jason m is offline
post #29 of 49 Old 07-19-2010, 08:41 PM
NalinMFG
yes, a continuous weld is stronger. As stated above, the tubes are already welded from the factory so this is just added insurance. This was my first attempt ever welding to cast so I used this method to keep the heat down. The 1/2" mild steel tubes can take alot of heat, however I have melted moderately porous cast away with very low settings.
Linkedin:
Email:
Website:
Facebook:
NalinMFG is offline
post #30 of 49 Old 08-16-2010, 11:40 PM
alex211
1995 XJ Cherokee
I just welded the tubes on my buddies 8.8 with my Hobart 187, no cracks except for one crappy bead. I ground it out and hit it again, it is fine now.
95 xj bone stock for now
alex211 is offline
.035 , cast , cool slowly , ford 8.8 , housing , pre-heat , tubes , weld
Which Rod to Weld Axle Tubes? 99TJSahara Fabrication Shop 2 03-01-2010 07:43 AM
Tubes or no tubes? jerryjeeper General Jeep & Off-Road Equipment 4 05-03-2009 09:08 PM
Stick weld or MIG weld? theboxman71 Fabrication Shop 39 10-05-2006 06:46 PM
Bazooka Tubes? Black Hills TJ Audio, CB & Ham Radios, GPS, & Electrical 4 01-30-2006 11:37 AM
will axel housing tubes support jeep? NMullens General Jeep & Off-Road Equipment 2 10-25-2004 08:02 PM
