how to weld CJ body - JeepForum.com
post #1 of 8 Old 02-13-2011, 06:40 PM Thread Starter
my_304_cj7
1976 CJ7
how to weld CJ body
I was trying to fix the body of my CJ where the spare tire carrier ripped through but even with my welder on the lowest setting it is just blowing through the sheet metal. Any suggestions? Thanks
'76 CJ7 Quadra-Trac 304 2.5" superlift 1" body lift 33" DuraTrac's
2014 Grand Cherokee Altitude
my_304_cj7 is offline
post #2 of 8 Old 02-13-2011, 06:47 PM
Unlimitedlou
Use some brass or aluminum on the backside when you are welding. The weld won't stick to the brass and aluminum and you can fill it in by stitch welding. Use little bursts while welding.
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline
post #3 of 8 Old 02-13-2011, 06:50 PM Thread Starter
my_304_cj7
1976 CJ7
I used a welding spoon ( I think thats what its called). The metal just melts away, I have a hole now where it was only a tear in the metal.
post #4 of 8 Old 02-13-2011, 07:04 PM
Unlimitedlou
You are definitely welding to hot then. You will have to find a lower amperage welder.
post #5 of 8 Old 02-13-2011, 07:06 PM Thread Starter
my_304_cj7
1976 CJ7
Thanks for the info, I will try to borrow one.
post #6 of 8 Old 02-13-2011, 07:18 PM
Machinist
if you are putting the tire carrier back on then I would weld a thicker and bigger plate in so it wont tear out again
Machinist is offline
post #7 of 8 Old 02-14-2011, 06:57 AM
Ironworker709
Ironworker709's Avatar
What welder are you using?220v?110v?..what brand?..Fluxcore or MIG?..Fluxcore is a real PITA to weld any thin sheetmetal even for a well seasoned weldor.
If using Fluxcore and it is your only option,set to the lowest heat possible and pratice on running the wire speed a lil faster than usual until you can JUST spot tack without burning through,clean the slag off after every tack before tacking that area again...do the tacks in complete opposite sides back n forth allowing the tacked areas to cool before continuing in that area until it is completely filled/welded.
If it already ripped in that area and just trying to patch the same area up,you will need to build some kind of structural support there to prevent it from happening again.
If the sheetmetal is has alot of rust behind what you are trying to weld,this will cause "blow throughs" too,rust will easily cause an "arc blow" because the arc is trying to get through the rust,plus the rust will blow out,causing too much heat in the sheetmetal before you actualy get a tack.And rust will cause a very poor weldment in anything.
Pics would be nice to see what you are dealing with too.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #8 of 8 Old 02-14-2011, 01:10 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
From my experience, you shouldn't try to run a bead, either. Tack it, lots of tack welds with sheet metal.
Pacfanweb is offline
Should i weld it? Eman Fabrication Shop 7 09-23-2009 03:22 AM
Will this weld body panels? YJames90 Fabrication Shop 5 05-22-2008 01:56 PM
Stick weld or MIG weld? theboxman71 Fabrication Shop 39 10-05-2006 06:46 PM
cj7 body repair-rivet/tack weld spot fix CJ7 Vette General Jeep & Off-Road Equipment 4 05-26-2006 07:56 AM
I need someone who can weld FredBull General Jeep & Off-Road Equipment 0 01-29-2005 11:23 AM
