How to: Vacuum Disco Elimination, Axle Tube Sleeve Fix, ubolt Eliminator - 56K beware - JeepForum.com
post #1 of 19 Old 06-10-2009, 06:07 PM Thread Starter
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Last year while wheelin’ in Colorado with some friends, I developed a serious crack underneath my passenger side SOA perch. The problem didn’t surface till the next day while I was in Moab doing a relatively easy trail. All the sudden my front axle started making some interesting noises, and looked as if I had balljoint issues at first glance. So Randy (Rock_Worm) and I got out to take a look. Next thing I know, Randy say’s something to the effect – hey Joe, I think I’ve found the problem”.
Anyway, we did a trail repair & then towed it back to our campsite in Moab. The following day, Randy, Larry & I welded it back up as a temporary fix so that we could continue wheelin’ for the next week. It has held up fine ever since & has several other trail runs on it – but I wanted a more permanent fix. So, this is where my “Disco Elimination & Axle Tube Sleeve Fix and ubolt eliminator” begins.
Here’s what the initial crack looked like:
Face of the axle tube:
View from underneath:
View from the back:
So, back at my campsite, I borrowed a friend of mine’s Lincoln MIG welder and we cleaned up the crack and welded it back as best we could.
My friend Larry, from WA, helping do some welding:
Beginnings of the repair:
Okay, now that I’ve explained how my troubles started – here’s what I’ve done as a more permanent fix. Yea, it’s a HPD30 and some may say; “why polish it?” This fix cost me a grand total of ~$30.00 for the 3”x.250” DOM, including hardware. I already had everything else laying around my garage.
I had a pair of perches, so I got some 3”x.250” DOM and started doing some measuring.
I secured the Jeep on jack stands & pulled my tire, then started to remove the Warn hubs:
Then I removed the Warn spindle & Vanco calipers and rotor:
Joe Dillard is offline
post #2 of 19 Old 06-10-2009, 06:14 PM Thread Starter
Joe Dillard
Next was to remove the Warn passenger side axle shaft:
Remove the steering links from my MORE steering bracket:
Remove & tape up the axle breather & ARB fitting:
Then the drive shaft and secure it out of the way:
Next up was to remove the ubolts & spring plates:
HPD30 removed. You’ll notice I didn’t bother removing the brake rotor, hub spindle etc from the driver side since there was no need.
Now it’s time to start chopping up the disco housing & completely remove it so I could sleeve the tube with the DOM.
I opened up the vacuum disco block-off plate and stuffed a rag in it so that debris wouldn’t enter the tube as I cut portions of the tube off:
As you’ll notice here – I cut off the tube close to the axle perch so I could take advantage of as much of the axle tube as possible when I sleeve it.
Here’s the outer portion of it that I’ll reuse. Notice how I marked the tube so that when I reattach it – my caster should be correct:
Next up, I opened up the disco housing block-off plate & move my rag to the inside of where I’d be making my second cut.
Vacuum disco gone:
post #3 of 19 Old 06-10-2009, 06:16 PM Thread Starter
Joe Dillard
No, I’m not a dentist there are some deburring tools I use to help remove those nasty/pesky burrs after cutting:
Then I removed the old RE axle tube shock mount:
Cleaned up the axle tubes with a flap disc:
Test fit of the new sleeve, perch & rechecking castor with my angle finder:
I drilled some holes in the new sleeve so I could plug-weld it in place:
Test fit & checking castor:
Marking the new spring perch for welding:
Fabricating new spring plate and ubolt eliminator plate:
post #4 of 19 Old 06-10-2009, 06:17 PM Thread Starter
Joe Dillard
Since I did a 1” wheelbase stretch some time ago – I needed to drill an offset hole in my spring perch so the centerpin has an exit:
Measure twice – drill once
Ubolt eliminator test fit:
Plug welds complete & beginnings of the sleeve welded:
Spring perch & ubolt eliminator tact welded & angle rechecked:
Starting to paint/reassembly & getting ready for final welding:
Perch & new lower shock tabs welded:
post #5 of 19 Old 06-10-2009, 06:18 PM Thread Starter
Joe Dillard
Nothing ever goes perfectly – right?
I checked the tube and noticed that the rag I put in it earlier was accidentally left inside. No big deal, I took a broomstick handle & retrieved it:
That’s better. Notice the ARB crosspin:
On to the reassembly. Brakes, steering, spindle, shocks, check:
Drive shaft, breather ARB – check:
post #6 of 19 Old 06-10-2009, 06:20 PM Thread Starter
Joe Dillard
Hubs & tires, check:
Well, that’s about it. This is just the first fitting. I’ll be changing this design in the future, but you get the idea as to why & how I did it.
post #7 of 19 Old 06-10-2009, 07:12 PM
jgorm
jgorm's Avatar
nice fab work!
jgorm is offline
post #8 of 19 Old 06-10-2009, 09:11 PM
Death_Valley_TJ
Death_Valley_TJ's Avatar
Nice job!!
Death_Valley_TJ is offline
post #9 of 19 Old 06-10-2009, 09:18 PM
yjcrawler
great job. i need to get the funds up to do this soon.
Soon to be SOA with 14 Bolt SF rear, D44 front and 38's
Early YJ Club, Member # 33
yjcrawler is offline
post #10 of 19 Old 06-11-2009, 09:43 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Nice repair and writeup Joe, we had a guy break his axle tube the same way on my last run. I hope I'm not next.
Jerry Bransford is online now
post #11 of 19 Old 06-11-2009, 10:17 AM
ritjobbie
WOW. Just wow.
1995 YJ Rio Grande, 2.5L Low Output Engine
ritjobbie is offline
post #12 of 19 Old 06-12-2009, 01:46 AM
Greg_Volkman
just curios as to why you attribute the break to the disco cast iron mount when the break occurred on the tube, and not at the mount?
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon
Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci
Greg_Volkman is offline
post #13 of 19 Old 06-12-2009, 08:24 AM Thread Starter
Joe Dillard
Greg,
I'm not sure what I may have said to give you that impression. Could you point me to where I indicated or implied that? Thanks.
By completely removing the vacuum disco housing (which I have not needed ever since I installed the Warn hub kit and 1 piece Warn inner ~5-6 years ago) it sure makes it far easier to sleeve the axle tube with it completely gone.
IIRC, the sleeve ended up being ~21.25" in length, and since I left a few inches of the original tube at the inner C and differential, this made for sleeving it fairly easy.
Thanks everybody for the feedback.
post #14 of 19 Old 06-29-2009, 02:40 PM
skullver
Tarpitz
1991 XJ Cherokee
nice fab work!
Are you using grade 5 hardware for your u-bolt eliminator? I am looking into helping a buddy with his dana 30 and as it is trussed along the bottom, there is no room for u-bolts(making room could prove to be very labor intensive). Upon looking into it I have heard there are some issues with the hardware stretching/loosening. A google search for "ubolt eliminator" brought up this thread so thought I would get your thoughts/experiences. What size hardware are you using?
THANKS!
Blah blah blah blah.
my Jeepspeed build thread:
skullver is offline
post #15 of 19 Old 06-30-2009, 01:06 AM Thread Starter
Joe Dillard
The initial hardware was not up to my standards, it was mearly for fit. It's now grade 8 stuff.
where to buy ubolt plates for 8.8 swap willyb8 Engines & Drivetrain 5 12-27-2008 04:00 PM
Custom vacuum axle disconnect Crash&Burn Fabrication Shop 1 03-22-2008 09:57 AM
D30 passenger axle seal disco type? mighty4banger Engines & Drivetrain 2 03-12-2008 12:09 PM
D30 HP vacuum disco penguinland General Jeep & Off-Road Equipment 3 05-31-2005 04:27 AM
Swaybar and Ubolt plates DaveFL Tires & Wheels 4 09-13-2002 07:27 PM
