How to test my weld - JeepForum.com
post #1 of 12 Old 01-22-2011, 04:52 PM Thread Starter
airframer
airframer's Avatar
How to test my weld
So i just welded on my lca brackets is there a way to test em without doing the hammering method?
Everything in moderation
airframer is offline
post #2 of 12 Old 01-22-2011, 04:55 PM
frankenjeep
1994 ZJ
Other than a ultra sound or destruction type just a visual is all there is.
I may be drunk, Miss, but in the morning I will be sober and you will still be ugly.
Winston Churchill
Jesus saves..... "yea? So do my rock sliders" F.J.
frankenjeep is offline
post #3 of 12 Old 01-22-2011, 04:59 PM
wushaw
Rockin jeep
wushaw's Avatar
X-RAY.
Usually one does a lot of welding, practice and destructive testing before doing something that matters.
wushaw is offline
post #4 of 12 Old 01-22-2011, 05:01 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Got any good pics of the weld?
BESRK is offline
post #5 of 12 Old 01-22-2011, 05:08 PM
frankenjeep
1994 ZJ
Opps ya x ray...lol that's what I meant.... sigh
Winston Churchill
post #6 of 12 Old 01-22-2011, 07:01 PM Thread Starter
airframer
airframer's Avatar
ya i did the destructive testing b4 welding these. after a lot of practice i fabled up sum taillight cages to practice.
post #7 of 12 Old 01-22-2011, 10:47 PM
wushaw
Rockin jeep
wushaw's Avatar
Then if you had the machine set right and layed your bead as you did with the your test pieces then you should be ok.
wushaw is offline
post #8 of 12 Old 01-23-2011, 12:42 AM
Krochus
What process and electrode did you use?
Are the welds even across the top and bottom leg?
Any porosity or undercut?
Are the welds rolled or do they have a "Ropey" look?
Think Green recycle your YJ's sway and trac bars today!
Originally Posted by buickgnx88 View Post
"Jeep Wave threads, it's a newb thing, you wouldn't understand!"
Krochus is offline
post #9 of 12 Old 01-23-2011, 06:28 AM Thread Starter
airframer
airframer's Avatar
im goin to clean em up and post sum pics later on today. ive welded b4 but this is the first "important" thing ive welded.
post #10 of 12 Old 01-23-2011, 10:38 PM
Wintermute
1967 FSJ Gladiator
do a bend test, or just go pay the money at your nearest welding certification center to take your cert tests. Take tests for the same methods you weld with (eg. 1f, 2f, 3f, 4f, 1g, 2g, 3g, 4g, etc... and with the welding process you are using). If you pass the tests, then great...if you don't pass...well...
--Wintermute
"No man's knowledge here can go beyond his experience." - John Locke
"Vi Et Armis" - Cicero
Wintermute is offline
post #11 of 12 Old 01-23-2011, 11:48 PM
Krochus
After 14 years welding in heavy steel fab I'm of the opinion that having certifications from whatever local welding instruction facility is absolutely no indication or garentee whatsoever as to that persons actual welding ability.
At the end of the day welding is like riding a bicycle. You can read about it and be taught the physics behind it but the only way to get good at it is to ride it.
Krochus is offline
post #12 of 12 Old 01-23-2011, 11:53 PM
Wintermute
1967 FSJ Gladiator
Didn't say it was an absolute indication...however, if a cross section test shows no occlusions, the bend test doesn't break it and the instructor doesn't fail it for just looking like crap, having undercut, lacking penetration, etc... it's probably a good start for him to tell if his welds are decent. If you're doing welds that require full x-ray analysis or food quality stainless, then get your certs (cause they most likely won't hire you without them) and then make damn sure your welds will pass all of the x-ray tests everytime you make one...and have your insurance paid up just in case one fails.
--Wintermute
Should i weld it? Eman Fabrication Shop 7 09-23-2009 03:22 AM
Weld-a-nut dz1087 General Jeep & Off-Road Equipment 1 03-01-2009 07:06 AM
When you weld.... IGotADisneyJeep Fabrication Shop 29 03-26-2007 01:43 AM
what do you use to weld? cotoole Fabrication Shop 4 10-12-2006 07:23 AM
Stick weld or MIG weld? theboxman71 Fabrication Shop 39 10-05-2006 06:46 PM
