How should i get more penetration? - JeepForum.com
post #1 of 56 Old 01-05-2013, 07:41 PM Thread Starter
sevenscrew
1/4" material. Flux cored mig
Should I uphill and go slower?
image-996894329.jpg   image-1248305140.jpg   image-3876248581.jpg   image-2970215003.jpg   image-261853735.jpg
1997 Limited 5.2L - SOLD
2016 2DR JK
sevenscrew is offline
post #2 of 56 Old 01-05-2013, 08:49 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Bevelling the joint would help. So would travelling uphill.
What welder are you using?
BESRK is offline
post #3 of 56 Old 01-05-2013, 11:00 PM
my-jeep-earl
1971 CJ5
Are you using a 110V welder? If so you might not get much better than that.
my-jeep-earl is offline
post #4 of 56 Old 01-06-2013, 04:13 AM Thread Starter
sevenscrew
Lincoln 180
2016 2DR JK
post #5 of 56 Old 01-06-2013, 09:47 AM
Ironworker709
Ironworker709's Avatar
Like was said,bevel the joint,and travel uphill.....downhill never penetrates much at all,your puddle will stay in front of your wire and cause it not to burn into the steel,more or less just laying on top.
Start your puddle,then travel uphill watching the puddle fill to the desired fill and then just keep traveling ast that one consistent speed untill filled
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #6 of 56 Old 01-06-2013, 10:04 AM Thread Starter
sevenscrew
Okay thank you
2016 2DR JK
post #7 of 56 Old 01-06-2013, 10:15 AM Thread Starter
sevenscrew
What it the weld is horizontal?
2016 2DR JK
post #8 of 56 Old 01-06-2013, 12:44 PM
bigwahini
Uphill meaning "push" the torch?
ifyoubegintothinkyou'relosingcontrol...it'salready gone
bigwahini is offline
post #9 of 56 Old 01-06-2013, 12:49 PM
Sandhara
You could always preheat it some.
99 Wrangler Sahara 5spd manual - Mine
08 Patriot sport 4x4 auto - Wifes
92 Cherokee Lorado auto - for when mine needs fixin/winter beater
Im sorry, some times i drink and post stupid comments.
Sandhara is offline
post #10 of 56 Old 01-06-2013, 01:29 PM Thread Starter
sevenscrew
Is uphill harder to get nicer?
Also now this piece is bowed from the welds pulling it in . Anything I can do to straighten it out
I feel like when I unbolt it from the jeep I won't be able to line it back up
2016 2DR JK
post #11 of 56 Old 01-06-2013, 01:46 PM
sailsurf7713
When welding uphill I set my machine for roughly 1/2 the material thickness. Then trace the front of the puddle and pause on the "sides." Despite the lower settings it still burns in nicely. I'm sure there are people out there that can make a "pretty" uphill weld, but yes, it is difficult. You can also use solid wire for this application with that machine. I don't know if you're just using flux core for the extra penetration.
Professionals, correct me if I'm wrong here.
Good info, IMO
http://www.weldingtipsandtricks.com/...echniques.html
'99 SE: The "It could be worse..." jeep
Originally Posted by 97flexy View Post
...I say don't lift but CUT. :)
sailsurf7713 is offline
post #12 of 56 Old 01-06-2013, 02:20 PM Thread Starter
sevenscrew
I don't have a tank. Thanks so much though
2016 2DR JK
post #13 of 56 Old 01-06-2013, 02:46 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
It bowed in because you piled on a bunch of weld in that inside corner. As the hot weld cooled.. it shrank... pulling in on the inside of the plate causing it to bow.
Depending on what tools you have at your disposal, you might be able to get some of that bow out with a BFH.. a winch cable (pulling from the front), a bottle jack (pushing it out), an Oxy/AC torch (heat and bend).. or a combination of some of those. .. or, cut it off and start over.
If you're having issues like this, it might be better to push "pause" on the actual bumper fab, and play around with the welder and some scraps to get the technique down. It's alot easier to toss the scrap and try again, than it is to fix something that's already welded to a nice Jeep.
BESRK is offline
post #14 of 56 Old 01-06-2013, 03:04 PM
Motorcharge
Slowing down with a consistent pattern should help too imo. I like to do cursive Cs and come back about halfway through the previous one as I go. Makes for a much cleaner weld and gets good penetration.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #15 of 56 Old 01-06-2013, 04:52 PM Thread Starter
sevenscrew
I have it on voltage E and 5.5 ish wire speed fluxcore .035 Lincoln 180 does that sound too high for 1/4"?
I'm bolting the d ring mounts thru the main mounts so there's a lot of strength combined between the bolt and weld incase the weld would fail.
I'm pretty confident in the rest because its mostly cosmetics I'm not going to be pushing stuff with it. When I get a winch in 4 years after I come out of the army I'm going to just make sure the plate it sits on is well secured to the main mounts.
I have my stock tow hooks sandwiching the frame rail with the plates
2016 2DR JK
