how to narrow a rockwell axle - JeepForum.com
post #1 of 17 Old 01-22-2009, 09:26 PM Thread Starter
jason m
Nothing but the facts
jason m's Avatar
well last week i dug into my rockwells so i can narrow them down. i will cut 7.5" off the long side tube and re-weld it so i can run a short side axle shaft on bolth side's. i did this on my chepo harbor frieght band saw, but after getting it level it cut the ends perfect. i got one cut done and had to leave, so heres were i am now.
i was going to build a JIG to get the tubes re-centered but i will just use inserts and flat stock welded to the corners to line it. should be damm close, close enough for a rockwell. this is what i did when i reparied crane section, worked for them.
so heres some pic's for now and this weekend i will have more.
jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #2 of 17 Old 01-22-2009, 10:19 PM
mudwhoreTJ
That is one hell of an axle...turning your jeep into a duece and a half maybe?
mudwhoreTJ is offline
post #3 of 17 Old 01-23-2009, 05:54 AM Thread Starter
jason m
jason m's Avatar
nope going into a buggy, the 60/14 bolt will stay in the jeep.
jason.
jason m is offline
post #4 of 17 Old 01-23-2009, 05:59 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Looks like you could just clamp/tack 4 pieces of angle iron along the corners to align it...
I'm definately gonna follow along on this build..
BESRK is offline
post #5 of 17 Old 01-23-2009, 06:08 AM Thread Starter
jason m
jason m's Avatar
ya that's the general idea, before i went to sleep last night i had a good idea with maybe the angle iron on the inside of the tube. i will know better this weekend.
jason.
jason m is offline
post #6 of 17 Old 01-23-2009, 11:54 AM
Slawth
Master Rebater
Slawth's Avatar
1978 CJ5
Awesome. Can't wait to see Monday's update.
Slawth is offline
post #7 of 17 Old 01-24-2009, 12:36 PM Thread Starter
jason m
jason m's Avatar
ok heres were im at now. im am runing into some problems ( like any build ) but nothing i cant over come. when the rockwell axle's are built form the factory they start as two half's, like two piece's of channel iron. so they weld the two halve together when they do this the side's get sucked inward, big time.
so now its not as simple as lining up the edge's, so i will go back to the idea i had with a line up bar. so now i need to have 4 pucks made, 2 that will fit the seal retianer plates OD and then a set inside the carrier bearing caps. i will have holes cut into the centers of the pucks that will be 1.5" so i can use the line up bar i have for the 9" axles. works for them so it should be fine for the rockwell.
i need to tear down another rockwell center and remove the bull gear and upper pinion gear set. this way i can use that bare center for a JIG with the line up bar.
so heres a few more pictures, sorry for the crappy cell phone ones.
jason.
jason m is offline
post #8 of 17 Old 01-24-2009, 03:59 PM
Turner
What kind of suspension will the buggy be running? The reason I ask is if you will be using leafs it would be an excellent time to turn the tube that way the leafs can sit flat.
Or you can have your shocks/coilovers/ or whatever your running higher away from those nasty rocks. Looks awsome though
--Turner--
2006 Jeep TJ
1982 Toyota Pickup 20r/22r Hybrid, 5.29s, Lockrite frt/spool rear, Longfields, Hysteer, discs, armor, dents, smiles.
1970 Ford Bronco302, dana 30, 9", 3 on the tree, show stopper.
Turner is offline
post #9 of 17 Old 01-24-2009, 07:35 PM Thread Starter
jason m
jason m's Avatar
going to run a FOX air shocks. i got real lucky, a good friend is building another buggy. so he stripping his old buggy down to a chassie and is giving it to me for the price of a rear steer 60 axle that i built for him over the summer and some cash.
so its a pretty good deal ( on my end ) and i figure buy the time i would of got all the tube and bent it up its still cheaper for me. another plus i always liked his buggy, http://www.pirate4x4.com/forum/showthread.php?t=745332 this is the twin of the chassie im getting. my friend rick built two but if you follow the other link in that piarate post you will see it, the one in the snow.
so picture that buggy with the rockwell axles under it. i will have to play with the up travel in the front but nothing i cant handle. specs for my buggy will be a TPI 350 ( mild build maybe 300-320 HP ) a T-400 with eather a 205 or a dana 300 and of course the rock's with rear steer.
more to come, but money dictates all my move's, like any build
jason.
jason m is offline
post #10 of 17 Old 02-07-2009, 07:42 AM
voodo
More.............................????????????????? ???????????????
voodo is offline
post #11 of 17 Old 02-07-2009, 08:31 AM Thread Starter
jason m
jason m's Avatar
its in the hands of the machine shop ( my friends place ), he is doing some simple machine work for a line up bar. so im hooping in a week or two i will have some more progress. till then really nothing more to report on.
i did tear down a broken center chunk. it had a bad upper ring gear, so i will use that as part of the JIG. that chunk will hold the pucks in the middle, im going to place them in the carreir bearing jurnails ( how ever its spelled ). then for the outers i will use the OEM seal retainer plate positon and have him put a 1.5" hole in the center of another set of pucks.
so once the bar slides thru all the pucks its should be very true. agin once i get them back i will post back with more pictures.
jason.
jason m is offline
post #12 of 17 Old 02-07-2009, 04:52 PM
Fastbeeatch
Finally got that project going, wow you must love moving those around your garage very interesting stuff can't wait to see the centering whatchamajiggy thing you're making. Good luck and can't wait to see the pics of the buggy build will you start a buggy build thread here or on Pirate I don't see too many build threads on here for buggy's.
95 4L Auto D300 TC
103" Wheelbase
D60 Front 14 Bolt Rear 4.10 Gears
H1 Wheels 36" GoodYear OZ Tires
Fastbeeatch is offline
post #13 of 17 Old 02-07-2009, 05:02 PM Thread Starter
jason m
jason m's Avatar
i will probally do one here in the fab section. i got some time before i start on a buggy. but like i said im getting a complete chassie from my friend that will need some tweeking. so that will be a big step in a faster direction. the motors built, the tranney is getting a freshing up in a month. the dana 300 is apart wating for machine work and HD yokes ( i need to buy them still ).
wiring harness is in maine at another friends place. i have parts scatterd but once i get the chassie i will start bringing them together.
getting past the axle work and getting the steering set up will be the next hurdle.
anytime you want to come buy pat just drop me a line and you know me weekedns are best.
jason.
jason m is offline
post #14 of 17 Old 02-07-2009, 05:11 PM
Fastbeeatch
Will do, I have been working weekends to try to make ends meet so free time is hard to come by, but I definetly want to take a look at what you are doing this stuff is way out of my league but I do love to learn new things.
95 4L Auto D300 TC
103" Wheelbase
post #15 of 17 Old 02-07-2009, 05:39 PM Thread Starter
jason m
jason m's Avatar
any time pat.
jason.
jason m is offline
2.5 ton rockwell project Lostj General Jeep & Off-Road Equipment 23 08-23-2008 09:39 AM
2.5 rockwell 1977cj7 Engines & Drivetrain 0 04-12-2008 09:04 PM
Narrow or Wide? gmshades Tires & Wheels 7 08-25-2007 03:41 PM
Rockwell t-case? Ryanpowell167 Engines & Drivetrain 14 06-10-2007 08:49 PM
RockWell bracket in cj8 welding pic RockJeep Fabrication Shop 1 09-18-2004 05:39 PM
