How much should a cage cost?? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > How much should a cage cost??
Rockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Poly Door Hinge BushingsStainless Steel Door Hinge Pins
Unread 07-04-2008, 08:14 PM   #1
learfxr
I'm looking at buying a tube bender and doing my own work, or paying to have a cage built. I can get a good bender for around $800. What would a cage cost? I need to determine which route to go. I also need to explain the expensive tool to my wife.
1989 YJ
TBI350 4L60E from 94 Yukon
Rockwells and 47's under construction
2000 TJ The wifey rig
3.5" and 1" body, 8.8 swap, 35's and 4.88's
learfxr is offline   Reply With Quote
Unread 07-05-2008, 07:52 AM   #2
Grape Ape
Web Wanker
Grape Ape's Avatar
It doesn't matter what a prebuilt cage would cost you should tell the wife it will cost $5000. Plus the cost of the new bumpers you can build with the bender would be $5000 and the new rear bumper would be $5000. The stinger for the new bumper is yep you guessed it $5000. So now you have the money $20000 to go out and get a good tube bender, a nice notcher, a welder, a plasma cutter, yep see how it works. If you want a really nice (read expensive) welder and plasma cutter, etc... then just tell her everything would cost $8000 or $10000 to buy it prebuilt.
Seriously it depends on what tools you already have. Having a tube bender would be nice but if you also have to get a welder and other tools then it would be cheaper to buy prebuilt. If you have those items and a tube bender is all you have left to be able to fab up a nice cage and bumpers and sliders then by all means get the bender it will pay for itself soon enough.
As for the bender if you are looking at a manual bender you may want to look into the JD2 model 3 It runs $295 and the dies are $150 to $350 depending on size.
The Final Salute
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things, the people you meet and the books you read. Charles E. Jones
I think I'll add some memorable quotes. blah blah blah..... FPKites
Trying to understand some people, is like trying to pick up a turd by the clean side.
Grape Ape is offline   Reply With Quote
Unread 07-05-2008, 08:03 AM   #3
redhatman
redhatman's Avatar
I assume you trust your welding skills with your life?
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
"Project Dirty Princess"
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
"Project Grow A Set"
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline   Reply With Quote
Unread 07-05-2008, 08:11 AM   #4
xxxflhrci
The opposite side of that is does he trust the skills of a total stranger...
xxxflhrci is offline   Reply With Quote
Unread 07-05-2008, 10:17 AM   #5
MLJeeper
haha touche
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline   Reply With Quote
Unread 07-05-2008, 11:07 AM   #6
Dutchers
if you want i have blue prints on how to build your own tubing bender (manual if course). but youd need a welder, grinder, sander, oxyacetylene torch, and a drill press, sooooo yeah. BUT if you can make your own parts you can make parts for other ppl and the stuff can pay for itself.
-Dutch
Dutchers is offline   Reply With Quote
Unread 07-05-2008, 11:22 AM   #7
Joe Dillard
Electric Chair Operator
I designed & built my own cage with the help of a couple friends.
Material cost was ~$200, plus a few odds & ends like masking material, tarp, primer, & paint. I borrowed a really nice hydro bender and tube notcher.
Your cost is going to be geared towards how "custom" or extream you want it to be. Plus, will it be DOM, HREW, chromo, size of tubes, or a mix of all these metals? Plus, how many places will it be tied to the frame and are you going to reuse any of the old cage?
I can easily see mine costing upwards of $1,500+ if somebody else bought the materials, and did the fab, paint, and design work.
Joe Dillard is offline   Reply With Quote
Unread 07-05-2008, 03:56 PM   #8
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I charge material and labor. For material, I do "my cost plus 20%". I have to buy at least 300ft of tubing to get a price break. My last order of 1.75"x.120" DOM was about $4.30 per foot. Last cage I did, I charged $5.00 per foot for the material. Plus, you have the mounting plates, nuts/bolts, gussets..etc. Price adds up quickly.
For labor, I charge $40hr.
There are all kinds of factors that affect the price of a typical cage... am I going off stock rollbar or doing one from scratch? Simple front add-on or something more serious? X bar? Shoulder harness bar? Hip bars? Seat mounts? Tied to frame?...etc.
If you're a competent welder, a bender will pay for itself on the first full cage you do. After that, it can make you money.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 07-05-2008, 04:08 PM   #9
learfxr
Thanks for the replies
I was told about a few good places to find kits over on the Lone Star Jeep Club. I'm leaning towards the starter kit from here http://www.kozoffroad.com/pages_cata...jrollcages.htm
I've never been a fan of bending. I am no good at figuring bend allowance and measuring where to place the bend and have it right. I would end up with plenty of scrap. I love to buy tools for my shop, but I think I'm better off not doing some things. I'll stick to things like my bumpers, a copy off of Besrk's design. Some of my bumper pieces were bought from Besrk to make it easier too. You're top notch Besrk
1989 YJ
Unread 07-07-2008, 08:38 AM   #10
zachv
Vendor
We offer our YJ/TJ cage addition kits that work nicely and if you need to modify something on them we can do that if you order over the phone.
Doing your own full cage is definitely a viable alternative. If you settle on one size die, likely 1.75", you can get a bender setup pretty reasonably and then you will have it. The challenge is that you may do like many of us and waste some tube before you get good, but that is to be expected. Bend Tech software helps, especially when new, but I find my "feel" has taken me further.
Have a great day!!!
Zach Vaughn.
AtoZ Fabrication, Inc.
570-385-3931--shop
570-385-3932--fax
MADE IN AMERICA---and proud of it!!!
Now scheduling cage/custom work so call now to get on the calendar.
CHECK OUT OUR DIY FAB PARTS FOR SALE!!
We also offer the best prices available on:
Advance Adapters
Clayton Offroad Suspension
RCV ultimate axle shafts
Corbeau Seats
Raceline Wheels
zachv is offline   Reply With Quote
