How to: Make a Trail Mig (Flux Core) welder - JeepForum.com
post #1 of 45 Old 09-01-2010, 01:44 PM Thread Starter
sherlocktk
Hi all. I just finished making a mig welder that uses 2 car batteries (24v). Here is the how to. Total cost was around 150, but only cost me around 50 as I consider the welder free. This is basically the same system as ready welder but without the cost.
My cost was $35 dollars as I had many of the "parts" lying around.
Parts List:
1. Harbor freight 90 amp Flux core welder. This was my first welder, but it had outlived its usefulness as I got a better machine. Frequently on sale for $90
2. PWM (Pulse Width Modulation) 24v motor speed control ($25) - ebay
3. Jumper Cables ($15) - 8 ga seems to not get hot at all.
4. Plastic Home Depot tool Box ($8)
5. Battery Disconnect Switch ($4)
Step 1. Take out the "guts" from the harbor freight welder. The only parts you want are the ground cable, Torch cable, Wire feed motor assembly and the thing that holds the spool of wire. I donít have a picture of the gutted welder.
Step 2. Take out the Top plate in the welder that all of the above items and attach into a box of your liking. I used a 8 dollar home depot tool box as seen in Pic 5 below. I cut out the handle part and screwed the metal plate from the mig welder into it to hold all of the items.
Step 3. Install Battery cutoff switch in appropriate position (red handle thing in Picture 5. This allows me to turn off and on the welder without needing to mess with the jumper cables.
Step 4. Wire up the Motor to the PWM speed control and trigger switch on mig gun. Picture 1 and 2 for the Wiring diagram
Step 5. Attach the welding "ground" to the Positive Connection on the battery, Attach the mig gun to the negative battery connection. via the jumper cables
Step 6. Tidy up the wiring (which I have not done yet), attach the PWM Controller somewhere Fit it all in a box and turn the speed control to about 20 % and run a test bead (Picture 4) The picture shows .030 wire, I have since tested .035 and liked the results even better, but either work ok.
Step 7. Put you goggles, Gloves and all the appropriate cables (I put my 4 1/2 grinder) in the tool box for your "welding kit" It all fit in nicely.
Optional: I thought about just putting terminals to hook normal jumper cables to, but I really did not like the idea of having to pull the welder around and have a cable short out somehow. I opted for the dedicated cables, but it would be easy to do some type of high current connectors I suppose. This would take away some of the bulky wiring. I would also consider a better ground clamp. The one from Harbor freight gets very hot, but the harbor freight mig gun does not seem to heat up.
Please post back if you have tried this and liked it.
Your Done, and saved many $$$ over a ready welder. Any Questions or comments?
IMG_0241.jpg   batteryWelder Wiring Diagram.JPG   IMG_0242.jpg   IMG_0232.jpg   IMG_0239.jpg
sherlocktk is offline
post #2 of 45 Old 09-01-2010, 04:51 PM
Area.3.Fiftyone
That's pretty slick.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #3 of 45 Old 09-01-2010, 11:11 PM
Kettles
I might get around to this. Not because I think I need a welder for trail use, but It would be a cool project. And I like welding.
One of the things I dont like about the HF welder is that it is a "hot tip". Im no electrician but I would guess that I could find a heavy duty solenoid (battery isolation solinoid?) and wire into the trigger switch to make it a traditional cold tip?
Again, Im no electrician, but What is special about a PWM controller for this use? Would a resistance type controller (rheostat) not work? Or is the PWM more predictable by having a 0-100% power instead of 0-X resistance, and requires less math to make sure it will work?
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #4 of 45 Old 09-02-2010, 01:38 AM Thread Starter
sherlocktk
It would be trivial to put in a 24v starter relay inline with the mig gun. You would need to change the green wires to complete the circuit that feed the Pwm controller instead of the motor and wire to make the starter engage off of the pwm power input feed I can make up a diagram next week im out on the trails this weekend
As far as a rheostat that would also work just as well for the speed control. One from a rc car or something would work. At 24 v. I have it set at 20 percent speed or so. That is potentially a lot of heat.
post #5 of 45 Old 09-05-2010, 10:44 AM
wozz
this is pretty awesome
wozz is offline
post #6 of 45 Old 09-05-2010, 11:06 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That is a great creative design but I am concerned that it won't put out enough heat for many common trail heavier gauge steel repair jobs.
Using a 90 amp MIG welder for 3/16" is marginal under most conditions, and lots of stuff that can break on the trail is at least 3/16". How well does that work for you with 3/16", especially when that 3/16" is a large piece or part of something bigger that will sink off a lot of its heat?
Cable-wise, I plan to use at least 4 gauge jumpers for mine, 8 gauge is pretty small stuff for jumping batteries and welding.
I like your idea and I am tempted to make one but I am concerned about its 90 amp rating.
Getting
Jerry Bransford is online now
post #7 of 45 Old 09-05-2010, 11:41 AM
Kettles
Nothing about it is 90 amp anymore, the 90amp part was the transformer in the welder, which is no longer in use. The only parts from that are the wire feed mechanism, and torch. It can now output hundreds of amps (limited by the cables themselves i would think).
Running off of 120 volts with a 20amp breaker you have 120 amps at 20volts (theroretical), that is why 220v systems with 30-50amp breakers can put out more amps, because there is more power available. But car battery's can output a couple hundred amps, and two batteries puts the voltage in the MIG range. Your limiting factor is the wiring now, and while the HF welder is kinda wimpy in the parts department, for occasional short use it should be fine.
_=====o000o
Kettles is offline
post #8 of 45 Old 09-05-2010, 11:52 AM
Jerry Bransford
Administrator
Oh yeah, that makes perfect sense now. Hah, and I normally consider myself fairly astute when it comes to electrical stuff.
Nice, you making me realize it's no longer a 90 amp welder is making me want to do this later when I get some extra $$$.
Getting
post #9 of 45 Old 09-05-2010, 11:57 AM
Showtime3492
coming from a career welder that is pretty slick!
Showtime3492 is offline
post #10 of 45 Old 09-05-2010, 01:03 PM
Ironworker709
Ironworker709's Avatar
I like it,i have an old 90 amp Cambell Hausfeld machine i gave to my family up north,but they never use it,they just wait untill i come to visit if something needs welded"hey Brother,make sure you bring you're welding stuff too"..lol
So i think i'll just get it back and try this out for the heck of it
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #11 of 45 Old 09-05-2010, 01:08 PM
webdog
DirtBound Offroad
webdog's Avatar
1990 XJ Cherokee
Now I regret selling my HF 90A Mig for $20...
webdog is offline
post #12 of 45 Old 09-05-2010, 07:09 PM Thread Starter
sherlocktk
So the test welds were on 3/16. Got good penetration. I would like to upgrade the ground clamp as it gets pretty hot but the mig gun itself got no hotter than normal. I think the 4 ga battery cables do not matter much as none of the hf wiring is that gauge. Considering you would be welding for a few min at a time I think the smaller gauge cables are adequate
post #13 of 45 Old 09-05-2010, 10:36 PM
dodger889
Just a note I would get the largest wire size that the roller could handle for the heavier welding. By adding a portable battery grinder you could some cleanup or a break.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #14 of 45 Old 09-06-2010, 10:41 AM
Jerry Bransford
Administrator
Yes but as described above, the welder is no longer limited to 90 amps as it was when it came from the HF factory. I'm looking for a used HF 90 amp welder (I made a $40 offer yesterday for a used one that was refused) for this project but I'll be using 4 gauge cables for it.
Getting
post #15 of 45 Old 09-06-2010, 10:47 AM
Ironworker709
No promises Jerry,but i maybe able to hook you up with one on the cheap,a few farmers i know who bought them and only used once or twice and figured out they were useless to them and sitting collecting dust,i'll see if any of those guys still have one laying around they want to get rid of.
Again no promises,but i'll see what i can do.
Never forget 9/11
Welder wont feed wire (MIG/Flux Core) AlTheKillerr Fabrication Shop 17 01-18-2010 11:10 AM
mig vs flux wire welder 3S00W Fabrication Shop 14 11-27-2009 08:58 AM
flux core welder questions 97tjgunner Fabrication Shop 9 06-20-2009 08:27 PM
which wire is better for flux welding on 3/16 with a 110 welder micahtbyrd Fabrication Shop 4 06-11-2008 08:36 PM
.030 or .035 flux wire for my 110v MIG welder? Jerry Bransford Fabrication Shop 20 02-21-2007 01:51 AM
