How to install a ‘lunchbox’ locker (ex locker, aussie locker, etc) in your D30 axle.
#61 | ||
My jeep has only ever killed 3 things, a cat, a deer, and my wallet. What's the problem officer? 1992 Red YJ. Lifted, locked, and loaded with beer (Disclaimer: This doesn't mean said driver endorses drinking and driving, please enjoy alcohol responsibly and do not operate any vehicle of any kind, thank you....) Thanks to the price of gas here ($4.25 a gal) I just bought a mountain bike, 0" of lift, 0" of travel, MT's, locked rear axle, oh yeah, it's the sh#$. |
#62 |
oil
great write up. question about the gear oil you mentioned.... do you need a special kind of oil for lockers? also who has the best price on the ausie locker? thanks
#63 | |
#64 |
Your write-up helped me immensley! A thousand thanks to you, oh great Canuk.
92 YJ, 2.5 l/o, 4" Lift, 33" Super Swampers, Superwinch EPi9.0, Aussie Locked Dana 30, Uniden pro510xl CB and Firestik antenna, Hi Lift, Tuffy Center Console, Miller Lite tap handle shift knob, 40mm ammo can tool box, chains, straps, etc. 2006 Wrangler LJ. Stock for now . . . |
#65 |
Note: A friend of mine installed a Aussie in a D-35C (in his yJ) & used the center pin provided by Aussie. Their center pin wore the carriers hole ob-longed/egged shaped. We even had a rep out to check @ a local garage. They sent us a new locker but when we used a micrometer the Aussie pin was smaller then the original, thus wearing out the carrier's hole. Aussie could not comment, nor could the rep. I have talked to others & they used their factory center pin to combat this. We removed the brand new locker & installed a Detroit.
P.S. We thought it was popping, (enough to rip the axle end off) (driving straight) due to the Lucas synthetic. Then we replaced the synthetic w/regular dino oil but it continued. Replaced w/Lucas synthetic, again, & then found the center pin problem. Aussie Locker Write up Comments are further down the post on the center pin problem, basically the same thing I said here.
*MY CJ IS YOUR yJ's DADDY* Project CJ8 Build Gallery <----Click CJ8 Build Thread<---- Click |
#66 |
would this work for a v-8 zj that is also gettin a wj brake set-up and a np-231 by any chance? i'm geared 3.73 should i have to pull the carrier out?
1994 JGC limited 5.2l 4in F>R swap 31in. dune grapplers, soft 8's, flowmaster 40 series and duals out the sides, taurus e-fan, high flow intake, 231 swap, 44a swap, NGK plugs, Shell 93 octane only, homemade choppped and drilled light bar, gold>black stripes, in the process of making true cowl induction hood and putting 96-98 cladding, bumper cover, and grill on |
#67 |
Thanks for the write up.... I have the 3.07 30 do i have to take off the carrier? If so, what steps do I skip or point to a write up..... Thanks for helping!
'88 Black Jeep Wrangler 4.2L 6cyl NV3550 Tranny 2.5 lift 31" x 11.5 tires Special Features: Front Parking Lights light up when I hit the brakes... Let me know if you are in a good club in Socal! |
#68 | |
1)Plan on having to remove it, tear the cover off, drain the fluid, and look at the cross shaft, if it's partiallly "blocked" by a gear tooth then yank the carrier and do it this writeup way. If it's not blocked from coming out then just pop the retaining pin that holds the cross shaft in out of there, pull the shaft, then roll the gears out and replace with the locker (axle shafts of course still need to be removed). 2)Do an exploratory run, pull the cover, see if it's blocked or not then put it back on and refill with oil and plan for when u wanna do the whole job. hth Sorry if the spelling is off, just sliced the hell outta my finger and am goin to get stitched up soon. Laters
#69 |
Wow... wounded and still responded. I appreciate the help!
#70 |
I just spent over an hour reading all 5 pages and I think it will be great. I just bought the locker today. I am going to go ahead and assume it is almost the same in a TJ from what a previous post said? If it took me over an hour to read I am assuming it will take a while to do. How long did it take you? I guess I will plan on riding in the rain. Thanks!
If I can get there I can wheel it! CentralMass4wd.com 1993 Ranger 2wd - dd 1999 wranger 2.5 - it gets used for something 1978 international scout - being built 1998 Cherokee sport 4.0 auto 1957 CJ5 - restoring back to stock http://www.jeepforum.com/forum/f8/restoring-57-cj5-stock-build-thread-553649/#post5168554 Bikes:2000 Ducati Monster 900: 2001 CBR 600 F4i: 1980 CB 900 my build http://www.jeepforum.com/forum/f9/my-build-thread-those-us-low-budgets-550786/ |
#71 | |
#72 |
Any reason the aussie locker install or performance would be any different on my 08 JK with a Dana 30?
Do these lockers wear out like some limited slip diff's after 20-30k miles? In 2 wheel drive, is there absolutley no difference in behavior? (I let my kids drive the jeep on the highways, in the rain, in 2wd, I don't want to find out that it makes it more dangerous. thanks
My Conservative Sahara |
#73 | |
#74 |
I'm pretty sure the two front axle options for the 4wd non-rubicon jk are hp dana 30 and hp dana 44. Not sure if they offer a lsd in the front of those though.
1998 Cherokee Sport 4.0 5 Speed |
#75 | |
Thanks for the info. While looking for gears, I was poking around and found this: "THIS GEAR ONLY FITS NON-RUBICON 2007 WRANGLER FRONT AXLES. Jeep changed the long-produced Dana 30 to use different gears, carriers, bearings, yokes and all. None of the parts for a 2006 and older Dana 30 will work with 2007 and newer Jeep Wrangler axles. " at this site: http://www.4wheelerssupply.com/catalog/product_info.php/products_id/71697 So it seems your info is good, but I have to be careful to get one for a new model Dana 30. Kurt
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
