How do you check Torque Wrench accuracy? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > How do you check Torque Wrench accuracy?
Rough Country Deals at JeepHut.comSteering and more from Ruffstuff!The Ruffstuff 14 Bolt Complete Swap Kit!
Unread 10-18-2006, 12:45 PM   #1
junglejeep
I have a click style torque wrench and want to check and see if it reads right. How would I do this?
If it's not right then how do you calibrate it?
I want a CJ-6 with a hardtop.
junglejeep is offline   Reply With Quote
Unread 10-18-2006, 12:51 PM   #2
Divinitous
Disgruntled Jeepforum'er
Divinitous's Avatar
Location: NY/NJ/PA Tri-State Middletown NY 10941, New York
http://home.jtan.com/~joe/KIAT/kiat_3.htm
-Ryan
Google Voice (or the number Grape calls when drunk): 845-476-8182
Originally Posted by Enzo Ferrari
"The Jeep is Americas only real sports car!"
Originally Posted by MrBlaine
"Jeeps do not make jeepers, jeepers make Jeeps."
Divinitous is offline   Reply With Quote
Unread 10-18-2006, 01:17 PM   #3
junglejeep
Any other ideas? I don't really like the idea of building a toe smasher on my vise. It may work well but there has to be another way. What types of shops should I look at locally to have it calibrated?
Unread 10-18-2006, 02:36 PM   #4
Matt in TN
1979 CJ7
Honestly I wouldn't fool with it unless you think it's way off - even then, you'll be cheaper to buy a new wrench than to "calibrate" your old one.
Torque specs are really specified as an "easy" way to guess at the longitudinal thread stretch, and even if your torque measurements are perfect (which is VERY rare), you're still looking at something like 30% error on the thread strain - it's all just a crapshoot anyway.
That being said - I'm careful to torque bolts to specifications, using the same (dry or lubricated) type of conditions. After that - I don't worry about it too much.
Join an off-road club! [URL="http://www.cumberlandoffroad.com"]http://www.cumberlandoffroad.com[/URL]
[B]'79 CJ-7, 304, T-18a, Dana 20, AMC-20 w/ Yukon 1-piece axles, and Dana-30, 33x12.50x15, 1" Body Lift w/ heavily trimmed fenders, full cage with seats and harnesses, CJ/Wagoneer power steering upgrade, custom front and rear bumpers, body armor, and belly-up skidplate[/B]
In the garage, waiting for hell to freeze over so I can finish the installation: Waggy front D44, AMC M23 rear
Matt in TN is offline   Reply With Quote
Unread 10-18-2006, 02:45 PM   #5
junglejeep
Matt you're probably right. A buddy of mine says just german torque them with a closed end wrench and call it good. Atleast I have one I guess.
Unread 10-18-2006, 06:03 PM   #6
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
I think the most important thing in using a torque wrench is just to get a multi-bolt setup at an even setting, like axle u-bolts.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct.
Member and Web guy: New Mexico 4 Wheelers My Truck Page on NM4W Site
JeeperDon is offline   Reply With Quote
Unread 10-18-2006, 06:26 PM   #7
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Exactly. There is a range of acceptable tightnesses so it's not usually important you get a particular bolt to a precise tightness. It's more important that adjoining bolts/nuts like on heads and wheels just be tightened to the same tightness. That just means a more important trait of any torque wrench is the repeatability of its settings. So to me, it's no big deal if my Harbor Freight Tools torque wrench says it's tightened to 90 ft-lbs when it's really 94 ft-lbs. I really just want all the lug nuts or head bolts to be tightened equally to prevent warping.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 10-19-2006, 07:32 AM   #8
junglejeep
Thanks Jerry and JeeperDon for that logic I never thought of it that way. In that case who cares I'm just gonna set it and use it.
Unread 10-24-2006, 06:25 AM   #9
TJ_with_Tusks
For craftsman torque wreches, you are supposed to take them to sears and have them calibrated once a year.
04' Columbia TJ
33" BFG AT's, OME HD lift, front airbag suspension, teralow 4:1 kit & supershort shaft kit, TW CV shaft, 4.10 gears, JKS body lift, track bars and quicker disconects, Warn 9.5ti, warn front bumper, garvin wilderness rack, and solid cast aluminum tusks,
TJ_with_Tusks is offline   Reply With Quote
Unread 10-24-2006, 03:44 PM   #10
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
For free???
Unread 10-24-2006, 08:14 PM   #11
Vinman
I completey agree with this.
Another thing I always do is adjust the torque setting on the wrench (click type) as low as it can go any time I am not using it. I see people set the torque setting to a specific setting, tighten the nut/bolt and then store the wrench without turning the setting back down to 0 or less.
This method causes constant pressure on the internal spring which, I'm sure, will contribute to reducing the wrench's accuracy.
Vince
Vinman is offline   Reply With Quote
Unread 10-24-2006, 09:34 PM   #12
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
all you really need is a spring scale like you find in science class and solid anchor point for the head (vice). measure out 1 foot from the center of the wrench's head (the middle of the square for the socket) and attach your scale so it can't slide on the handle. a thick rubber band placed on the handle and some twine will suffice for small measurements. now set you wrench to oh say 20 ft lbs and put the head in your vice (to simulate a bolt. you could put a bolt in the vice and put a socket on the wrench to fit if you like). now apply the turning force by pulling on the other end of the scale. when you hear the click, check the reading on the scale. it should match the setting on the wrench. if not then you'll know how far off it is. keep in mind that the variance probably isn't uniform though. it may be off 1 ft-lb at 20 ft-lbs, and off by 7 ft-lbs at 50 ft-lbs.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline   Reply With Quote
Unread 10-25-2006, 11:37 AM   #13
coonash
coonash's Avatar
Find a local vendor who sales and services pressure gauges. They also will calibrate torque wrenches. Our local rep told me that craftsman is the worst for calibrating. They are made by the lowest bidder and change from year to year.
Originally Posted by 5-90
This is an online forum, and the written word is the primary method of communication. If you make an effort to communicate clearly, people will be willing to communicate in return. If you don't make an effort, I don't see why I should - write like an idiot, and I'm going to think you're an idiot, that's just how things work.
USN Jeep Club Number 41
coonash is online now   Reply With Quote
Unread 10-30-2006, 01:40 AM   #14
dawnskaybug
I use Torque wrenches everyday at my job. If we find a tourque wrench not stored at the lowest setting we turn it in to get calibrated. Believe it or not alot get thrown away because they cant be fixed because there not stored at there lowest setting. Also dropping it will throw it off.
dawnskaybug is offline   Reply With Quote
Unread 11-02-2006, 09:58 AM   #15
Indy
Quick and simple method. Take a known weight and a known length. example, measure out 1 foot from the socket end of your torque wrench, assuming the wrench is more than 1' long. Attach the socket end to a fixed object. Set wrench to 10lbs, or whatever weight you have handy. Apply 10lb weight to the 1 foot mark on the wrench. Click? you're calibrated.
Odds are im typing on a tablet. It takes too much effort to add some punctuation. Im lazy, get over it
Never underestimate the power of stupid.
Indy is offline   Reply With Quote
