How do they channel water off ^^ shaped roofs - JeepForum.com
post #1 of 8 Old 08-16-2013, 10:50 AM Thread Starter
outbackmatt
I notice many large manufacturig buildings are built in a way that they look like two buildings connected to each other side by side and the roofs come together to form ^^.
I'm curious how water sheds off in the middle do they have some type of gutter built in? What do they call it?
My new shop addition is a 20 x 50 metal building and eventually I want to put another one next to it and connect them together and take the wall down to make one building measuring 40 x 50. This will give it a roof design similar to those large commericial buildings and I'm trying to figure out how to channel rain water out of the double ^ peak.
Here is a massive version of what I am trying to accomplish. Same principle though.
outbackmatt is offline
post #2 of 8 Old 08-16-2013, 11:04 AM
RICEKILA
commercial roof aren't really flat - there's peaks and valley's -- and pitched to scuffer plates - depending on the sq. foot theres 4" drain caps every 20' feet or so -- if you stand next to an outside wall during a heavy rain - where a drain is ---- it sounds like a toilet flushing -
In the back right hand corner of this photo -- is the raised grading for a drain --
And incase if your wondering if the air in a Target store is safe to breath --- notice the black / green gelatinous goo coming out of a A/C unit --
P/S -- photo of your roof ?
I was once a tree house.
I lived in a cake.
But I never saw the way - the orange slayed the rake --
RICEKILA is offline
post #3 of 8 Old 08-16-2013, 12:19 PM
tjcj
The photo you posted more than likely has an internal gutter. Basically a trench in the roof that is sloped to either end of the building to downspouts.
Sent from my XT881 using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #4 of 8 Old 08-16-2013, 02:07 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
internal gutters. work great, but make a heck of a mess if one ever comes loose insided the building.
where i work is 4 buildings joined together, each build about 6-10 years apart and we have quite a few internal downspouts.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #5 of 8 Old 08-16-2013, 02:28 PM Thread Starter
outbackmatt
Ah! So its called an internal gutter. This may work well for my building. See its a metal carport building which the roof is pitched end to end along the 50' length so most of the rain water runs toward the front end and not really off either side. The internal gutter wont have to handle too much water drainage.
The carport building has 9' sides and I'm wanting to go 12' on the addition. I wonder if internal gutters work with 2 buildings of different heights?
Here is the type of metal building it is. The back of it is joined to my larger 2 story shop and there is another metal building joined to it on the other side, and then I have another metal building next to it. lol I'm just having to slowly build up the shop in stages as jobs come in and money becomes available.
post #6 of 8 Old 08-16-2013, 04:02 PM
tjcj
Yes a internal gutter can be used on 2 different eve heights. However if the eves are the same as the red building you posted I'm not real sure you could get a gutter to seal against it. Because the roof is rolled around to the sides to act as an eve trim of sorts.
tjcj is offline
post #7 of 8 Old 08-16-2013, 05:36 PM Thread Starter
outbackmatt
Are there premade gutters that you install or do you fab them from metal roofing material?
I see the the rounded eves might make it more difficult but shouldnt be too problematic. The bottom of the rounded eve panel can be unscrewed and lifted up, then a premade gutter slid under and everything screwed back down.
post #8 of 8 Old 08-16-2013, 06:50 PM
tjcj
You can have gutters made. Any sheet metal fab shop should be able to bend up whatever you want for a gutter in 10'-12' lengths. Then you just have to source hangers , screws and the sealant ( not silicone) for the joints. Around here there are a couple seamless gutter installers, but most of those are used in residential. All the internal gutters I have installed in 18 years have all been stainless steel straight from the metal building supplier.
tjcj is offline
