how do i use a die on pipe?!?!?!!! - JeepForum.com
post #1 of 28 Old 04-28-2013, 03:05 PM Thread Starter
madduck
trying to make a few fixtures with gas pipe, 1/2". i've it mounted in the vice and am trying to use a hand die...and i'm about to scream.
i can't get a good bite. i beveled the edges, which, come the thing of it maybe i shouldn't have. but, trying to apply equal pressure so it stays square and applying the pressure long enough to get a good bite seems to be eluding me.
the pipe vice i'm using is holding the pipe horizontal and it's about crotch level. i did one short piece that i was able to place in the vice vertical and use my body weight to get the die to bite. it wasn't pretty, but i got it to work. there's no way i can place this piece of pipe vertical, i barely got the other piece cut. it was quite an ordeal.
ideas and/or suggestions???
thanks much
2006 lj. 4.0l, 6-spd, k&n fipk(was on it when i bought it, gonna get rid of it.) 17'' jk rims-black ops, borla exhaust, 3" currie lift with anti-rock and rear anti-sway bar.
madduck is offline
post #2 of 28 Old 04-28-2013, 03:56 PM
chriskeenan
I've always used a pipe threading machine
I dont see why it cant be done as you describe though. Maybe the pipe OD is too big. Remember pipe sises dont match up to standard thread sises.
chriskeenan is offline
post #3 of 28 Old 04-28-2013, 04:06 PM Thread Starter
madduck
It's the right diameter, bought it brand new at lowes. The dies says 1/2 NPT and on the short piece I cut the fixtures fit. Is just getting a clean, square bite that's a bear.
madduck is offline
post #4 of 28 Old 04-28-2013, 04:51 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
a few things to check. Most Pipe dies i have used are adjustable, maybe yours is adjusted too tightly making it too small to start correctly.
2nd, and possibly a stupid question, are you sure you are starting it the correct way? being pipe thread, it is tapered so it will only start one way to get the taper on the threads
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #5 of 28 Old 04-28-2013, 06:45 PM Thread Starter
madduck
no prob up'd, never to proud to have someone ask/question what one would think is obvious. i have a wonderful gift of overlooking it quite often.
i've tapped and die'd lots of stuff before, but much smaller stuff. like i said earlier though, i was able to cut threads in a much shorter piece because i had it vertical in the vice and was able to use my body weight to help keep pressure on the pipe/die. it seems that the die will start to cut but without enough pressure to keep the die cutting the early part of the bite just strips the pipe smooth.
and this is a die that is in a wrench, it's not adjustable.
thanks for the ideas.
madduck is offline
post #6 of 28 Old 04-28-2013, 07:37 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Pipe is sized by I.D. not O.D. If you want pipe that is 1/2" O.D. you need to buy 3/8" pipe.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
post #7 of 28 Old 04-28-2013, 08:45 PM Thread Starter
madduck
hmmm. layback thanks.
so...i'm prob using the wrong size die. well...that would explain why it's so dad gummed hard to get started. tomorrow i'll take a look at the OD of the pipe because i'm definitely using a 1/2" die.
thanks much.
madduck is offline
post #8 of 28 Old 04-29-2013, 09:27 AM Thread Starter
madduck
put a micrometer on the pipe this morning and it's showing .84. so...what size die should i use to cut this thing? i'm using the type of die you would use in a tap and die set for bolts and such, not a pipe cutting die that you put on an elec thread cutter.
thanks layback, like i said in an earlier post i'm pretty good about missing the obvious.
madduck is offline
post #9 of 28 Old 04-29-2013, 03:18 PM
underpowered
does the die say 1/2" NPT, or something like 1/2-13? i highly doubt you have the wrong die, if it is a regular bolt die, you would never even get it started.
we have manual pipe dies at work and use them often but never had any issue starting one. all ours are self aligning and only take a little pressure to get them to bite and start threading.
could you post any pics of what you are using? might be able to spot something you are missing maybe.
post #10 of 28 Old 04-29-2013, 03:28 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
The O.D. on his pipe is about .84" which makes it a 1/2" pipe I would guess. He needs to use a 1/2" NPT die or he is in for some serious grief!!
post #11 of 28 Old 04-29-2013, 06:21 PM Thread Starter
madduck
ok...lemme go back and see how in the heck to post a pic. be back soon.
madduck is offline
post #12 of 28 Old 04-29-2013, 06:28 PM Thread Starter
madduck
madduck is offline
post #13 of 28 Old 04-29-2013, 06:29 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
http://www.flickr.com/photos/madduck00/8694711958
post #14 of 28 Old 04-29-2013, 06:32 PM Thread Starter
madduck
ok, i've downloaded the pics into flickr. don't i copy and paste the link info into the pic window that opens up here?
madduck is offline
post #15 of 28 Old 04-29-2013, 06:34 PM Thread Starter
madduck
thanks layback, i'm trying to get the pic to show on the forum to make it easier for those reading this. i've done it before but it was a while ago. and i know flickr changed the way you posted pics to 'make it easier.' just don't do this often.
thx
madduck is offline
