How did you guys make center mounts for TT's? - JeepForum.com
post #1 of 6 Old 01-20-2011, 09:24 PM Thread Starter
JJeeper09
Im trying to make a tummy tuck for my current build and the only problem im running into is the center mount. I made a piece of steel plate, and welded a piece of angle to it. So a the high side it sits about 1 inch. That i believe is to high of an angle to mount the Trans and Transmission to. Anyone know how i should make one? here is a pic
JJeeper09 is offline
post #2 of 6 Old 01-20-2011, 11:34 PM
wushaw
Rockin jeep
wushaw's Avatar
Make your holes in the red iron when your able to, then shore up the tranny and remove the OEM skid, then mount the red iron to the tranny mount, then jack up the flat skid to the red iron and you will be able to see if your angle is correct or not. Adjust as necessary to obtain the correct angle.
I don't have a OEM mount style but what I just said is what I would do.
wushaw is offline
post #3 of 6 Old 01-21-2011, 06:36 AM Thread Starter
JJeeper09
I have a Lo Pro mount from Undercover Fab, which will help me not raise the t-case to much.. You think that will work?
post #4 of 6 Old 01-21-2011, 04:41 PM
wushaw
Rockin jeep
wushaw's Avatar
I have no idea if a lo pro mount will work, I went from a NV3550/NP231 to a NV4500/Atlas. The OEM stuff no longer applied or were even close to the same animal. I built a crossmember to hold the tranny/xfer case, my skid is completely seperate.
If your going to fab something you will need to tear into it.
wushaw is offline
post #5 of 6 Old 01-24-2011, 09:24 PM Thread Starter
JJeeper09
bump! more ideas guys
post #6 of 6 Old 01-24-2011, 10:13 PM
Boodyrider
Take off factory skid. Unbolt the factory mount plate from the factory skid. Use as a sample, or use on the TT.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline
CB mounts? gonejeepin247 Audio, CB & Ham Radios, GPS, & Electrical 31 02-26-2010 01:13 PM
HD LCA mounts dr hook Fabrication Shop 2 01-25-2007 01:37 PM
Where to buy mounts? EaglesSJ Fabrication Shop 2 10-14-2006 10:54 AM
Does JL Audio make a TJ Center Console Sub Solution? jeeplaw Audio, CB & Ham Radios, GPS, & Electrical 5 02-11-2005 10:58 AM
CJ mounts for 5.0? rustyCJ Engines & Drivetrain 3 11-19-2003 10:39 PM
