homemade press brake and die ideas - JeepForum.com
post #1 of 16 Old 08-30-2010, 04:46 PM Thread Starter
baja67
1980 CJ5
I'm looking for ideas for a press brake to use in my shop press to bend angles, etc. Anybody that has built there own, please post some pictures and tips on making one and also how you made your dies. I have metal fab tools such as mig welder, plasma cutter, chop saw, grinders, etc. and I shouldn't have any problem making one. I just don't have any way to mill or machine with a lathe. I have some ideas that I have picked up, but wanted to see some tried and true ideas from you guys on the forum. Thanks, Dan
baja67 is offline
post #2 of 16 Old 08-31-2010, 08:12 AM
Jim1611
Jim1611's Avatar
Here's something interesting to look at. Press Brake Project.. Sanity Check Pretty elaborate but may give you some ideas.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3 of 16 Old 08-31-2010, 12:13 PM
ORTJ
Swag Offroad has a decent little setup - 20 TON Press Brake DIY Builder Kit
ORTJ is offline
post #4 of 16 Old 08-31-2010, 02:31 PM
Jim1611
Jim1611's Avatar
I like that. Looks like something good to have.
My build thread
Jim1611 is offline
post #5 of 16 Old 08-31-2010, 02:36 PM
Swagoffroad
Vendor
Swagoffroad's Avatar
Let me know if you have any specific questions.
This press brake is a real time saver and your work will look so much better than smacking steel with a BHF in a bench vice.
I have plenty in stock and ready to ship out.
Troy
Innovative fabrication tools, & Drop down tailgate kits for YJ's, TJ's and JK's.
Visit us on
Swagoffroad is offline
post #6 of 16 Old 09-03-2010, 04:53 PM Thread Starter
baja67
1980 CJ5
I know some of you guys surely have some ideas and pictures of your homemade presses!
baja67 is offline
post #7 of 16 Old 09-04-2010, 07:03 AM
oiw
1967 FSJ Gladiator
Nice jeep! I made my press out of stuff i had laying around, probably not engineered perfectly but she works for me.The hardest part is probably making different dyes.Sorry no pics not good with all this computer stuff.I used 8'' I-Beam,8" Channel,and a 40 ton press probably went over board like always shes about 7'x4.5'.What part of AR are you from?
oiw is offline
post #8 of 16 Old 09-04-2010, 02:10 PM
Netpackrat
We had this thread not long ago:
http://www.jeepforum.com/forum/f37/b...brake-1081019/
Netpackrat is offline
post #9 of 16 Old 09-04-2010, 03:37 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I kind of pushed that big project to the back burner for awhile. However, I was actually looking over my 36" die yestereday and I think I've got just about everything I need to build a little 36" brake to do stuff like winch plates, frame kits.. brackets.. etc. I plan on going ahead with that project soon.
BESRK is offline
post #10 of 16 Old 09-04-2010, 04:47 PM Thread Starter
baja67
1980 CJ5
I took info from some of the old posts and also researched the web and made a brake press today to fit my 20 ton shop press. I still need to find some compression springs and I will be done. Maybe Home Depot or Lowes will have something. I tested it on a piece of 1/4 inch x around 2 inch plate and it bent it like butter. I will try to post some photos and more specifics tomorrow if I can find some springs to finish it. Thanks for everyones comments and ideas.
Regards,
Dan
baja67 is offline
post #11 of 16 Old 09-05-2010, 12:12 PM Thread Starter
baja67
1980 CJ5
press brake completed with pictures
Here is what I decided to build. I used 1/4 inch plate for the base with 2x2x3/16 angle for the dies. Mounted the base to 1/4x2x2 tubing. Welded the top die to the same tubing with it turned diagonally. Used 5/8 rod for the uprights along with some compression springs for a return. Picked up some simple I-beam clamps to clamp it to my press. Bent a 1/4 piece of plate just to test it. Bent it like it was nothing. Didn't have anything thicker, but most of my bending will probably be 3/8 or less. May check into getting some stiffer compression springs, but that is all Home Depot had. They work good, but could use a little stiffer spring. Any comments or improvement suggestions welcomed. Thanks again to all. Jeep forum is great!!!!
Regards,
Dan
baja67 is offline
post #12 of 16 Old 09-05-2010, 02:44 PM
oiw
1967 FSJ Gladiator
Nice job looks great.I miss read your first post i was thinking you were going to build a H press my bad.But it makes me think just how nice that break press would look with my press?I just might have a new project. Thanks
oiw is offline
post #13 of 16 Old 09-05-2010, 02:51 PM Thread Starter
baja67
1980 CJ5
Thanks oiw, did you get my pm from yesterday?
baja67 is offline
post #14 of 16 Old 09-05-2010, 05:14 PM
oiw
1967 FSJ Gladiator
Tried to PM you don't know if i did it or not ? sorry
oiw is offline
post #15 of 16 Old 09-05-2010, 05:18 PM Thread Starter
baja67
1980 CJ5
Got it, thanks.
baja67 is offline
metal shop/press brake help... theGiantPanda Fabrication Shop 9 08-25-2010 11:45 PM
Built a midget press brake flatlander757 Fabrication Shop 13 08-05-2010 11:20 AM
two homemade ideas. bigtim6656 Fabrication Shop 2 11-27-2009 07:55 AM
Homemade console... need ideas! jgrabski Fabrication Shop 30 04-06-2009 07:16 PM
homemade snorkle ideas? beneharris Fabrication Shop 14 11-28-2008 12:24 PM
