Quantcast Homemade Jerry Can Mount - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Homemade Jerry Can Mount
Old 10-07-2007, 04:07 PM   #1
Trombino
Decided to buy a Blitz Jerry can and base on eBay a couple of weeks ago:
5 Gallon Blitz Jerry Can
Jerry Can Mounting Base
Both items, shipped, were around $51. After arriving, I did some research and saw some ideas for mounting plates. As I don't have a welder, I decided to head to the local tractor supply store and see what I could rig up. I had some scrap sheet metal laying around that I planned on using for the base, but then needed to figure out how to mount it. I decided to use the (2) open holes for the spare tire on my LoD tire carrier, which required a little grinding on the LoD mounting plate. I next decided to pick up some 1/2", 6" hex tap bolts and bunch of 1/2" nuts and washers and began assembling. I ran with this all last week with a full tank, just to see how sturdy it was going to be and I had no problems. I'm not going to have it on all the time, but figure it will be nice the next time I head out to the trail. Here are some pictures of the end-product:
I figure total materials, aside from the Blitz base and can, were around $12 (including an allocation for rattle can that I had and the sheet metal).
Trombino -- '04 TJ -- Rubicon Express 4.5" Superflex + 3/4" Front Spacers, OME Shocks, Currie Rear Shock Relocators, JKS 1.25" BL, JKS BMML, JKS Quicker Discos, 15x8 Cragar Soft 8's, 35x12.50 BFG KM's, LoD Heavy Duty Rear Tire Carrier, Chopped Front Bumper, Uniden 520XL w/ 3' Firestik II, Skyjacker Steering Box Skid, Rusty's Engine Skid, IPF H4 Conversion w/ Fatboys, Hella 500 Windshield Driving Lights, Tomken Gas Tank Skid, ARB Rock Sliders, PSC Rock Ring (D30), Riddler (D44), MV50 OBA, Rusty's Air Tube, TBS, Flowmaster 40, Dana 44 with Trac-Loc, Warn XD9000i w/ Grill Guard
The Wife -- '02 KJ Limited -- Pre-Lowered, Full Mopar Skids, 245/70-16 General Grabber AT2's, Trac-Loc Rear, Flowmaster 50 SUV
Trombino is offline   Reply With Quote
Old 10-07-2007, 04:33 PM   #2
Dan Fredrickson
Vendor
Dan Fredrickson's Avatar
I don't want to rain on your parade......
And I really hate being critical when someone is just starting out but......
If those 2 bolts are all that is holding that can on it will bend over the first bump you hit with the can full, a can of gas weighs somewhere over 60lbs. A third bolt, creating a triangle pattern would be much stronger but still possibly bend under the weight.
Dan Fredrickson
www.ruffstuffspecialties.com
Much Better Than Good Enough
Sales 916.509.2242/Sales & Tech 916.600.1945
Dan Fredrickson is offline   Reply With Quote
Old 10-07-2007, 05:37 PM   #3
Trombino
Do you think using a Grade 8 bolt would help out? Filled, it weighed a little under 35 lbs. (which probably isn't the most precise as I used a standard bathroom scale). However, after a full week of driving (nothing to rough but a couple of seasonal roads), it still seems to be fine. Do you think if I welded some steel tubing over the bolt it would strengthen it more than it is now?
Old 10-07-2007, 06:13 PM   #4
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I imagine those stacked nuts (sounds funny saying that ) basically turn those long bolts into 3/4" solid rods. That's probably why their still not sagging.. but I think they will eventually. I'd rather see a center tube (maybe like 2" square?) running from the center (between the two nut stacks) out to another plate with at least 3 bolts (triangle pattern) attaching it.
Who knows?.. your setup may hold up. However, kind of scary to have a 5 gallon gas can (full of gas) fall off at highway speed. Better safe than sorry.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 10-07-2007, 06:28 PM   #5
Trombino
Yeah -- That definitely wouldn't be a good thing. Thanks for all the feedback. If I didn't have the 3rd brake light mounted, it would nothing to add a third mounting point. I guess its time to go back to the drawing board on this one.
Old 10-14-2007, 04:58 PM   #6
Mr.Crowley
1980 CJ7
do like a buddy of mine did..Get a 6'' peice of 2'' inner square tubing..''IE'' receiver hitch material..Weld to 8''x8'' plate..Drill 3 holes to match bolt patern of spare in plate.Drill hitch pin hole in square tube..Sandwitch plate and receiver between spare and spare tire bracket..Now weld on 1''-7/8'' square to jerry can mount and drill hitch pin hole..
walla
Instant quick release jerry can mount..also can be used for anything you want to put into reviever such as a rack,vice for u-joints.whatever..
I had him send me this for ya..
1980 cj7 258 weber,5'' of lift,33'' boggers,lincoln locked,lockright and a snorkle...Khaki Jeep Club member No. 1
1984 cj8 350 on 35's..the wifes
[QUOTE=Me]
"offroad it, and wave then you might understand"[/QUOTE]
BLS Home Chapter... Where it all Started
:hahaha: yj
My low Buck Rock Crawler project Project..Stop by and check it out..[URL="http://www.jeepforum.com/forum/showthread.php?t=497896"][B][COLOR="DarkOrange"]The lizzard Queen[/COLOR][/B][/URL]
Mr.Crowley is offline   Reply With Quote
Old 11-13-2009, 02:27 PM   #7
98VolsTJ
looks good man. i plan on making something alot like yours real soon.
98VolsTJ is offline   Reply With Quote
Old 11-16-2009, 02:10 PM   #8
jeepinmichguy_
Resident *** Hole
jeepinmichguy_'s Avatar
and now your selling it.....
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
How about this, if you had the Jeep Spirit, you wouldn't abuse the rest of us trying to enjoy a nice day out wheeling by bringing your brokeass broken down junkyard crap out to play where it can't handle it?
Special thanks to the following vendors for supporting the TJ of the Month contest:
jeepinmichguy_ is offline   Reply With Quote
Old 11-18-2009, 06:21 PM   #9
Trombino
If it will help you feel better about dropping $20 on it, I can throw in a pack of lollipops for you (legit offer)?
Cheers.
Glock Forum
