05-25-2005, 02:44 PM
#1
I know frame building is pretty tricky. But a jeep frame seems pretty straight forward. In my case I have a CJ7 and I want to have a stronger frame as well as one that doesn't look like swiss cheese. I can't bring myself to spending $1500+ on a new frame from matkin or 4wd hardware. I figure that if I take my time I could build a CJ frame using 2"x5" rectangluar stock. Do you think this could be successful or would it be a big waste of time and money? Any of your thoughts would be appreciated.
-Thanks
1981 CJ7 w/ IH Dana 44s f/r, 3.07 gears, NV4500, 3.9L 4BT CTD, Dana 300, 31" Procomp MTs, 3" of lift, soon to get D60/14Bolt & 37s
1991 YJ
05-25-2005, 04:26 PM
#2
ive made them before using 2x4 3/16 wall square tubing. the hardest part is finding a nice level welding table or a frame jig. i ended up using a home made jig to use. before you do any welding make sure you know what you are doing and your welder can handle full penetration of the thickness of the material you chose to use.
05-25-2005, 06:40 PM
#3
GROUND POUNDER
I'm gonna do this later on in the Fall. Plan is to use 2"x4"x3/16" wall. Since it's a frame for Big Lime, it'll be pretty much trail only stuff so I'm not too concerned about getting it exactly square/plumb. Pirate has a few good threads about frames.
05-26-2005, 08:27 AM
#4
I tried doing searches for threads regarding frames but didn't come up with much. I'm not sure if anyone can bring some light to this. I think im gonna go for it and see how well it turns out. I want it to be as perfect as possible since its gonna be used on road as often as off road. I will probably just use a flat welding table. But what does a jig entail, how is it work or is used?
1991 YJ
05-26-2005, 10:18 AM
#5
you can make a jig by simply drilling holes in your table. a jig is just a device that will hold the frame for you as you weld it up and make sure all your angles are where they are supposed to be.
06-01-2005, 07:49 AM
#6
I've kept thinking about this and was wondering if butt welds would be strong enough for the frame or would I have to get fancy and do "inverse fish mouth" cuts in order to make it strong, as in when I cut the peices to weld the frame would they have to look like this > instead of this l in order make it strong and well built?
-Matt
1991 YJ
06-01-2005, 04:21 PM
#7
GROUND POUNDER
I butt welded my entire rear half of the Jeep frame (from about the door opening back).. almost 4 years ago. Still going strong with no cracks. I've recently swapped in a much heavier drivetrain (lots of unsprung weight) and that is why I'm going to revamp my entire frame. I'll probably but weld again and then scab over the joints with plates <>
06-02-2005, 08:36 PM
#8
H2 Recovery Team Member
-Matt
Like BESRK said, for the most part butt welds (done right of course) should be strong enough, but it can't hurt to add some additional plating just to be sure. I added this:
on top of this just to be sure things would hold for a long time to come.
everything else is built off the frame so you want it to be as strong as possible. much easier to add strength now than later after you find you should have done it in the first place.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
06-02-2005, 08:52 PM
#9
hey sentinal02, what kind of welder where you using when you did that in that the pics?
06-02-2005, 09:00 PM
#10
little craftsman mig with .030 flux core. my first big welding project so the welds aren't the prettiest.  held up fine so far though and that's all that matters. balancing on two wheels at PAP:
full details on the repair are here:
http://www.jeepforum.com/forum/showt...t=frame+repair
06-04-2005, 06:11 AM
#11
Thanks for the pics sentinel, those help alot. The weld looks pretty darn good for your first time using it. I've only stick welded before, don't know how good I would be with a mig.
-Matt
1991 YJ
06-01-2012, 10:55 PM
#12
hate to bring this old thread up, but holy smokes do those welds look like poop.
06-02-2012, 03:24 PM
#13
GROUND POUNDER
06-02-2012, 04:51 PM
#14
Hope I didn't come off like a jerk, wasn't intentional. Im was just searching for some threads on frames and came across this one. Was really surprised that he didn't get any comments on the bad welds. I was a boilermaker (till my shop closed) , so I feel somewhat qualified to say something. And yes not every weld I make is perfect, Ive had bad days. But on those days I stop, or grind out the bad welds and redo. Ive seen some pretty funky welds hold up tho.When I bought my willys, I cut the back half of the frame off to redo it and what a sight that was, the PO had welded another jeep frame to the existing one. There was half penetration, porosity, undercut, cold lap, you name it, was even some wire in there , but it held up . Ill get some pics up if I can find the piece of frame I cut off. Anyway It might hold , it might not. But your frame is the backbone of your whole jeep. Why have any doubt? 50/50 Isnt a safe bet imo.
06-03-2012, 10:30 AM
#15
My Frame-Off, Stroker Magnum V8, SOA YJ/CJ Build Thread: www.jeepforum.com/forum/f22/magnum-force-mopar-mans-build-1412306/
