Homemade Automatic Parts Washer - JeepForum.com
post #1 of 16 Old 02-19-2014, 02:32 PM Thread Starter
bashbro
I am in the middle of my 1989 YJ frame-off resto. Goal is to make it reliable again and clean up the years of junk. I have vowed to clean and paint every piece that goes back onto the jeep. It will get dirty again but want to remove and treat all current rust and prevent future rust. So I have been looking up parts washers to assist with the cleanup but to me they don't look too useful as you still have to scrub and wash. Here's my idea for an automatic cleaner...
Take a 20 gallon rubbermaid bin. Drill a hole in the middle and mount a BBQ rotisserie spit and basket through the rubbermaid bin. Then, use a bulkhead and make another hole a few inches off the ground and plumb that as the input to the pump and output would feed a Y splitter with (2) PVC pipes on the top of the bin. Drill holes in the output pipes to spray onto the rotating basket. Would use a water based solvent such as Krud Kutter or something.
Basket would spin moving the parts around, would have a continuous flow of the solution running over the parts. Should be a hands off way to clean small parts.
Honestly, I got the idea from that show Gold Rush on Discovery. Think of this as a modified trommel.
I think i could have all of these parts together for under 50 bucks, less than i would pay at HF just to have to wash the parts myself.
Any thoughts or ideas?
1989 Jeep YJ
2.5 - AX5 - 4" RC lift
MY BUILD THREAD:
bashbro is offline
post #2 of 16 Old 02-19-2014, 07:45 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Maybe zip tie a few stiff bristle brushes inside the basket.. to help "scrub" parts as they tumble around..
BESRK is offline
post #3 of 16 Old 02-21-2014, 12:20 PM
boybadone
You have to build this, I want to see it in action.
boybadone is offline
post #4 of 16 Old 02-22-2014, 08:26 PM
ltrail
1984 XJ Cherokee
An old dish washer and a tank if solvent has worked for me in the past(even just purplepower, or Berrymans claners). Little water pump from an RV seems to be the cheap ticket. You'll be surprised at what you can do with the junk left at goodwill or salvation army. If you need to powder coat smaller things (no larger than wheels) an old oven works nicely and a cheap but effective kit for such is available from jegs or summit.
One man's trash is truly another man's treasure.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #5 of 16 Old 02-24-2014, 08:07 AM
athos76
I used to have an old stainless tub with a washing machine motor and heater attached. We could throw engine blocks in it and run it and it would automatically clean the parts using the solvent cleaner... Simple design and held about 15 gallons of solvent.
2006 I6 6-Speed X, 33" Goodyear Duratrac, 8.8.
athos76 is offline
post #6 of 16 Old 02-25-2014, 12:33 PM
mike_dippert
mike_dippert's Avatar
Large, heated, ultrasonic cleaner.
mike_dippert is offline
post #7 of 16 Old 02-25-2014, 02:24 PM
thantos858
1974 CJ5
Those get rather expensive. I used a old washing machine outer drum with a pump from northern tool. I will probably add a heater soon as cold solution doesn't work as well. Biggest problem I had was a filter before the pump.
thantos858 is offline
post #8 of 16 Old 02-25-2014, 06:27 PM
athos76
Get a remote oil filter housing from Jegs and plumb it in. That's how my HF parts washer is set up
athos76 is offline
post #9 of 16 Old 02-25-2014, 06:35 PM
thantos858
1974 CJ5
I made one myself since I couldn't find one that fit. Old pair of nylons from the wife for a prefilter then a mesh filter from my fish tanks
post #10 of 16 Old 02-26-2014, 08:33 AM
athos76
Here is the kit I used. Just ignore the one adapter, and plumb this inline with the pump...we used fram extra duty filters with it. They would last about 2 months with almost constant use
http://www.jegs.com/i/JEGS+Performan...51715/10002/-1
athos76 is offline
post #11 of 16 Old 03-03-2014, 06:23 PM
82JeepCJ7
1982 CJ7
Mine works pretty good...
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #12 of 16 Old 03-13-2014, 12:21 AM
WSS
WSS's Avatar
1972 CJ5
google "parts tumbler", for more ideas. Hot water helps, does not need to be filtered. Use a heating element like in the dishwasher shown. Use a 20% solution of Zep's purple degreaser with water for a cleaning solution.
Just some ideas, you try it first LOL.
WSS is offline
post #13 of 16 Old 03-13-2014, 11:26 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I made a "parts tumbler" out of a Cement Mixer. Used it for knocking dross off plasma-cut parts. Worked okay but was loud as hell. I didn't like the way it dulled everything up and rounded corners.. So, it's sitting in the back yard collecting rust.
BESRK is offline
post #14 of 16 Old 03-15-2014, 04:25 PM
athos76
Eddie, what did you use for media in the tumbler? I have a similar setup at work and it uses Hershey's kiss sized ceramic pieces. It's so loud we put it on the opposite side of our lot and ran an extension cord to it.
athos76 is offline
post #15 of 16 Old 03-18-2014, 06:00 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I just tossed a few handfuls of small steel pieces in the tumbler.. about the size of marbles or so..
BESRK is offline
