Homebrew Trailer from an 8.25 - Page 2 - JeepForum.com
post #16 of 17 Old 08-02-2010, 12:02 PM
Netpackrat
Originally Posted by Bigbob View Post
I have never understood the idea behind using a vehicle differential for a trailer axle. Not that there is anything majorly wrong with it and to each his own and all that rot, but I figure if a differential is cheap enough to get from a junk yard it probably is indeed junk.
Usually you take the entire back end of the pickup truck it was taken from, including frame, springs, suspension, etc, and modify the front for a tongue. I couldn't imagine building a trailer from scratch around a vehicle axle, but I've used trailers made from the salvaged back end of a pickup truck, and they worked fine.
Netpackrat is offline
post #17 of 17 Old 08-03-2010, 08:08 AM
flatlander757
If you wanted to fab an axle yourself then spindles from an old D44 or front of a Ford Ranger plus some tubing wouldn't be too hard or expensive.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
8.25 , axle , backing plates , trailer , trailer build
homebrew snorkel johnny9 Fabrication Shop 7 08-12-2009 09:19 PM
Build Trailer Using Trailer House Axles?? jsc7002 Fabrication Shop 5 07-19-2009 06:43 PM
Homebrew Wrap-Around Cab Rag Top MikNov Fabrication Shop 7 06-17-2009 11:33 AM
homebrew comp cut? newtjrjrjr Fabrication Shop 9 12-04-2008 12:32 PM
Homebrew kit tjchad Tires & Wheels 3 02-27-2005 11:04 PM
