Homebrew Fiberglass Snorkel - Page 2 - JeepForum.com
post #16 of 57 Old 02-18-2010, 03:54 PM Thread Starter
02gixxersix
AWESOME resource!
06 LJ 6sp - 4" RC lift - XRC8 - 1" BL - 1" MML - 35s-Currie Steering - Spartan locker - SYE - MC UCA
02gixxersix is offline
post #17 of 57 Old 02-18-2010, 04:06 PM
MurdaJs
I agree, that post is getting a thumbs up just for that resource
Ive been thinking about a fiberglass snorkel for a while, with that write up ill be doing it within the next month
MurdaJs is offline
post #18 of 57 Old 02-18-2010, 04:07 PM Thread Starter
02gixxersix
I had never thought to use netting like that. I was going to shape foam or use 2x4. I still might use foam but I can make a much better outline with the netting first.
post #19 of 57 Old 02-25-2010, 03:00 PM
balzer
I have read that write up in the past and forgot about it. Pretty good, but I would have to take a little more time and make it look better for sure. I would imagine you could also (if well enough built) just leave the wire frame inside the snorkel for strength.
balzer is offline
post #20 of 57 Old 02-25-2010, 03:20 PM
sv16dan
Junior Member
looks like a good plan!
sv16dan is offline
post #21 of 57 Old 02-25-2010, 04:20 PM
oteps
1980 CJ5
fiberglass should work. you can make fiberglass shatter or just bend, depending on how much resin you use plus the type of fiberglass u use. I made a set of bodywork for my roadrace bike, it turned out ok but took a lot of time. Its thin and flexible, I havent crashed YET to try it out.
oteps is offline
post #22 of 57 Old 02-26-2010, 03:20 PM
ex m38a1er
Can't we just route the (custom)pipe through the vent grill and go sideways to the pass side and the then up next to the windshield?
Like that i won't be drilling the fender and there is no risk of bushing on the tree...
ex m38a1er is offline
post #23 of 57 Old 02-26-2010, 03:56 PM
CjAl
1980 CJ7
if you use the stock air box like ARB does and the snorkle goes from there then even if it does shatter the pieces will just go to the filter in the airbox
CjAl is offline
post #24 of 57 Old 02-27-2010, 09:19 PM
bamacpl
this may be a silly question, but what is the purpose of a snorkel on a vehicle?
bamacpl is offline
post #25 of 57 Old 02-28-2010, 10:47 AM
southtxdstroyer
high water crossings
it brings the air intake up a little higher so you dont risk sucking in splashed water
another benefit is when you pull air in from outside of the engine bay, its a lot cooler and kinda helps the efficiency of the engine
Whoever appeals to the law against his fellow man is either a fool or a coward.
Whoever cannot take care of himself without that law is both.
For a wounded man shall say to his assailant, 'If I live, I will kill you. If I die, You are forgiven.'
Such is the rule of honor.
open your eyes
southtxdstroyer is offline
post #26 of 57 Old 02-28-2010, 10:50 AM
Totallymetal
If you are talking about the vent in front of the windshield. That provides air to your ventilation system, don't think I would mess with it.
2007 JK Rubicon
5.5 Rock Krawler X-factor lift w/37 x 12.5 x 17 BFG KM2s, 5.13 Superior gears
Warn Powerplant HD
Totallymetal is offline
post #27 of 57 Old 02-28-2010, 10:53 AM
southtxdstroyer
a few guys have routed their snorkel through the cowl
do a search for hummer snorkel and you will find a great thread on how to do it
it does involve cutting your firewall and cowl though
i really like the way the hummer snorkel looks and if i ever go that far, that is the one i will do
open your eyes
post #28 of 57 Old 09-16-2010, 09:17 AM
ex m38a1er
Any updates???????????
" H TAN , H EΠI TAΣ"
'WHO DARES,WINS'
post #29 of 57 Old 09-16-2010, 05:15 PM
ImpactFabWorks
Well I am a little late and maybe he you don't plan on it now but, I actually make molds for an intake company on the side. The key is to have a nice well made plug, grab some wood and bondo and make something that looks good and will function the way you want. Just make sure the inside is large enough to flow enough air. If the air has to flow in a restricted area it starts to tumble and gets rough enough to make a rather large impact on performance. it sounds like you know how to work with fiberglass but, have you ever made a mold before?
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #30 of 57 Old 09-17-2010, 01:58 AM
ex m38a1er
Personally i was thinking of using a piece of styrofoam,form it the way i like it,fiberglass it and then use some kind of solvent to melt the styrofoam from the inside of the formed tube...
'WHO DARES,WINS'
homebrew snorkel johnny9 Fabrication Shop 7 08-12-2009 09:19 PM
Homebrew Wrap-Around Cab Rag Top MikNov Fabrication Shop 7 06-17-2009 11:33 AM
Another Homebrew Snorkle thread John_Wayne Fabrication Shop 2 06-04-2009 05:32 PM
homebrew comp cut? newtjrjrjr Fabrication Shop 9 12-04-2008 12:32 PM
Homebrew kit tjchad Tires & Wheels 3 02-27-2005 11:04 PM
