Quantcast Home-made press brake - JeepForum.com
Jeep Home Jeep Forum Jeep Classifieds Jeep Registry JeepSpace Jeep Reviews Jeep Gallery Jeep Blogs Jeep Clubs Jeep Groups Jeep Videos Jeep Events Jeep Articles
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Home-made press brake
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineONBOARD-AIR.COM: Economy OBA System**Best prices on Yukon Axle & Gears**
JeepForum Membership Drive - Reduced Premium Membership For a Short Time Only
Old 03-22-2009, 02:29 AM   #1
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
I had some things to bend and didn't want to spend the money having someone else bend them so I made a press brake out of some scrap. I wasn't sure how well it was going to work so I made it fairly short; figured I could use it for brackets, etc.
Here's the bottom portion. The bottom plate is 3/16", the angle iron is 2" x 1/4" and the sides are 3/8".
And here's the top. Angle is the same 2" x 1/4" but you can see I filled about half of it in with the MIG, not sure if it was necessary but I got to practice on multiple passes! The top (flat) piece is 3/16" and the round part is a 1 1/2" x 3" galvanized nipple; it's all I could find at the store that would work.
Here it is attached to the press. The bungee cord simply holds the upper piece to the press so it doesn't fall off.
And here's a series of pictures while bending some 3/16" plate. This is actually the second piece I bent and in the last pic you can see it's about 92 deg. (vs. 90). I stopped pulling the handle on the first one right when it bottomed out and it was a perfect 90 degrees; on the second one I gave it a few more tugs and it went past 90 a little bit.
I also bent a piece of 1/4" and a piece of 3/8". The 1/4" I bent all the way to 90 deg. but the 3/8" I only bent about 10 deg. I'm sure it will get close to 90 deg. on the 3/8" but for some reason I stopped and moved on to the boatsides.
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is offline   Reply With Quote
Old 03-22-2009, 02:36 AM   #2
ChiliPalmer
Bacon Ends & Pieces
This is what I really wanted to bend - my XJ boat sides! I'll start a thread dedicated to them but thought I'd throw some pics in here too.
Here's where I started today. 1/4" plate both vertically and horizontally
Fitting the frame end of the slider...
After scoring it...
In the middle of the first pass through the press...it took 4 passes through the press!
Right on the money!
Test fitting it after the bend...
Welding up the scoring seam...
Good penetration on the weld...
Now I just need to trim it up and weld away. When it's all said and done it will be welded to the frame stiffeners (3" x 3/16" angle plug and stitch welded to the uni-rails), welded to the bottom of the vertical piece of 1/4" and welded at the top to the outside of the horizontal 1/4".
The worst part is I'm going on vacation and won't be able to work on it for a week!
Feel free to critique away...
P.s. - Here's a link to all my build pics - the boatsides begin on page 3. Clicky
Old 03-22-2009, 06:32 AM   #3
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I hate you only because of the press you have.
Very nice work man.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 03-22-2009, 08:21 AM   #4
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Cool.. I've got something similar except I just used a sharpened piece of 1/2" thick plate for the top "knife".
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 03-22-2009, 08:38 AM   #5
jason m
run a pass of hard face down the edege and it will last for ever, that's what i did years ago.
to the OP looks great, keep up the good work.
jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
jason m is offline   Reply With Quote
Old 03-22-2009, 08:56 AM   #6
TSEJEEPERS
Sweet!
Good idea thanks!
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list. www.mijc.org
TSEJEEPERS is offline   Reply With Quote
Old 03-22-2009, 09:54 AM   #7
Unlimited04
Unlimited04's Avatar
great idea, nice work!
Unlimited04 is offline   Reply With Quote
Old 03-22-2009, 12:59 PM   #8
ChiliPalmer
Bacon Ends & Pieces
Thanks for all the props...
I thought about going that route also but with 1" (I don't have any 1/2") but I decided I didn't want to do all that grinding!
Old 03-22-2009, 03:58 PM   #9
Slawth
Slawth's Avatar
1978 CJ5
Nice work and great use of scrap, Chili. I can't wait to see the finished boatsides...
The End
Slawth is offline   Reply With Quote
Old 03-22-2009, 05:40 PM   #10
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I'm almost tempted to try and make my own 60"-100ton brake. Something that could do a 90 in 60" of 3/16". Do the basic frame out of 1" plate and make it to accept standard brake dies. If I ever do something like that, I'll do a detailed writeup to include pics of my probable ambulance ride to the hospital..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Old 03-22-2009, 06:55 PM   #11
Dogman
Nice, I'm glad you went that route rather than having someone else bend it. That should come in handy when it's time for me to make some brackets
Dogman is offline   Reply With Quote
Old 03-22-2009, 08:25 PM   #12
spd500
What size press are you guys using for this ? I am interested in setting something similar up , but i am not sure my press caqn take it . Also , what did you use to score the steel where it is to be bent ?
spd500 is offline   Reply With Quote
Old 03-22-2009, 11:28 PM   #13
ChiliPalmer
Bacon Ends & Pieces
Very nice work man.
LOL - missed this the first time through! The press was one of the first "big" tools I bought when I got into Jeeping. Waited for a 20% off coupon from HF and bought it when it was on sale. I think I paid $150'sh...
Thanks and here's some more pics of the boatsides...The vertical piece of 1/4" has 15 bolts going into the body and the horizontal piece has 6. Most of the forces will be applied to the vertical piece, plus the part of the body the top piece bolts to is only 22 gauge sheet metal - the bolts are really only there to help hold the body to the slider, the bulk of the strength is in the vertical piece. Also; the slider itself will be welded to the frame stiffeners so it won't be going anywhere.
Here you can see the substructure I built out of 1/4"...
And here it is all welded up...
I'm almost tempted to try and make my own 60"-100ton brake. Something that could do a 90 in 60" of 3/16". Do the basic frame out of 1" plate and make it to accept standard brake dies. If I ever do something like that, I'll do a detailed writeup to include pics of my probably ambulance ride to the hospital..
LOL - that would be one hell of a press to build - looking forward to it!
Me too, saved about $70 and it wasn't really that hard actually. Had my neighbor help me run it through the press, all in all it took about 45 minutes to get it just right - scoring, bending, re-scoring, bending, final "adjustment" (wood 2" x 4" and sledge hammer )
Let me know when you need to make brackets...
It's a 20 ton Harbor Freight press and I used a standard 4.5" grinder with a .045 cut-off wheel. It actually would've been easier if I used a thicker cut-off wheel. With the narrow wheel I had to go back and re-score it after the first bend because the sides of the line were beginning to touch each other. Wasn't too bad, just a quick run down with the cut-off again and it was good to go!
One thing I did learn is you don't have to keep your movements to the length of the brake, i.e. my brake is about 6" long but when I moved from one bend to the next I moved the steel about 12-16 inches, if you only move 6 inches at a time the steel will bend about 6" on either side of the brake also; which isn't a bad thing in the beginning but once you're working on your final angle it will mess things up - hence the final adjustment with the sledge and wood 2" x 4".
EDIT: When I get back from vacation I'll start a write up on the whole Jeep. I have one somewhere but it's seriously outdated...
Old 03-23-2009, 06:27 AM   #14
spd500
We have a break at the shop , so I do most of my bending there . But it would be nice to get a decent press for at home , and sometimes it would be nice to bend a few pieces at home . I have a new sheet of steel waiting for me to get the time to start cutting and bending it up to build a center console for my YJ , but have not had any time lately .
Old 03-23-2009, 11:12 AM   #15
skullver
Tarpitz
1991 XJ Cherokee
cool deal! Looks similar to the one I made:
nice work on the boatsides as well
Blah blah blah blah.
my Jeepspeed build thread:
http://www.jeepforum.com/forum/f37/dez-racer-xj-build-367176/
skullver is offline   Reply With Quote
Glock Forum
