Home Made Flat TC Skid Write Up (W/ pictures)
#61 | |
Texair - Yes I used a 1" MML. The only drawings I used were the ones scotch740 posted. To get the shape of the new skid I sat the factoy skid on it and traced it onto the 1/4" plate. We did a test fitting and saw that the skid was on the transmission pan, so we pulled it out and notched the skid. I beveled the holes with a 5/8" drill bit and test fit each bolt until I was happy with the fit.
#62 |
Cool!!!!!! That´s exectly what im looking for...!!!
How much BL do you have? Do you know if this would work with the 4spd auto tranny? It has a real deep oil pan.
2.5" OME & 2" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer 35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA 12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan Jeep TJ Runicon Pics www.timbercrawler.de |
#63 |
I made mine to work with the 42RLE. It has performed flawlessly at the local club grounds and Moab.
#64 |
Join a 4x4 Club
It only has to be lower in the middle. Were 1" spacers part of your design? How low does this skid make the center compared to the old one? Seems to me would have been better to build in a normal curve to the new plate to eliminate the need for spacers. Spacers always seem tacky to me, a temp fix.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct. Member and Web guy: New Mexico 4 Wheelers |
#65 |
I like your skid. Any reason why you didn't put the 5/16" on the top side leaving the bottom completely flat? That was the thought I had when thinking of how to counter-sink the bolts.
#66 |
what is the stock length, thread count and bolt size for the t-case skid? I need to buy some grade 8s that are 1" longer.
I'm making a t-case drop just in case I get vibes when I install my 2.5" OME (already have a TT, so driveshaft will see ~4.5-5" lift). I can't pull a t-case bolt out at the moment tho.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#67 |
Brace the top with angle iron like the last one posted. I had a 1/4 plate with no angle and it bowed right away. Went to a 3/8 plate with angle across the top and still bent it but it took landing a 5' wheelstand on a concrete pipe to do it. That plate is in my friend's Jeep now.
I gave up on using a plate and now build a simple substructure out of .120 dom tube and skin it with aluminum/uhmw. It ends up weighing a little less, easy to fab and service and is a lot stronger. It's easy to tie to the motor mounts too. |
#68 | |
PM sent, would like to see a writeup or at least a picture or 10 on this approach.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift 84 CJ7; frame off restoration in progress. The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice. |
#69 | |
Man that is very cool !! Greatly done ~ something anyone can do !! ![]() ![]() WOW.. reviving an old thread.. only 6 months to last post !! Last edited by prd_cdn; 09-29-2009 at 11:43 PM.. Reason: Poor Taste.. |
#70 |
This is cool, prolly gonna do it. Maybe I won't need an SYE. I have 5 " of lift with no SYE now with minimal vib's and stock wheel base. My thinking on not needing a SYE is that I am stretching my wheel base 15" to the rear. Thoughts?
#71 |
how much did your project cost ?
#72 |
you need a SYE. i'm surprised your driveshaft hasn't fallen out.
#73 |
his is totally custom.............the only 1996 TJ on the planet, so maybe its different????
01 TJ Sahara 4"short arm/rear gas&tire carrier bumper/front winch bumper winch/detroitEzhttp://i73.photobucket.com/albums/i225/FLATFENDER54/Off%20raod%20trip%20to%20Colorado%20with%20son%20a nd%20dad/DSC01873.jpg 66 Chevelle(Not a good pic in shed 4 many years)http://i73.photobucket.com/albums/i225/FLATFENDER54/memeorystick512262.jpg 93 ford lighting-trick flow heads 6 psi supercharger http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01636.jpg 1954 WILLYS CJ3B (under construction) http://i73.photobucket.com/albums/i225/FLATFENDER54/DSC01301.jpg 99 escort zx-2 my favorite lil gas "sipper" (who cares)lol USMC "Semper Fidelis" |
#74 |
where did all the pics go???
#75 |
i have 4 inches of lift and 35,s and no sye..took a couple yrs but found out this weekend why we need a sye..broke the t.case shift fork from where the slip yoke jammed the nose cone on a few big bounces up a hill and ripped a u-joint in peices..but im building it smarter now..
great write up here for sure also
JACK OF ALL TRADES,,,MASTER OF NONE fla cracker head born and bred build- http://www.jeepforum.com/forum/f22/punishers-ezgo-build-thread-1065655/ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
