home made flat fenders(aluminum) - JeepForum.com
post #1 of 4 Old 09-09-2013, 03:37 PM Thread Starter
zboss86
Anybody made any flat fenders out of aluminum? I feel pretty comfortable about being able to make them except that I've never bent any aluminum tubing. I'm curious if the JD2 will bend aluminum tubing as well as the mild and chromoly tubing...
Guess I need to call the company up and check before I waist any money on tubing... I'm thinking 1.5"OD x x.120 or .188 thickness
Cleaning out the garage... check what I have for sale here:
http://midsouthjeeps.com/forum/index.php?/topic/20693-jeep-parts-for-saletradebumper-2-spacers-relocation-brackets/
zboss86 is offline
post #2 of 4 Old 09-09-2013, 07:38 PM
tjcj
It will bend it I used mine to make some rub rails for my aluminum sliders. I've used it at work to make aluminum handrails for stairs also.
Sent from my XT881freeze ray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is online now
post #3 of 4 Old 09-30-2013, 02:07 PM
jaspepp
The important part about bending aluminum is the temper of the material. The most common aluminum round tube is 6061-t6511. Which is a 60 series alloy with a t6 temper and artificially aged. In a nut shell, it doesn't want to bend. If you anneal it first (heat then quench in water for aluminum). I will bend well but will no longer have the temper which gives aluminum it's strength and rigidity. I've seen some people get away with bending 6061, but I'm sure if you to a microscope to it you would see lots of tears/cracks. 6063-t5 is what tends to be more readily available and can be bent. It IS considered an architectural alloy, but for tube fenders it will be just fine. That's how I made mine and they have held up well. Haven't bounced them off many rocks yet though. The weight savings are awesome, but they will NEVER hold up to rash like steel ones do. Have fun!!! Aluminum is a blast to work with
"Idaho sucks!!!! Tell California"
jaspepp is offline
post #4 of 4 Old 10-02-2013, 01:40 AM
fratis
fratis's Avatar
Good info above. I have bent 1.25" sched 40 Aluminum 6061-t6 (speedrail) in my protools bender. Was only doing slight bends and not 90*. The first one went fine. The second bend snapped before I got it very far. I forgot to buff the aluminum clean and the oxidation made it bind in the bender.
-insert meaningless out-of-place political diatribe-
fratis is offline
