home fab roof rack idea..... - JeepForum.com
post #1 of 20 Old 04-27-2007, 01:36 PM Thread Starter
jclaudii
I have been looking everywhere for a roof rack similar to the older kargo master congo cage for the TJ but have yet to find anything used in my area. So I am contemplating building/making one from scratch. I want to run my idea by you and obtain feedback on if the material/method will work.
Okay as for the look, it would look almost just like the congo cage, be hingable in the back where the tail lights are, and bolt to the windshield pillar bolts.
Mounting up front, I thought about using a pair of windshield light mounts to do the front hoop with.
Mounting in the rear would be basic flat stock welded to gether with a suspension busihing to reduce the chance of noise in the tilt joint.
The material I propose to use would be standard "black pipe" steel from the plumbing section in any hardware store mainly used for natural gas plumbing.
Method:
I am assuming the little crappy pipe benders you see that are bottle jacks are made to bend this type of pipe. By this type I mean small o.d. pipe or conduit that is steel and can be welded.
I would start by making a front hoop by bending two thiry degree bends in some say 3/4 to 1 inch black pipe and then weld that to the light tabs on the windshield mounts.
I would then start on the back and make a plate that is the same size as the tail light housing but about a half inch tall on the top side. Weld another 2 inch steel plate that goes horizontal to get it away from the body some and then weld in my bushing.
The above would sint on the bushing (similar to a shackle) and I would then make the rear hoop in a similar way that I made the front. I would then weld two straight bars to the rear bar and I would bolt it in the front.
The purpose of this rack is to huall two rec kayacks about 40 lbs each. I would also like it to be able to support some additonal gear. All in all I would be happy with a 250 lb capacity.
My concerns for this project are mainly the gas pipe and how in the hell to bend it. I can weld in guesstets in the bends to make it strongerif I need too. I have heard that using the bottle jack benders will basically "rip" a hole in the pipe when it bends because of the type of steel it is made out of and it's thickness. I would not think a 30 degree would "rip" the pipe, but it will pull away some of the material making it weaker in the bend. I have also heard it is easy to crush pipe with this type of bender. Any info on actual use of this style bender will be greatly appreciated.
I'm working on a sketch-up design, but it won't help much because it looks so much like the cargo master. Please help me out with some feedback I appreciate it.
here are a few images of what I want it to look like. The only difference is that the windshield is going to be slopped instead of straight as it looks in the design. I appreciate everyone's feedback and suggestions. Thank you!
Top View
rear corner
front corner
jclaudii is online now
post #2 of 20 Old 04-28-2007, 09:48 AM
Scotch740
Scotch740's Avatar
Looks good, what program did you use for that? I am gona have to design a rack to carry canoes.
Scotch740 is offline
post #3 of 20 Old 04-28-2007, 02:01 PM
sentinal02
H2 Recovery Team Member
sentinal02's Avatar
250 lbs isn't a whole lot and black pipe is heavy. even 1/2" schedule 40 has an OD of about .8 and walls close to 1/8". you're talking about close to 1 lb/foot of material. i would look into something like 3/4" dia, 1/16" wall round tube. weighs less than .5 lb/ft and you would probably be able to bend it with an EMT bender fairly easily. it should easily stand up to 250 lbs.
RIP: '88 YJ 2.5L Ax-5 NP231
Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front.
92 YJ 4.0L Ax-15 231
5" springs, 1" shackle 31's or 35's depending on my mood
sentinal02 is offline
post #4 of 20 Old 04-30-2007, 11:44 AM Thread Starter
jclaudii
The program I used is called sketch-up and it is free by Google. I have downloaded some extra librarys for it. Just play around with the tutorial some and it is fairly easy to crate something. The libray I got was the Mechanical libray wich has the correct sizes for all things like pipe, washers, spacers, bolts, and nuts.
I did not know black pipe was that heavy. I will look at it further when I am at the hardware store. I'll be back
post #5 of 20 Old 05-14-2007, 03:13 PM Thread Starter
jclaudii
I have been thinking more and more about building my rack. I am wondering if I was to cut round tube half way with my grinder and then bend it over and weld it what would it look like and would it be very sound? I know you can do this with square tube because all the corners align. I have called all the rental places around and no one rents a tube or pipe bender. We have a dragway and a dirt circle track, you figure one of these rental places would keep a bender on hand. Another option would be to just heat the pipe and bend it (they rent torches). I think I may go with around 1/2 inch pipe because it's cheap enough and plenty strong for a rack.
As for the windshield mounts, how would I bend them to the contours of the windshield? I'm guessing I put it over something similar and beat it with a hammer (using a block of wood so I don't dent it all up).
The cheapest used rack I have found so far is a used cargo master and it would be 300 bucks shipped to me. a new one from quadratec is 279+shipping which comes out to be about 320 bucks. How I wish there was someone close to me in the arkansas river valley area that I could visit and help them out if I could borrow a few specialized tools.
To be continued....
post #6 of 20 Old 05-14-2007, 04:14 PM
sentinal02
sentinal02's Avatar
To be continued....
if you're using pipe, why not just pick up an industrial supply cat and get some weld in fittings for most of the bends. ie 90 elbow for the corners, T's, etc. easier and cheaper than buying a bender. then you just have to worry about 2 or 3 bends instead of 20.
post #7 of 20 Old 05-29-2007, 04:02 PM Thread Starter
jclaudii
I guess that would work but I was hoping for a few bends and a few welds and be done with it. I'm looking around locally trying to find a bender to borrow. I figure I can either go to that location pay a few bucks and either do it myself or get some hehlp doing it and weld it up at home or just do it all there and pay one fee. The other option is to find a place to rent a bender. Finding a bender to rent is like finding water in the desert, no one has it. I'm not giving up yet.
Wife informed me she wants it to be able to flip over similar to the daves rack. I'm trying to work out a design that won't be noisy and have lots of moving parts to rust. I'll keep everyone posted.
post #8 of 20 Old 07-24-2007, 11:01 AM Thread Starter
jclaudii
Long time No Update
I have gotten another idea to hopefully get rid of the problem finding someone to bend some pipe for me.
I was looking at the Garvin Wilderness rack and it is a nice rack. It stands out because it is built out of square tube. I was wondering what size square tube it was built out of and if there are any cons on using square tube? I was also wondering a ball park price. After looking on the internet it seems a36(hotrolled) is the way to go, but I don't know what size. I am guessing 1 inch should be fine but I don't know what the size of ID that Garvin uses either.
I also think square will be easy to make a bend that is decent looking. Much like how the Wilderness Rack is made, I will just use my cut off grinder and notch the tube and bend it and reweld it. This should look decent and be strong.
Please let me know of any flaws you see in my "new" idea. Thanks
Jason
post #9 of 20 Old 07-27-2007, 02:35 PM Thread Starter
jclaudii
Okay, it looks like this will work. I called Garvin and asked what size tube they used and they use 3/4 inch 16 gauge .065. I called my local steel yard and that same tube is only $.39 per foot so 20 foot of pipe will run me roughly 8 bucks. I'm going to measure later today how many feet i think I may need and round up a little.
To make the bends I'll just use my grinders cut off wheel and cut the tube on 3 sides and grind what I need to make my angle and re-weld. I don't think I'm going to make a basket yet, but I am going to make mine lower profile than the Garvin one.
So far here is my price sheet
40' of tube..........................$16.00
2' of 1/4 x2.5" plate............$ 3.00
Grinding disks.....................$ 8.00
Welding wire......................$15.00
Hardware...........................$10.00
Paint(and supplies)............$12.00
Total $64.00
64 bucks isn't a bad investment in a rack to haul kayaks
Does it looked like I missed anything I would appreciate some feedback. I'll be using a gasless MIG that I will borrow from a friend.
Thanks for the help.
post #10 of 20 Old 07-27-2007, 04:19 PM
HumanWaffleIron
cool, let us see it when you finish....I think a cargo rack for my back seat area is next...you gave me some new ideas...steel is a little more here is guess, but thanks for the info...good luck
Mine - 98' TJ Black 4.0 IL6 ~ Home Made cargo-rack and rocker guards, 1" BL, with a 3" Full Traction Lift on the way and 33s to follow.
Hers - 01' TJ Black 4.0 IL6 ~ 2.25" BB with Skyjacker Hydros, 32X11.5X15 BFG MTRs too come soon.
HumanWaffleIron is offline
post #11 of 20 Old 07-28-2007, 09:09 AM
Volusiaguy
1995 XJ Cherokee
bump to the top. Can't wait to see what you've done.
Volusiaguy is offline
post #12 of 20 Old 07-28-2007, 11:14 AM
kencaz
I think grinding it and re-welding will give to harsh a bend and the top of the pipe will flatten out. I would do it like this:
for the front posts you could probably get buy with only a single piece cut to the correct angle on both sides...
KC
"I say we dust-off and nuke the site from orbit... It's the only way to be sure!"
kencaz is offline
post #13 of 20 Old 07-29-2007, 12:23 PM
extreme69
1990 XJ Cherokee
if you dont plan on smashing it up why not aluminum
extreme69 is offline
post #14 of 20 Old 07-29-2007, 05:01 PM Thread Starter
jclaudii
kencaz that is what I plan to do to make my bend look nice. As far as using alum. I would love to, but I don't have a welder I have access to in order to weld aluminum. I'm working on taking some measurements. If anyone wants to take measurements of a existing Wilderness rack that would be great. I'll keep you updated.
post #15 of 20 Old 01-09-2008, 03:27 PM Thread Starter
jclaudii
Quick question is there any advantage to using square tube (.75 @ 0.065) by it being positioned as a diamond rather than square? I'm guessing it may help with it flexing up and down some, but not much.
seat rack fab idea... HELP! BlueXJ00 Fabrication Shop 0 06-23-2009 11:40 PM
Roof Rack XJ95mlake Fabrication Shop 1 04-06-2006 11:13 PM
what do you think of this roof rack? twardozrally Fabrication Shop 2 04-29-2005 10:37 AM
home made roof rack surfsmeller Fabrication Shop 1 05-08-2004 11:42 PM
