Home Built Muffler? - Page 2 - JeepForum.com
post #16 of 43 Old 02-02-2014, 07:21 PM Thread Starter
underpowered
Bouncin' on a Budget
underpowered's Avatar
got started on this. doing 2 1/2" in/out. muffler case size is 8"x14"x4". case is 11ga, baffles are 16 ga. went heavy on the case as it will undoubtedly come into contact with rocks and other offroad hindrances.
here is a few possibly baffle setups i am thinking of.
1.
2.
3.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #17 of 43 Old 02-03-2014, 06:31 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I'm kind of liking the first one.. that splits the flow and forces it into the 2 side baffles. However, I have no idea how that would affect actual exhaust gas flow.. nor soundwaves.
Here's where a CNC Plasma Table would be nice. It would allow you to make those 1/2 tube shapes, and position/cut them precisely where you want them in the top/bottom of the case.. so you could plug weld them.
I'm really looking forward to seeing/hearing the final product
BESRK is offline
post #18 of 43 Old 02-03-2014, 12:55 PM
danielbuck
1946 CJ2
looks like a fun project!
danielbuck is offline
post #19 of 43 Old 02-03-2014, 03:20 PM Thread Starter
underpowered
the first one is what i originally had in mind before ever starting this project. the other 2 were just thinking physically since i had the parts in hand to see what other possibilities i could come up with.
And i am slowly but surely collecting parts for one. it is next on the big things to buy list. buying the plasma in the next couple months, already have a computer with up to date copies of Mach 3 and mastercam. it would certainly be much easier that way.
post #20 of 43 Old 02-04-2014, 04:27 PM Thread Starter
underpowered
possibly make it more of a true two chamber design.
thinking i am gonna roll with this setup and measure it all out and weld in place tomorrow.
post #21 of 43 Old 02-04-2014, 05:25 PM
tjcj
Nice idea. Just thinking out load here but couldn't you tack the shell of the muffler together with the baffles, then install it to hear it. If you don't like the sound cut the tacks and move around the baffles till you get the sound you wanted.
Sent from my XT881freeze ray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #22 of 43 Old 02-04-2014, 06:25 PM Thread Starter
underpowered
that is an option but it may not get a true sound unless the case is pretty well sealed and almost fully welded.. I do know i am going to install it with clamps before i weld it just to be sure it is what i want.
post #23 of 43 Old 02-04-2014, 07:44 PM
Lifted96ZJ
1973 CJ5
The first design looks the best to me. Looks a lot like the Imco one chambers before Cherry Bomb bought them
Build Thread
http://www.jeepforum.com/forum/f8/1973-cj5-trail-rig-hunting-rig-build-1403107/
Lifted96ZJ is offline
post #24 of 43 Old 02-11-2014, 04:51 PM Thread Starter
underpowered
well here they are. just gotta build the headers so that i can get these installed and see how they are gonna work out.
Baffle set up
Case
built a 2nd identical to the first and added a bit of High temp paint
post #25 of 43 Old 02-11-2014, 06:27 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Great job, can't wait to hear what they sound like.
87 YJ, TPI 5.7, 700R4, NP231, BDS 3.5" lift, 1" front & 5/8" rear boomerang shackles, Rubicon Dana 44 rear axle, 33" Goodyear Duratracs
My brake boster/master cylinder upgrade:
5.7YJ is offline
post #26 of 43 Old 02-11-2014, 07:53 PM
tjcj
Well those turned out nice.
tjcj is offline
post #27 of 43 Old 02-11-2014, 08:26 PM Thread Starter
underpowered
Thanks.
sadly it will probably be 2 weeks or so before i can hear them. Headers will be built next week, then it will probably be another week before i can get my hands on the exhaust bender to bend up the rest of the exhaust.
post #28 of 43 Old 02-11-2014, 08:29 PM
ltrail
1984 XJ Cherokee
This is pretty neat. I didn't have any good advice to add but interested in the idea for sure. I'd like to see how it sounds!
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #29 of 43 Old 02-11-2014, 09:56 PM
andrewmacc
I have a feeling they're gonna be freakin' loud. But if that's the goal, then perfect. The link I posted on the first page said his sounded like a deeper Flowmaster and flowed just as well on a flowmeter.
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #30 of 43 Old 02-12-2014, 07:23 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've been kind of wanting to build a Hot Rod sometime down the road.. maybe a rat rod of somesort. I will definately do my own mufflers now.. They can be loud.. as long as they eliminate the "cackle".
BESRK is offline
