Hole saw - JeepForum.com
post #1 of 10 Old 03-12-2013, 05:53 PM Thread Starter
leaky10
Hole saw
Can anyone recommend a 4 inch hole bit for a drill. I true a bi-metal bit and it ground a very shallow and ugly grove in my bumper.
leaky10 is offline
post #2 of 10 Old 03-12-2013, 07:35 PM
thantos858
1974 CJ5
What kind of material are you trying to drill through? The key is to go slow and use cutting oil if your going through thick metal. For a aftermarket bumper I personally would just torch the hole then grind it to clean it up.
thantos858 is offline
post #3 of 10 Old 03-12-2013, 11:46 PM
1222
RIP John
1222's Avatar
Just start with a sharp bi-metal hole saw. Drill a pilot hole first and then make a very shallow grove and stop. Add a liberal amount of cutting fluid (Rapid Tap is the best) in the grove and cut again going deeper. When it seems like itís not cutting then stop add more cutting fluid.
It will start to smoke but thatís normal. Do not over heat the hole saw or it will ruin it in quick order.
1222 is offline
post #4 of 10 Old 03-14-2013, 06:34 PM
cargo33
Ive used A LOT of hole saws forbmy work an wen u get up to the 4 inch size its tuff to cut a decent hole with them an they groove like u said. Like mentioned already go slow if yor guna used it otherwise id recomend a torch or plasma cutter for a hole that size
cargo33 is offline
post #5 of 10 Old 03-14-2013, 08:58 PM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
With a 4" saw doing what it has done, I would drill a 3/8" hole on the edge and use a saber/jig saw and finish cutting it out.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #6 of 10 Old 03-14-2013, 09:02 PM
cargo33
A saber saw would work an I totaly forgot a hand pumped hydrolic press would be the easiest. U maybe able to rent one at a tool rental store an that would b the easiest an make the cleanest hole asuming u could get it to fit in the spot yor trying to cut out.
cargo33 is offline
post #7 of 10 Old 03-17-2013, 09:21 AM
aguelzo89
1995 XJ Cherokee
I have found that my fathers RotoZip worked pretty good when cutting circular holes into metal. Might wanna look into that?
aguelzo89 is offline
post #8 of 10 Old 03-17-2013, 10:16 AM
thantos858
1974 CJ5
Biggest problem with a RotoZip type tool is the bits break if you force it at all plus the metal bits can get expensive.
post #9 of 10 Old 03-17-2013, 10:50 AM Thread Starter
leaky10
A lot of great info, probably should have include that I'm working with 3/16.
leaky10 is offline
post #10 of 10 Old 03-17-2013, 11:25 AM
schitzangiggles
King of Macastan
Oh then plasma cut it.
Or find a fab shop and see if they can do it fir you. I had to do it once or twice and it was @ $15 for both times IIRC.
any jeep clubs or farmers in your area?
http://www.jeepforum.com/forum/f346/
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
