Hints for MIG welding upside-down? - JeepForum.com
post #1 of 27 Old 09-05-2010, 08:22 AM Thread Starter
Jerry Bransford
Administrator
Jerry Bransford's Avatar
MIG welding upside-down (overhead) is something I normally try to avoid but I had to do more of it yesterday. My problem is that the puddle tends to run down, of course, leaving a big drip shape I have to grind off.
Is it just a matter of turning the voltage down a tad so it's not so hot? The same voltage/wire speed works fine when it's not upside-down.
Jerry Bransford is online now
post #2 of 27 Old 09-05-2010, 08:59 AM
Kettles
What is upside down? Do you mean Overhead?
I turn the voltage down on overhead typically, kind-of in-between vertical-up and horizontal position amounts.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #3 of 27 Old 09-05-2010, 12:11 PM
Ironworker709
Ironworker709's Avatar
I weld overhead at the same heat as a vertical or flat,you just have to kind of stay ahead of the puddle a tad more to let the puddle behind it cool before it drips...it's hard to get the same penetration on an overhead than any other position,so i actualy like to burn as hot as possible on overheads for a good burn in on the base metal.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #4 of 27 Old 09-05-2010, 04:34 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I keep the same heat/wire speed as horizontal.. I just move a little faster to keep the puddle from falling out.
BESRK is offline
post #5 of 27 Old 09-05-2010, 04:36 PM
g4x4xgeoff
same process, just move along quicker.
generally speaking however, when i have to weld overhead, and i have a choice, i stick it.
Originally Posted by Hurley91 View Post
I could be drunk, high, raped and almost dead.... and I could still recognize it.
g4x4xgeoff is offline
post #6 of 27 Old 09-05-2010, 05:51 PM
Bigbob
Bigbob's Avatar
Welding overhead can be tough. The tendency is to lower the amps so it don't run into your shirt sleeve. But actually you need to turn up the heat sometimes to get penetration. Liquid flows downhill and that is true with molten metal! Lay some wet cardboard over you bare feet if you weld that way!
Getting into the right position is key to get a good overhead weld. Sometimes that is hard to do.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #7 of 27 Old 09-05-2010, 05:59 PM
nitecop
X2 on what the others said.
Aslo get some scrap pieces (same thickness of course) and practice welding over head.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
post #8 of 27 Old 09-05-2010, 08:05 PM
CoryA
practice practice practice, we had to do stress tests in class with our gmaw overhead passes
just go a little faster than normal and like i said before, practice
grab yourself a vice grip and stick a piece of metal up in the air and just start running bead
CoryA is offline
post #9 of 27 Old 09-06-2010, 10:24 AM Thread Starter
Jerry Bransford
Administrator
Thanks guys, that was all really useful information.
post #10 of 27 Old 09-06-2010, 12:30 PM
flatlander757
When I was doing overhead welding under my Jeep for the build, I would throw a BUNCH of old beach towels over my arms/legs/everything(I need to get a welding blanket), and make SURE you have something over the TOP of your head and around your neck area... if you don't you'll find out quickly why
I suggest doubling up on the layers in your nether-regions as well... I've had one or two molten blobs get through and singe my boys. For that reason I also don't suggest welding while sitting "indian-style" like a 3rd grader overhead.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #11 of 27 Old 09-06-2010, 12:59 PM Thread Starter
Jerry Bransford
Administrator
Tell me about it, I was like "ooh" and "OOOH!" and "YOWSA!!" during Saturday's overhead welding session. I was wearing my welding jacket backwards, cap, etc. to cover me better but the slag was finding every little gap and hole including a few old burn holes in the jacket. My 'boys' have not yet been reached by the slag but it's probably only a matter of time.
post #12 of 27 Old 09-06-2010, 01:05 PM
maxwedge
Try get the right type of wire for it and it wont look like crap and will hold right as far as strength wrong wire is like using the wrong welding rod check into it.
maxwedge is offline
post #13 of 27 Old 09-06-2010, 05:36 PM
Ironworker709
Please Enlighten us on what special kind of wire is used for overhead welding that would be different using for horizontal ,vertical or any other...?
Never forget 9/11
Last edited by Ironworker709; 09-06-2010 at 06:59 PM. Reason: goofed on flat and horizontal..lol
post #14 of 27 Old 09-06-2010, 06:41 PM
wushaw
Rockin jeep
wushaw's Avatar
Originally Posted by ironworker709 View Post
please enlighten us on what special kind of wire is used for overhead welding that would be different using for horizontal ,flat or any other...?
x2
wushaw is offline
post #15 of 27 Old 09-08-2010, 07:08 PM
cleanslate
I used to be a mechanic on FedEx trailers and sometimes I was required to weld the braces from the landing legs to the steel cross support. Of course I was laying on my creeper looking up at where I needed to weld. They always looked like crap - droops, verry little penetration, etc... I talked to one of my co-workers one day do try to get some tips - he told me to turn the heat up a bunch, turn the speed down a little, pull not push, and move the gun at a pretty good speed. I tried it like that the next time and I got a nearly perfectly flat weld. Excelent penetration, no droops. That is what I would suggest for you to do. And, as mentioned before, practice.
cleanslate is offline
First welding projects: welding cart and rock sliders johnsoninc86 Fabrication Shop 13 12-11-2011 11:48 PM
232 Hints, Tips, ect. Psyker Engines & Drivetrain 1 08-27-2009 12:08 AM
can a amp be hung upside down? Warlord2 Audio, CB & Ham Radios, GPS, & Electrical 2 08-26-2007 05:36 PM
Welding - full penetration vs. welding both sides Matt in TN Fabrication Shop 11 01-21-2006 07:03 PM
Hints on removing c-clips from locker beachtaco General Jeep & Off-Road Equipment 2 04-27-2005 11:30 AM
