Hi-Lift jack installed on rollcage - Page 2 - JeepForum.com
post #16 of 20 Old 08-18-2003, 09:03 AM
FanAholic
FanAholic's Avatar
2007 MK Compass
barrow someone elses thats on the trail with you so you have more than one to make it more stable.
FanAholic is offline
post #17 of 20 Old 08-21-2003, 09:36 AM
k
Same thing but I used a garage door railing so the jack can rest on
Got a write-up and some more pics on my flickr account.
my jeep | 01 TJ Sport 4.0L I-6 auto - BFG MT/KM 32x11.50 - AR767 15x8 w/ 4" BS - 2" Tera 2T - DT Pre-Runner 8000 - Pioneer DEH-P6700MP - Adjustable Front Track Bar | 6" Xenon Flat Fender flares - JKS Quick Discos | soon: New shocks
Last edited by k; 04-25-2008 at 09:43 AM. Reason: Finally got the pic online in my flickr and the write-up back up :)
k is offline
post #18 of 20 Old 08-21-2003, 10:03 AM
GMagana
GMagana's Avatar
Not sure that this is gonna help at all, and now you got two jacks to worry about. I usually just have one person "man the jack" If someone who knows the hi-lift keeps tabs on it you'll be fine. Make sure it's on a stable surface, make sure it's not leaning, and keep a tight grip on the handle which should be locked up out of the way as soon as you stop lifting/lowering. The handle is what can be scary. You don't expect it to do anything. If the jack is leaning you "expect" it may fall so you fix that. The handle you think is your friend until it rips away from your hands and takes a swing at your face! Just exercise caution and don't leave it unattended.
George
2000 TJ
GMagana is offline
post #19 of 20 Old 09-11-2003, 09:37 AM
BluesMan
BluesMan's Avatar
Put the nut on, drill a hole through the threads and back the nut off to clean the threads. You can slip a lock on then.
BluesMan is offline
post #20 of 20 Old 09-28-2003, 07:48 PM
1bdyj
A guy I know got hit in the face by a High-Lift handle. the handle got away from him and smacked him in the cheek, The handle inbedded itself into his face almost flush. He shattered his cheekbone and almost lost an eye. Needless to say, he spent a long time in the hospital and went through alot of rehab. He's ok now....but doesn't go near a high-Lift any more! Whenever I use mine, I spray lube it real well b4 I try to jack anything up, especially the two pins that tend to get stuck.
89 YJ 454/TH350/D300/Rockwells/44 boggers/full cage/coils & links
83 FSJ Cherokee 360/727/208/44/20/33"mt's/chopped roof/cage
1bdyj is offline
Hi-Lift Jack Vs. Harborfreight Jack? itsayjthing18 General Jeep & Off-Road Equipment 14 01-01-2010 01:29 AM
Hi-Lift Jack TJ Unlimited General Jeep & Off-Road Equipment 11 10-03-2007 08:12 PM
Hi-Lift Jack Remoot General Jeep & Off-Road Equipment 10 04-06-2006 11:26 AM
Hi lift jack won't jack, need help? Bot General Jeep & Off-Road Equipment 13 04-03-2006 04:55 PM
Looking for a Hi Lift Jack SittingDuck General Jeep & Off-Road Equipment 24 11-27-2005 09:57 AM
