HF welder rewiring qustion - JeepForum.com
post #1 of 4 Old 03-20-2011, 02:02 PM Thread Starter
Yury
Hey guys
Just got a 90 amp welder from HF. It was 89 bucks I couldn't control myself. It's rather nice for small projects and once you put a decent wire in it lol. The only thing is I'm not crazy about the constant flow. I was wondering if there's a way to rewire the welder to only have current flow when the trigger is pressed. Anybody done this?
Thanks in advance
Yury
Home is where the couch is......
Yury is offline
post #2 of 4 Old 03-20-2011, 02:21 PM
Kettles
Originally Posted by Yury View Post
Hey guys
Thanks in advance
Yury
I wish I still had the transformer and lower half of my old 90amp HF welder to look at. I would guess the best way would be to wire some type of heavy duty solenoid into the power line, and tap into the trigger control wires to control the solenoid in adition to the wire feed motor.
I also know that the HF line of welders are quite popular to mod, being they are so cheap. You could try google searching "cold tip HF 90amp" or something like that.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #3 of 4 Old 03-20-2011, 02:23 PM Thread Starter
Yury
Originally Posted by Kettles
I wish I still had the transformer and lower half of my old 90amp HF welder to look at. I would guess the best way would be to wire some type of heavy duty solenoid into the power line, and tap into the trigger control wires to control the solenoid.
I was thinking something on the same line. Just don't know how to go about it safely.
Yury is offline
post #4 of 4 Old 03-21-2011, 12:24 PM
sherlocktk
Ok Guys here you go. This diagram is "scavanged" so it looks a little un-refined from my battery mig thread here.
You can see more diagrams so you can get the idea.
http://www.jeepforum.com/forum/f37/h...79/index2.html
As far as soleniod a constant duty 12v starter solenoid will work just fine. (29volts gets halved and looses 1.4 volts, so halved is 13.8 volts DC or so)
You also need a rectifier (I recommend around 5 amp+) and a capacitor. Just buy the biggest one you can find at radio shack and you will be fine. Probably about 5-6 dollars at radio shack
See attached diagram (that was slightly re-worked the capicator has nothing to do with the motor speed control)
sherlocktk is offline
