HF 14" cut off saw opinions - Page 2 - JeepForum.com
post #16 of 23 Old 11-05-2008, 08:34 PM
82Renegade
1982 CJ7
I've had that same HF model for a year or so now, and its held up well. As noted above, for anything more than angle or flat bar its not very accurate. Takes forever to get through anything thick, the grinder with a cutoff wheel is much faster.
82Renegade is offline
post #17 of 23 Old 11-06-2008, 10:06 AM Thread Starter
conrasm
conrasm's Avatar
Probably should have asked before buying, but like I said, I needed it pretty quickly didn't want to spend a lot on it, since I won't use it much.
I did use it yesteray to cut the 2" angle iron and it works OK. Once the saw gets up to speed, the blade has a slight wobble, so it ends up grinding out a fairly wide groove before it starts to cut. I did buy the "better" blade which I think is for a gas saw.
I found that if I just tap the switch a few times to get the wheel moving while it's on the metal, that alleviated the wobbling problem and my other cuts came out good. Thanks for the input. I'm sure it will sit in the bow for another year until I decide to do anything with it.
I got both supports welded up this morning and they turned out good.
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #18 of 23 Old 11-06-2008, 10:39 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by Whackmaster View Post
I love my plasma cutter.With a guide and steady hand you can make some nice cuts..
And that sells for how much?
Gone wheeling Friday through Sunday.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is offline
post #19 of 23 Old 11-06-2008, 02:09 PM
mountainpoo
1994 XJ Cherokee
i use a dewalt chop saw at work to cut duct frames. it cuts pretty straight.
1994 xj
RE 3.5 superflex/RE adjustable track bar
DT3000 shocks
cragar soft 8's 4" BS
31x10.5 R15 cooper discoverer stt's
homemade snorkel
mountainpoo is offline
post #20 of 23 Old 11-06-2008, 02:29 PM
Ski01xj
We had a Milwaukee chop saw when I worked in a fab shop. The blade would heat up quite a bit and would end up making the cuts uneven. Most of the time we could just tack them and weld over the gap. Also note that the stuff we were building was for industrial applications and most of it sat outside, so none of it had to be dead nuts square, like if you were building on your jeep or in your home.
Ski01xj is offline
post #21 of 23 Old 11-07-2008, 01:16 PM Thread Starter
conrasm
conrasm's Avatar
I was working on a supplemental counter top support that we're having a piece of granite installed on. When the guy came to template, he said the existing structure "would probably" be OK, but I wanted some extra insurance against a possible crack. I just cut it a hair long and ground it down. It doesn't have to be pretty or exact, since it will be covered with some wood molding.
The problem I was having with the blade wobbling seemed to be the actual blade and not the motor bearings (which it shouldn't be since the saw is new, but who knows with the quality "made in china" stuff you buy at HF. I thinking a higher quality blade might work better than the one the 4 year old chinese sweatshop employees made.
Shawn
conrasm is offline
post #22 of 23 Old 11-07-2008, 02:00 PM
design311
I made some rock sliders last week and I used my HF saw a lot. I must say, I hated cutting the 3/16" steel with it. It made very unpredictable cuts. The blade moves out away from the start of the cut very easily. I will be shopping for a better brand next year some time. Just my 2 pennies
05 Rubicon - 3.5" RE, Currie control arms, 1.25" JKS BL, 1" JKS BMML, 35" Xterrains, Ramsey Patriot 8000
1976 CJ7 ground up resto in progress...
Firefighters Jeep Club
design311 is offline
post #23 of 23 Old 11-07-2008, 06:11 PM
yellojeeper
My DeWalt seems to do the job.
1998 TJ
NRA Life Member
yellojeeper is offline
6.5" speaker opinions? barty Audio, CB & Ham Radios, GPS, & Electrical 4 12-17-2007 01:18 PM
2" Lift Opinions yobeez Tires & Wheels 8 07-03-2007 11:54 AM
opinions on YJ lifts (2" or so) RideRed04 Tires & Wheels 0 11-09-2003 03:14 PM
Opinions on Skyjacker 4.5" lift devestator_x Tires & Wheels 7 09-02-2003 11:59 AM
Your opinions on Rusty's 3" lift.... yaffy Tires & Wheels 6 02-28-2003 07:32 AM
