HF 14" cut off saw opinions - JeepForum.com
post #1 of 23 Old 11-05-2008, 04:20 AM Thread Starter
conrasm
conrasm's Avatar
I bought one of these yesterday to cut some angle iron for some counter top island supports that we're having granite installed on. Is thing any good or did I waste $70? It was on sale BTW, normaly $90. I kinda need to get this done by the end of this week, so I really can't wait for something by mail.
I didn't want to spend $150 at on a dewalt or hitachi for something I will only use a couple times a year if that.
http://www.harborfreight.com/cpi/cta...emnumber=44829
Shawn
'00 TJ Sahara (RC 4" LA kit)
'06 Grand Cherokee Limited
'07 Ram 1500 quad cab
conrasm is offline
post #2 of 23 Old 11-05-2008, 04:48 AM
540i
Had one for years and have used it allot. Don't know that a more expensive one would be any better at least for what I use it for.
540i is offline
post #3 of 23 Old 11-05-2008, 05:16 AM
yellojeeper
This Dewalt has 4.0 hp wheras the HF has 2.0 hp. I like more power.
http://www.dewalt.com/us/products/to...roductID=10604
1998 TJ
NRA Life Member
yellojeeper is offline
post #4 of 23 Old 11-05-2008, 05:23 AM
builder
I had one for 3 hours. I could cut straighter with my angle grider so I brought it back and bought a Milwaukee. Now I can make straight cuts
95 YJ
builder is offline
post #5 of 23 Old 11-05-2008, 06:51 AM
treky67
Got a miter saw, if so just throw a steel blade in there and giver, they work great if all your doing is cutting a little bit of pieces.
treky67 is offline
post #6 of 23 Old 11-05-2008, 07:40 AM
iamdurkee
sawzall.
iamdurkee is offline
post #7 of 23 Old 11-05-2008, 08:45 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
I don't have one, but I've been told that when you purchase a chop saw, to make sure there is no play back and forth with the blade when tightened down. That way you can get a strait cut.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #8 of 23 Old 11-05-2008, 08:50 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
don't force the saw through the steel, you'll burn up the bearings. go slow and let the saw nibble out the steel. this will help keep the cuts straight, but as the blade moves and produces friction it heats up, and heats up the metal (ALOT!), and it won't cut very straight. chop saws are good for rough work and quick cuts, but by no means should they be used to precision cuts. a sawzall or angle grinder will get you more precise cuts. don't forget to wear ear muffs, chop saws are really REALLY loud.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #9 of 23 Old 11-05-2008, 09:08 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
How could a sawzall or angle grinder give a straighter cut than a chop-saw?
Jerry Bransford is offline
post #10 of 23 Old 11-05-2008, 09:47 AM
BrandNew
oxy acetlene cutting torch alot faster and more fun!
Selling your tire carrier?! send me a PM i want it
BrandNew is offline
post #11 of 23 Old 11-05-2008, 09:48 AM
BrandNew
with a steady hand anything is possible
i use an angle grinder all the time, its basically the swiss army knife of my garage
BrandNew is offline
post #12 of 23 Old 11-05-2008, 10:14 AM
Unlimited04
a welding bench with a big 6" vise mounted to it, a steady hand, pipe-wrap, a soapstone and a keen eye.
the chop saw blade flexes A LOT when you're cutting. I made ALL my cuts on my roll cage with an angle grinder & cutting disc, almost every cut was perfectly flat or angled as needed. If you're cutting angle iron, or flat bar, a chop saw isn't too bad, but cutting tubing...you'll need to cut again with another tool because the blade flexes so much.
Useful Write-Ups:
Funny:
post #13 of 23 Old 11-05-2008, 10:41 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I have to disagree here. I have had my Rigid chop saw for a few months now and have NOT ONCE had to address a cut because it was not straight or messed up in anyway. I have cut DOM tubing, 1" and 2" square tubing, flat stock, angle iron, and even some plate.
I even used it to chop up my sport roll bar to add parts to my family bar. Once again, straight cuts exactly where I marked them to be.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #14 of 23 Old 11-05-2008, 10:53 AM
timatoe
timatoe's Avatar
Shouldn't you asked for opinions BEFORE you bought one? They have that one on sale for $49 quite often. I would think it'd work fine for a while. I've decided to stop buying cheap tools just to get by, so I try to buy a better quality tool when I need it now.
timatoe is offline
post #15 of 23 Old 11-05-2008, 03:07 PM
Whackmaster
I love my plasma cutter.With a guide and steady hand you can make some nice cuts..
Whackmaster is offline
6.5" speaker opinions? barty Audio, CB & Ham Radios, GPS, & Electrical 4 12-17-2007 01:18 PM
2" Lift Opinions yobeez Tires & Wheels 8 07-03-2007 11:54 AM
opinions on YJ lifts (2" or so) RideRed04 Tires & Wheels 0 11-09-2003 03:14 PM
Opinions on Skyjacker 4.5" lift devestator_x Tires & Wheels 7 09-02-2003 11:59 AM
Your opinions on Rusty's 3" lift.... yaffy Tires & Wheels 6 02-28-2003 07:32 AM
