HELP! Sway Bar Curiousty - JeepForum.com
post #1 of 6 Old 10-03-2011, 08:51 PM Thread Starter
Lil_Jeep_Guy
1992 XJ Cherokee
I am the new owner of a '92 Jeep Cherokee. I have not done much to it yet but do have some questions. 1 of my questions is what happens if i put longer sway bars on my Jeep?
Lil_Jeep_Guy is offline
post #2 of 6 Old 10-04-2011, 07:47 PM
kcaverly
Sorry I don't have an answer for you, but I'm curious as to why you would like to do this?
Kevin
1993 Jeep YJ - 350 Chevy TBI, SM465, NP241, 14B SF LSD, 10B
kcaverly is offline
post #3 of 6 Old 10-04-2011, 11:12 PM
dcope17
Longer anti-sway bar??????
I can see changing out for a lighter or stiffer one but length ultimately has very little to do with it...
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #4 of 6 Old 10-05-2011, 12:07 PM Thread Starter
Lil_Jeep_Guy
1992 XJ Cherokee
some 1 told me it gives thee jeep more of i lift but i found out different
post #5 of 6 Old 10-10-2011, 10:17 PM
Dbiked
It'll also potentally cause your sway bar to smash into the inner fender well.
Utah jeep crew member #32
Dbiked is offline
post #6 of 6 Old 10-11-2011, 12:47 PM
Kettles
You need longer swaybar endlinks in conjunction with a suspension lift. It prevents the upper busing setup from binding, or breaking. Generally for offroad use you don't want a sway bar so quick disconnects are used, that are longer than stock.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
cherokee , help needed , sway bar
Sway Bar Keifer General Jeep & Off-Road Equipment 1 09-29-2011 02:00 AM
Sway Bar??? 20Rubicon07 Engines & Drivetrain 1 10-23-2010 03:26 PM
Sway bar problem Wrangler11 Tires & Wheels 1 12-18-2006 09:50 AM
Sway bar ? beep_beep_jeep Street Jeep Forum 15 11-16-2006 07:09 AM
Sway Bar rsmnc Tires & Wheels 3 09-07-2001 11:46 AM
