Help me with my bumper..advice, opinions, comments & concerns. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Help me with my bumper..advice, opinions, comments & concerns.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineMemorial Day Sale at Under Cover Fabworks! 15% Discount oNOTCH CUSTOMS - Max Clearance Fender Flares
Unread 03-24-2012, 05:05 AM   #1
DezertXj88
1990 XJ Cherokee
So guys my Xj is on its way to be a mild ExPo vehicle. Its my DD, camping, fishing, ExPo rig..My original plan was to copy this here,
http://www.jeepforum.com/forum/f11/x...bumper-928227/
I hate big flashy bumpers..And I love hidden winchs. Clean, simple, lightweight and cheap.
Verus keeping the stock bumper, I pcked up a Warrior P# 560 bumper for 150 bones today with 2 new Hella 500 black magics on it. My idea is it will give more protection incase I needed to push something, or incase I bumped/hit something.
However when I went and picked it up I realized this bumper was not 3/16th like I was let to believe..its actually 3/16 bumper mounts and 1/8th formed bumper. So I'd like to beef up the Warrior a little because I do like it..ALOT, its got very very nice lines, matches well, just perfect in size and since I don't rock crawl or need to ram things..I think will a little added beef it'll do just fine!
Planning to reinforce it with 3/16 and do full bumper mounting/tie in brackets. Opinions on this? say 1/8th vs 3/16 reinforcement plates?
This is how it looks currently. Just 1/8 plate formed, completely hollow.
I want to add either 3/16 or 1/8 plates in it like this..
Full inserted into the bumper, and welded on both sides. Should I add gussets off the sides of these like the bumper mount idea? Or should I add in a plate to completely connect the 2 plates together?
For the corner, just add in a little gusset/brace..and one at the very bottom of the bumper.
And for the mounts, I'll be cutting the stock ones out and replacing them with full depth versions..they are currently 3/16, which is plenty strong, especially since I will be running the tie in brackets which have 9 bolts per side. However idk If I should do them like this, full depth and 2 gussets.
Or like this, full depth, 1/4" plate formed to bumper & 2 gussets
I was also curious on opinions/suggestion on Drings through the bumper. If I could, or it would be strong enough really...but run a Dring through the bumper, inbetween the 2 gussets, then weld it on the front of the bumper, weld it to the bumper mount and to the gussets?
The section inbetween the 2 bumper mounts will be untouched until the hidden winch comes, then I'll brace/cut & mod that to hide & hold a 12k Warn thats been sitting here.
Otherwise I'm basically looking for guidence, if my ideas good enough, if I should do something differently, add here or there, take away here or there? Whats your guys opinions, advice, suggestions?
Don't hate on my costco pizza board fab work
DezertXj88 is offline   Reply With Quote
Unread 03-24-2012, 06:44 PM   #2
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I think I would probably just box it in from the mounting plates outward. Even with those ribs, a hard bump on the ends is gonna fold them in.. buckling the upper/lower parts of the bumper. Box in and then gusset to the mounting plates.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 03-24-2012, 08:41 PM   #3
Abaddon
1995 XJ Cherokee
basicly do like the guy on CF was tring to say take some C channel and put it legs in and weld the legs to the bumper from the mounts out ward
it will box it in and kinda keep the weight down
Abaddon is offline   Reply With Quote
Unread 03-25-2012, 12:11 AM   #4
DezertXj88
1990 XJ Cherokee
Do you have a link possibly? I've been looking but have found much yet!
Unread 03-25-2012, 09:57 AM   #5
Spuznick242
I think your going at it too complicated but that's just me. Have you thought about making it into an oba storage tank for the compressed air. I'm making a front bumber for my YJ right now with a very similar design made out of .125 steel plate. Couldn't telll you much about making what you have stronger other than to add more metal to it, and I wouldn't go anything thicker than .125 if it isn't going to be seeing much action since its just useless weight. But since your going a similar route as me, I think the air tank is the way to go.
DD- 1995 YJ 2.5L, Cat delete, 19lb injectors, 30/9.5r15
Trail Rig- 1994 YJ 4.0L, Rubicon Express 4.5inch lift, 1inch body, D30 Aussie, 33/12.5/r15 Cooper Mud Terrains, front bumper, rocker guards
Spuznick242 is offline   Reply With Quote
Unread 03-25-2012, 10:31 AM   #6
RenoF250
I think I would get some 2x2" 3/8" wall square tube and weld it under the top flange. That would strengthen it quite a bit and be fairly easy. Probably weigh 30 pounds or so.
RenoF250 is offline   Reply With Quote
Unread 03-25-2012, 11:45 AM   #7
webdog
DirtBound Offroad
webdog's Avatar
1990 XJ Cherokee
x2
But I would use something a little stronger than cardboard!
webdog is offline   Reply With Quote
Unread 03-25-2012, 02:41 PM   #8
DezertXj88
1990 XJ Cherokee
Originally Posted by webdog View Post
x2
Max I may be calling you..your work is top notch and I still have that stuff sitting here..maybe trade it to beef this bumper up slightly? Pm coming.
For air storage, I'm actually doing 2x6 rockers. Both will hold air..if my welds don't leak
Unread 03-25-2012, 06:23 PM   #9
webdog
DirtBound Offroad
webdog's Avatar
1990 XJ Cherokee
sounds good, just let me know.
Unread 03-25-2012, 08:30 PM   #10
Spuznick242
Thats too much plumbing to do for both sides for air, I much rather just have one larger tank right up front close to my york and if anything just put a valve on each side near the front of the tire to tap into with a hose to fill up each side and easy of use for air tools.
Unread 03-25-2012, 08:55 PM   #11
DezertXj88
1990 XJ Cherokee
Ya didnt think of that...I'll probably use my passenger side as the air tank..using my sanden (sp?) for a compressor.
Unread 03-26-2012, 06:03 AM   #12
dodger889
With that compressor you will need to add an oiler, to keep the compressor alive. They are do not have their own oiling system in them.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline   Reply With Quote
Unread 03-26-2012, 07:01 PM   #13
Spuznick242
Best part of the York, its got a built in oiler and can be used with a higher rpm to make it fill faster, making a hand throttle my next upgrade after I hunt down my york.
Unread 03-27-2012, 01:58 PM   #14
dodger889
Well sorta a york compressor is just an modified engine with reed valves in the head. So it has a crank case with oil in it. So it does not have a built in oiler per-say.
Unread 03-27-2012, 04:16 PM   #15
Diamond-x
1991 XJ Cherokee
Here's what I did:
http://www.jeepforum.com/forum/f11/t...build-1157408/
Diamond-x is offline   Reply With Quote
