Help me figure out whats wrong with my welder - JeepForum.com
post #1 of 11 Old 03-27-2011, 09:18 PM Thread Starter
minesbetter
i have a millermatic dvi. i dont know much about it bc i just got it from my uncle. So today i was doing some work on building my bumper and i noticed the wire feed was surging instead of keeping a steady flow. then it wouldnt feed at all. then it would feed but not arc.
it started working again for like 5 minutes until i found a bird nest of wire inside. i pulled all the wire out and re fed new wire through. then the bird nest came back. can you guys help me out here? im hoping its not the gun bc i dont wanna spend 130 on a new one.
minesbetter is offline
post #2 of 11 Old 03-27-2011, 09:29 PM
Bama1987
How old is it? You may just need a liner my Lincoln acted odd like that when my liner was worn. Like 10$
Bama1987 is offline
post #3 of 11 Old 03-27-2011, 09:46 PM Thread Starter
minesbetter
idk how old it is but I would guess maybe 4-5 years? and thanks but what do u mean the liner?
post #4 of 11 Old 03-27-2011, 10:01 PM
Bama1987
If I'm not mistaken it is a mig. The liner on mine and should be similar on all mig set ups is a very tight spring looking, flexible tube that gets the wire from the box to the tip of the gun without binding or dragging( which may explain the surging). Mine had a kink and a little oxidation on the inside. Open up your box where the wire goes you should have two wheels that push the wire. Coil your gun lead relatively tight and pull the trigger. Watch the wheels if they keep spinning at a constant speed and the wire stops or slows. I would bet it's the liner. Take the gun off the box unscrew any retainer nuts that hold the liner in pull it out and put the new one in. Mine was pre lubed I'm not sure what kind you will need if not.
Bama1987 is offline
post #5 of 11 Old 03-27-2011, 10:22 PM Thread Starter
minesbetter
thanks alot man. I'll try it tomorrow. you might've just saved me 2 days worth of working
post #6 of 11 Old 03-28-2011, 12:42 AM
bruteboy
where was the birds nest?
if it was between the drive rollers and the liner,then a poor liner or incorrect size tip may be the problem.
if it was around the spool of wire,then you may need to adjust the spool tension(ie;increase drag)
bruteboy is offline
post #7 of 11 Old 03-28-2011, 08:15 AM Thread Starter
minesbetter
its between the drive rollers
post #8 of 11 Old 03-28-2011, 09:01 PM Thread Starter
minesbetter
ok i fixed it. sprayed wd40 into the tip. wire fed right through. theres really nothing it cant fix haha
post #9 of 11 Old 03-29-2011, 01:06 PM
Bama1987
Wd40 isn't an oil be careful with it cause it will dissolve the grease or whatever is supposed to be there and dry up there is a paste, I forget what it's called. But it comes in a tub like vasoline and you stick the tip in it to lube the wire coming through the tip. Man that sounded dirty.... But check into it, will be better for the welder than wd40
Bama1987 is offline
post #10 of 11 Old 03-29-2011, 04:24 PM
Kettles
Get a new tip if it is catching at the tip. They are "consumables" they are supposed to be disposable. If it has the wrong size tip on it (too small), it could cause that too. Also make sure your drive tension is proper, if the tension is set right the roller should slip on the wire instead of bunching it up in a ball; Your not supposed to crank down the tension.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #11 of 11 Old 03-29-2011, 07:11 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I change tips out with about every roll of wire (30lb rolls). I also use alot of "Nozzle Dip" and scrape out the inside of the nozzle frequently..
Sometimes, if I feel like I boogered up a tip too soon, I'll remove the nozzle and lightly touch the end of the tip with a flap disk... just enough to clean it shiny.
BESRK is offline
whats wrong with my cb... Unii Audio, CB & Ham Radios, GPS, & Electrical 1 04-27-2010 03:55 PM
cant figure out whats wrong with engine konner Engines & Drivetrain 1 03-16-2010 09:54 PM
not sure whats wrong with the I6 lovesa02wj Engines & Drivetrain 2 07-25-2009 01:18 AM
whats wrong with my radio??? whitefiesta Audio, CB & Ham Radios, GPS, & Electrical 5 02-27-2009 04:19 AM
Is something wrong with my stick welder? Dogman Fabrication Shop 20 03-10-2008 01:06 AM
