Help me build this bumper - JeepForum.com
post #1 of 10 Old 02-08-2011, 09:13 AM Thread Starter
theblackjeep98
saw this crazy rear bumper for a jk. wanna build something similar to it for my TJ. How hard you guys think this would be. and any recommendations?
ITS SOOOO SEXYYY
UNCC MECHANICAL ENGINEERING TECHNOLOGY
MY JEEPS
98 TJ "mac" (5.2L v8 on 33's)
(Sold) 67 CJ5 "sheldon"
My V8 Swap Thread
theblackjeep98 is offline
post #2 of 10 Old 02-08-2011, 10:30 AM
muddy93
1987 FSJ Wagoneer
Those are not really considered "bumpers". It's just a fancy swing out tire carrier. Also worth noting, with that setup, sience it's only attached to the body, even though it dose appear to have armor, the force from any impact to that tire carrier is going to be transfered directly to the body.
At any rate, all that's really needed to build someting like that is, a tubing bender, and a welder. Things like a notcher and plasma cutter would make it easier, but you can do the same thing with a cut off wheel on a grinder, it'll just take more time.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
post #3 of 10 Old 02-09-2011, 05:27 PM
rinking
That is one sweet sum gun! I've been planning on making one similar to that real soon. Instead of the fancy, expensive heim joints, Im gonna use shackle bushings.
rinking is offline
post #4 of 10 Old 02-09-2011, 06:59 PM
jsc7002
1966 CJ5
IT loos pretty nice, but I would think that its adding a lot of pressure on the body, even though it looks like they tried to spread it out. The heims would be expensive too, I think your shackle bushings would be a good choice, it looks like it would swing out but it looks like they have bolts going through on all four mounts, so youd have to carry the wrenches for it too lol.
jsc7002 is offline
post #5 of 10 Old 02-09-2011, 07:03 PM
Hussler
1992 XJ Cherokee
I bet if you were to swing that carrier out all the way and put some downward force on it you would see the gap between the body and tailgate widen.
Looks neat but IMO, not the way to go.
Originally Posted by chris87xj View Post
Sometimes a restoration project is a labor of love, at which point cost, time, and labor involved become irrelevant.
Originally Posted by BorderC View Post
I see you also twizzled your scart lead. Well done! :thumbsup:
92 XJ with ARB's, 5" lift, too much armor, 33's and some other garbage
Hussler is offline
post #6 of 10 Old 02-09-2011, 10:12 PM Thread Starter
theblackjeep98
Well I do know the rear corners have either 1/8 or like 1/4 body armor so I suppose that would help?
MY JEEPS
My V8 Swap Thread
post #7 of 10 Old 02-09-2011, 10:16 PM
Hussler
1992 XJ Cherokee
Yes but you have to realize that armor is being held in place by SHEET METAL. Go check out the "carnage wrecks" section of JF, you will find that the armor tends to tear through what it was trying to protect when under immense amounts of stress
Hussler is offline
post #8 of 10 Old 02-09-2011, 10:19 PM Thread Starter
theblackjeep98
Yes but I wouldn't be running a 40 inch tire or anything. Would there be a way to reinforce it?
MY JEEPS
My V8 Swap Thread
post #9 of 10 Old 02-10-2011, 08:42 AM
mferrari
DelmarvaOffroad.com
mferrari's Avatar
Built something like that for my dodge a while back.
Michael Ferrari
Team 120 - DOR Racing - Racing for Operation Homefront
Operation Homefront (OHF) provides emergency financial and other assistance to the families of our service members and wounded warriors.
Thanks to our Sponsors:
Delmarva Offroad - F-O-A Shocks - BD Turnkey Engine - Under Cover Fab - Jer-C Transmissions - Quigley Driveshafts
Delmarva Offroad
You call it rolling, we call it R&D! 443-951-JEEP
mferrari is offline
post #10 of 10 Old 08-16-2011, 12:00 PM
aggiejon
1979 CJ7
Just build a simple tube rear bumper and mount the swing out to the corner of the bumper. you could attach it to the body or another post on the opposite end of the bumper. Just let the bumper transfer the weight to the frame rather than the tub. You could attach that style of swingout just as easily as the other swingout designs.
My $0.02, I have a CJ with the factory spare rack, mounted in two places only to the tub, and it has split the tub ahead of where it mounts. And the CJ tubs were much thicker metal than the new jeeps are. Move that weight to the frame. Regardless of the tire size.
All that said, that is a pretty cool setup. would make it hard to steal that spare if that was made to lock in the closed position.
aggiejon is offline
Another Bumper Build yellow85cj Fabrication Shop 29 12-20-2010 10:40 PM
bumper build underpowered Fabrication Shop 10 11-28-2010 05:23 AM
looking for a shop to build my bumper for my zj I have build plans FLboy4x4 Fabrication Shop 6 08-02-2010 08:56 AM
help with my bumper build youngjeepr Fabrication Shop 32 04-18-2010 04:05 PM
ZJ bumper build bamacpl Fabrication Shop 12 08-24-2009 10:21 AM
