Help With Cheap Homemade light bar! - Page 2 - JeepForum.com
post #16 of 21 Old 02-15-2011, 06:07 AM
zachsjeep
Running board
Originally Posted by mylittlecj5 View Post
here is mine...cheap, too! (might need to zoom in to see it)
A couple pieces of strap, some flat bar, and a length of pipe. Weld it all together and drill some holes.
Did you make the runningboard/step thing? Its pretty awesome!
zachsjeep is offline
post #17 of 21 Old 02-15-2011, 11:23 AM
TheNewbie
Holy old thread batman!
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #18 of 21 Old 02-15-2011, 02:28 PM
rdsk8ter
1982 CJ7
I would use a stick of black pipe and some flat bar 4" piece fron the depot welded on to some flat plate screwed to the window frame. dont let others get you down but I will tell you most of the tihngs you do "cheap" end up costing more in the long run so might as well save up for a bit and do it right the first time.
rdsk8ter is offline
post #19 of 21 Old 03-14-2011, 08:47 PM
loneeagle78
1990 XJ Cherokee
here is a "cheap" bar, just mounted this weekend..... thrown away bedframe, cut, welded and drilled and put on the jeep.
JEEP.......not just a vehicle.........its a lifestyle!!
loneeagle78 is offline
post #20 of 21 Old 03-21-2011, 05:01 PM
Cjensenr
Lol! I love bed frame steel....
C.
Cjensenr is offline
post #21 of 21 Old 01-26-2012, 12:32 PM
bradw76
use a fence post and dril square in it for the lights and drill the post on ur windshild frame
bradw76 is offline
Cheap Third Brake Light for Over-Size Tires ($2/No Drilling) Rubi22 Technical Articles & Write-Ups 17 05-10-2012 06:14 PM
Uniroyal Liberators: Cheap price = cheap tire? ManUTDJeep Tires & Wheels 7 12-09-2011 11:52 AM
Homemade TT C2U5H Fabrication Shop 11 02-13-2009 04:11 PM
Cheap Map Light slimP Cheap Tricks & Fixes 0 09-05-2007 12:28 AM
easy, cheap homemade snorkel tjwrangler911 Cheap Tricks & Fixes 1 06-25-2007 03:28 PM
