Hawse Fairlead Dims and Placement on Bumper - JeepForum.com
post #1 of 5 Old 01-24-2013, 10:28 PM Thread Starter
blitz134
Looking get a little bit of info. Haven't been able to find anything on the 'net, but I'm still looking. I'm currently modeling my front bumper in Solidworks so that I can get my steel cut in the near future.
Does anyone have any recommendations for placement of a Hawse style fairlead? I'm going to get a Warn winch that comes with this style since I'll be running synthetic line. I know they have a 10" bolt pattern, but I don't know the bolt size. I also don't know the overall dimensions of the fairlead or the recommended slot size that the cable will pass through.
For placement, how critical is the vertical placement of the fairlead with respect to the winch? My intended winch (M8000) will feed off of the bottom, so I know I want it lower than the centerline of the winch.
Current Jeeps (Click to see build threads):
blitz134 is offline
post #2 of 5 Old 01-24-2013, 10:50 PM
rchase559
They usually use 3/8 bolts to secure them to the fairlead mount. If you don't have an answer for the placement of it by tomorrow afternoon I can give you the measurements off of mine after class.
rchase559 is offline
post #3 of 5 Old 01-25-2013, 09:10 PM
rchase559
My apologies. It's a 7/16 bolt. The best i can measure is the center line of the opening is 2.125" off of the base that winch sits on. The opening on the fairlead mount is approximately 1.8" x 8.625" with radii in each corner. The opening in the fairlead will obviously be smaller.
Edit: These are all off of a Savvy fairlead mount.
post #4 of 5 Old 01-26-2013, 06:14 AM
tangotag
Why not just buy the winch now and use it for getting your dimensions and mock up?
You may want to change your plans on your bumper design once you have it on hand, I did.
I also picked up a smittybilt hawse aluminum fairlead for mock up just in case go to a synthetic line later. It is the same bolt pattern as the m8000 roller fairlead. You will want the winch with the line on it to determine the set height of the fairlead anyways.
Here I was using the winch and fairlead to determine how high to put the fairlead mounting tabs.
tangotag is offline
post #5 of 5 Old 01-26-2013, 02:55 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
This is the best bet. Have both the winch and the fairlead in-hand prior to doing the CAD drawing. There are different shapes/sizes of aluminum hawse fairleads. Only common dimension (with certainty) would be the 10" bolt centers..
BESRK is offline
