Hard Tonneau Covers?? PICS?? - JeepForum.com
post #1 of 5 Old 06-27-2010, 10:05 PM Thread Starter
steve76t
Hi All:
I've got an '01 Wrangler & am looking to build a hard tonneau cover with as little cost as possible. I've got a couple ideas, but was hoping to see what others have done.
I'm thinking of using 1/2 or 3/4" plywood, using a couple of the bolts from the hardtop to secure it, add a hing in the middle to make it easy to fold up for easy removal, and a couple eye bolts underneath to help secure the folding part, and a few more eyebolts on top for securing other stuff to the top of it.
I'm sure someone else has done this, but I can't find any examples in my searches. Your help sure would be appreciated.
Thanks!!!
Steve
steve76t is offline
post #2 of 5 Old 06-27-2010, 10:41 PM
dodger889
I thinking that using 1/4 " plywood with bracing would be lighter than a solid piece of 1/2 or 3/4 plywood. Now if you are planning to use the top to carry stuff on then that is another story.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #3 of 5 Old 06-27-2010, 11:29 PM Thread Starter
steve76t
I may want to carry something on top & 1/4" may be too light for that. I'm leanin' towards using 1/2" plywood with a couple 2x4's for bracing. We'll see...
In the mean time, someone out there has to have something to show off. I can't imagine I'm the only doing something like this.
steve76t is offline
post #4 of 5 Old 06-28-2010, 07:39 PM Thread Starter
steve76t
bump...
steve76t is offline
post #5 of 5 Old 06-29-2010, 09:05 AM
muddy93
1987 FSJ Wagoneer
Here's a link to my write up for my "storage system". I went a little farther than just a tonneau cover, but I wanted to still be able to put the rear seat in, as well as have more storage options.
http://www.jeepforum.com/forum/f37/y...ite-up-596248/
Although I am currently working on rebuilding it out of metal, the origional version was made of 3/4" plywood, and covered with bedliner. It held up fairly well that way for around 3 years, just a few nicks in the bedliner from throwing stuff on top of the tonneau section.
As far as weight carrying, I added a couple pieces of 1" angle iron to the under side of the tonneau section for reinforcement. The largest/heaviest thing I ever had on top of the tonneau was a garden tiller. it held that weight just fine.
maroon 1987 Grand Wagoneer. stock for now...
muddy93 is offline
home made hard tonneau with pics and info.... under_psi Fabrication Shop 30 04-21-2011 08:06 PM
Hard Tonneau Cover Ideas? GA95YJ Fabrication Shop 4 01-28-2010 04:40 PM
hard tonneau/ TJ trunk TJgreg Fabrication Shop 1 12-17-2006 05:50 PM
Another DIY Tonneau tommaho Fabrication Shop 9 06-08-2006 12:03 PM
tonneau + sub box Thug Nasty Audio, CB & Ham Radios, GPS, & Electrical 1 05-21-2006 02:06 PM
