Grade 8 Bolts - JeepForum.com
post #1 of 10 Old 02-26-2007, 03:41 PM Thread Starter
djXternal
Grade 8 Bolts
Where is the best place to buy single grade 8 bolts, nuts, and washers? does home depot or lowes carry them, or is the best place a wholesale tool company where I buy buy the package?
Also how can I determine if the bolts and nuts I buy are grade 8 or not?
'04 TJ Sport
CB, 3" 4WD.com lift, BDS Front Adjustable Trackbar, Stock D30, ECGS Ford 8.8 Rear (Arb air locker and 4.56 gears), Eagle Alloys Series 187 15x10 wheels, 33x12.50r15 Cooper Discoverer STT's, 1" PA BL, 1" JKS BMML, Viking Fastback Top
djXternal is offline
post #2 of 10 Old 02-26-2007, 07:02 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Grade 8 bolts have 6 marks on top of the bolt head, no idea how to tell if a nut is a Grade 5 or Grade 8. I just trust that what is in the bin and labeled as a graded nut is what it's labeled as.
Home Depot has a very small selection of graded hardware but Lowes has a pretty complete selection. If you're lucky, you'll have a bolt specialty store nearby but sometimes they have minimum quantity requirements. You're probably better off going to Lowe's or a small speciality hardware store than you would be with a Home Depot.
Jerry Bransford is offline
post #3 of 10 Old 02-26-2007, 07:28 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
If you're looking for a few bolts and nuts of different sizes, try Mcmaster Carr . They have a large selection of nuts/bolts and other fasteners. Since I don't mind buying in bulk, I pickup alot of stuff from fastenersuperstore.com . Some of the Grade 8 nuts that I buy have little tick marks on the corners.
BESRK is offline
post #4 of 10 Old 02-26-2007, 07:35 PM
tw_jeep
Around here in NW FL.... the Ace Hardwares are great for buying hardware in small numbers, Grade 8 included. Some of the non-chain lumber yards are also good...
2000 TJ Sport/auto/D44/X8000i & Tomken mount/jeeperman rear bumper and rails/Skidrow steering skid/RE 3.5SF/33x10.5x15ATKOs/JB Conversions SYE/CV shaft/BESTOP tire carrier/AtoZ front bumper/Front Aussie Locker/some aesthetic stuff/
tw_jeep is offline
post #5 of 10 Old 02-26-2007, 08:21 PM
Grape Ape
Web Wanker
Grape Ape's Avatar
I found that Tractor Supply has a pretty good selection of grade 8 nuts and bolts. I had to buy grade 8 the other day for my gas tank access mod because that was all they had. The grade 5 and 2 were all gone.
EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun!
We've idiot proofed the world... now its full of idiots. - Spiritof76
You will truly be the same today as you will be five years from now, except for two things, the people you meet and the books you read. Charles E. Jones
I think I'll add some memorable quotes. blah blah blah..... FPKites
Trying to understand some people, is like trying to pick up a turd by the clean side.
Grape Ape is offline
post #6 of 10 Old 02-26-2007, 11:06 PM
MQ79
Same here. Ace is where I buy all my Grade 8 bolts.
MQ79 is offline
post #7 of 10 Old 02-27-2007, 12:10 AM
JJ-4
JJ-4's Avatar
1987 YJ Wrangler
i agree ACE and also OSH has a pretty good selection of grade 8 bolts
JJ-4 is offline
post #8 of 10 Old 02-27-2007, 12:13 AM
jason m
Nothing but the facts
jason m's Avatar
is there a CAT dealer near buy, i work for CAT and i am not trying to push there product but there zinc coated grade 8 bolts and hard ware are about the tuffest out there, all there heads are thicker. they way to tell the diference between grd 5 nuts over 8's is they are zinc coated ( goldish plated ). one more thing about the CAT nuts is they have more relieafs or dimple's cut on the face side of the nut to grip the lockwasher or steel better, jason.
jason m is offline
post #9 of 10 Old 02-27-2007, 05:13 AM Thread Starter
djXternal
ok thanks guys I found everything I needed at Lowes, cost me 25$ for all the hardware I needed, but at least I'll be able to install all my parts this week
'04 TJ Sport
post #10 of 10 Old 02-27-2007, 08:25 AM
Matt in TN
1979 CJ7
I'll second Tractor Supply for bolts and nuts - you buy by the pound and usually it is much cheaper than Lowe's or HD. FWIW - Grade 8 bolts have 6 tick marks as said above, Grade 5 have 3 tick marks. Grade 2 has no markings.
Join an off-road club!
'79 CJ-7, 304, T-18a, Dana 20, AMC-20 w/ Yukon 1-piece axles, and Dana-30, 33x12.50x15, 1" Body Lift w/ heavily trimmed fenders, full cage with seats and harnesses, CJ/Wagoneer power steering upgrade, custom front and rear bumpers, body armor, and belly-up skidplate
In the garage, waiting for hell to freeze over so I can finish the installation: Waggy front D44, AMC M23 rear
Matt in TN is offline
Grade 8.8 bolts VS 8 ex m38a1er Fabrication Shop 11 10-18-2009 07:41 PM
Grade 8 and Grade 5 bolts for 2nd graders KJFactor Fabrication Shop 5 05-26-2009 04:59 PM
For your info. Grade 8 or Grade 5 bolts KJFactor General Jeep & Off-Road Equipment 6 05-25-2009 10:54 AM
Grade 5 vs. Grade 8 Fasteners ksm4_al Fabrication Shop 13 11-09-2008 10:24 AM
Grade 8 Bolts - Appearance phattdraggon General Jeep & Off-Road Equipment 21 06-16-2005 09:57 PM
