Grade 5 vs. Grade 8 Fasteners - JeepForum.com
post #1 of 14 Old 10-22-2008, 07:23 AM Thread Starter
ksm4_al
Although I originally posted this response to a question on a different thread the article on ROCKCRAWLER.com by David Potter is so well written I thought the post was worth repeating here.
Originally Posted by 4.7stroker View Post
OK Why does everyone insist on grade 8 hardware?
Grade 5 is just fine and much cheaper, the better safe than sorry answer will not cut it with me.
Dwayne
Hey Dwayne. David Potter's article from ROCKCRAWLER.com will will do a much better job answering your question than I ever could seeing that he is a "genuine rocket engineer for Lockheed Martin".
ksm4_al is offline
post #2 of 14 Old 10-22-2008, 07:35 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Here's my personal experience with grade nothing vs grade 5 vs grade 8 & 35 ft-lbs of torque.
http://www.jeepforum.com/forum/f27/why-use-grade-8-hardware-606505/
If you didn't understand all the shear & tension engineering speak in the above link - just buy grade 8 and don't ask questions
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 14 Old 10-22-2008, 12:50 PM
jsc7002
1966 CJ5
its all about the tensions and shear strength, I personally always like to overkill the things I do, like my roof rack is bolted down with M10.9 bolts which are equal to Grade 8 bolts, and I have even broke a M10.9 bolt in half on my Jeep, it was a bolt that held on the engine skid and I hit it real hard once and the head just snapped off
jsc7002 is offline
post #4 of 14 Old 10-22-2008, 01:08 PM
Bigbob
Bigbob's Avatar
In many areas, like the case above, a grade 5 will work better. Being the grade 8 is much harder than a grage 5 bolt it is also more brittle. You are not going to bend a grade 8 bolt easy, but they can crack and break when the reach a certain point. On something like an engine skid that has a certain amount of give to it a grade 5 bolt is a better choice.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #5 of 14 Old 10-22-2008, 04:33 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
A Grade 8 will do everything a Grade 5 will do... except better... and at a higher cost.
BESRK is offline
post #6 of 14 Old 10-27-2008, 11:45 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A Grade 5 bolt will ALWAYS ALWAYS ALWAYS fail before a Grade 8 bolt will, no matter what use or stress it is subjected to.
A Grade 8 bolt is not so hard that it would ever fail before a Grade 5 bolt would, no matter how you flex/stress it. There is no use that a Grade 5 would hold up to better than a Grade 8 bolt would. That said, I use Grade 5 bolts when Grade 8 is not called for. I don't use Grade 8 bolts for everything as some people seem to think is necessary.
Jerry Bransford is offline
post #7 of 14 Old 10-28-2008, 09:23 PM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
i have actually stretched an M10.9 bolt on my UCA with a 1/2" drive socket and box wrench to the point that when i went to torque it to the stock 55ft/lbs, it merely ripped in half. so i went with true grade 8. maybe it was a bad bolt but i didnt want to risk it.
1990JEEPXJ is offline
post #8 of 14 Old 11-02-2008, 05:21 PM
Kman1983
1983 CJ5
Several years ago I simply just started refilling the bolt bin with Grade 8 hardware and I have started adding extra bins with stainless hardware where there isn't a needfor the strength but corrosion may be a factor.
Kman1983 is offline
post #9 of 14 Old 11-02-2008, 05:30 PM
USAntigoon
Retired from Forum
Using a grade 8 fastener is only "effective" once you apply a torque (read clamping load) close to the yield point of the fastener. Because of the Heat treated condition it will require more load to stretch, hence it will generate more clamping load..A grade 8 bolt used with low clamping loads will behave worse then a grade 5.. Also keep in mind that the nut or threaded hole the fastener threads into has its limitations vis a vis yield....
USAntigoon is offline
post #10 of 14 Old 11-02-2008, 06:22 PM
algmmech
1974 CJ5
The clamping load might explain something that happened to me a few years ago. I replaced all my spring bushings and installed new grade 8 bolts in all the spring eyes and shackle hangers. Shortly after I was on a very difficult trail when I heard a banging noise. I had broken one of the new grade 8 bolts on the front of the rear spring. I replaced the bolt and went on my way. When I got home, thinking about what had happened, I replaced all the bolts with grade 5 and never had another problem. I believed that the impact from the spring on the hardened bolt, which is more brittle, caused the problem. I used grade 5 because I believed a slightly softer bolt would bend before breaking. Now, I may have just had a defective bolt. I'm not sure, but the clamping force was not that great to allow the spring to move. This might explain things. I have used grade 8 since for my winch and roll bar. I wouldn't think of using any less for those items.
mostly stock 74 cj5, 258, t14, d20, d44 & 30.
I'm a member of PETA.
People Eating Tasty Animals
algmmech is offline
post #11 of 14 Old 11-03-2008, 08:58 AM
mcneil
Not a true statement - the stiffness doesn't change with heat treat. Steel's modulus is ~30ksi regardless. A gr8 bolt isn't any stiffer than a gr5 bolt, until you exceed the proof load of the gr5 and lose some of the preload.
mcneil is offline
post #12 of 14 Old 11-03-2008, 10:13 AM
USAntigoon
Retired from Forum
I used the word "stretch" and I was thinking "stretch to proof load", because this is way higher for grade 8 bolts then grade 5. (sorry)
Those who are now even more confused should read THIS article and this one as well
post #13 of 14 Old 11-03-2008, 10:22 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I read a book from Barnes & Noble called "Fasteners and Plumbing" or something like that.. it had more info about nuts/bolts than I needed to know but it was pretty interesting. My wife couldn't believe I would lay in bed and read about "stupid bolts" as she called them.
BESRK is offline
post #14 of 14 Old 11-09-2008, 10:24 AM
FunkSkunk
Sold my soul to JeepForum
FunkSkunk's Avatar
^ A true sign of a fabricator! nice Besrk!
FunkSkunk is offline
Grade 8 and Grade 5 bolts for 2nd graders KJFactor Fabrication Shop 5 05-26-2009 04:59 PM
For your info. Grade 8 or Grade 5 bolts KJFactor General Jeep & Off-Road Equipment 6 05-25-2009 10:54 AM
Why to use Grade 8 hardware. Unlimited04 General Jeep & Off-Road Equipment 3 09-15-2008 10:52 AM
How do you tell if a bolt is Grade 8 or not? GilpinTJ Fabrication Shop 7 09-23-2007 06:13 PM
Grade 8 Bolts djXternal Fabrication Shop 9 02-27-2007 08:25 AM
