Got Bored today. my Mock Roll Cage
| Truck-Lite's New LED Headlamp Series | 4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE Needed | Ruffstuff Axle Simple Swap Kit! |
#1 | |
Head Brewmaster
Before anyone says anything I got very bored today, this is what it lead to. I had this RC TJ body laying around with a roll cage and I decided to play around a bit and mock up the cage I plan to make for my YJ. Boredom does strange things to people. So I got me some straws and a hot glue gun and started playing around. My only gripe the cage and body aren't to scale. so the bars are a bit off. the green part represents the stock main hoop that i will be building off of, and the straws are what i plan to add. so here it is
top rear view: ![]() Drivers side view ![]() Front view ![]() Passenger side view ![]() Another top view ![]() And yes, I am fully aware I have too much time on my hands[ ]some changes for the real deal will be the use ofsset plates instead of the small angle bars in the top corners in some locations. Would have been to hard to make em and glue em in with the hot glue gun so I just used chunks of saw instead.
92 YJ. High Output 4.0L Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods My RigRater Score: 682RRv1.0 with a BOA of 13.47 I'm now doing custom bumpers and lift installs in So-cal |
#2 |
GROUND POUNDER
Good idea to mock up your cage with a model instead of wasting tube. One suggestion. Instead of running 4 straight spreaders from the B pillar to the A pillar (main pillar to your windshield pillar), I'd recommend two outer spreaders, one center spreader and two angled spreaders from the center of the B pillar out to the corners of the A pillar. That'll help prevent the front pillar from collapsing in on a hard front pillar corner hit during a roll.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#3 |
Head Brewmaster
the reason for the two center spreaders is I plan to fab an overhead console that will mount between them. Also my A pillar isn't a hoop like the B pillar. its hard to tell because the straws kinked, but the outer bars are bent from the b-pillar and are connected side to side with a top bar and the dash bar
#4 |
Now all you need is the machine from that honey I shrunk the kids movie. Reverse it and have it turn plastic to steel and you're set!
'84 CJ-7 Junkyard TBI 360/T18/D300, 4" 4WDH Lift, D44 front with ARB and HS/D44 Rear w/ Detroit, 4.56s, 36" Iroks, TFI, TJ flares, Homemade rocker guards and bumpers with swing out, Optima Yellow Top, M8000, York OBA, 6pt cage "when you're up to your *** in alligators, it is hard to remember that your original intention is to drain the swamp" |
#5 |
Is there any side to side bracing? On a flop there will be alot of force applied to the side of the cage. You might want to add some kind of cross brace behind the front seats to help tie the sides of the cage together.
53 willys wagon with less of rust and no more bugs. Now sporting a 1988 wagoneer frame, amc 360, dana 44's. '80 CJ-5, full width, 3 link front, 1/4 elliptical rear, 38's, and propane. |
#6 |
Head Brewmaster
side to side bracing is there, just didnt really show up in the pics
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
