Glowing rod?? Welding question. - JeepForum.com
post #1 of 6 Old 10-15-2003, 04:06 AM Thread Starter
BamaJeeper
BamaJeeper's Avatar
What causes the welding rod to glow orange after only burning 1/2 of it?
Details:
Lincoln 225, 3/32" 6013 rod, 90 amps, welding on 3/16" thick angle iron.
Thanks
Nathan
Out of the darkness comes light.
BamaJeeper is offline
post #2 of 6 Old 10-15-2003, 10:42 PM
eight
eight's Avatar
Welding too hot for the rod. You should be useing 1/8" rod for anything over 1/8" thick. And step up to a 6011 if you're decent at welding. Gets good penetration. 6013 is only good for learning.
eight is offline
post #3 of 6 Old 10-16-2003, 05:07 AM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Bama,
Rod is too thin for that amperage. Upgrade to atleast 1/8" Also make sure your arc isn't too short, doesn't work when you ground the rod out.
I'll disbute the 6013's. They're a good general purpose rod and are nice to use with any stock, many welders I know continue to use those or 7018's.
6011's splatter allot and should really only be used on rusty nasty stuff where appearance is second to penetration..
K9Jeep
K9JEEP is offline
post #4 of 6 Old 10-16-2003, 05:49 AM Thread Starter
BamaJeeper
BamaJeeper's Avatar
The rod was within the specified amperage for its size as suggested on the box.
I'm using the 6013 because I am learning and have been told that they are easier to learn with. I will start using 7018 when I burn up the 5lbs of 6013.
post #5 of 6 Old 10-16-2003, 06:35 AM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Stick diameter w/Rod type, average amperages
-----------------3/32"------1/8"----- 5/32"-------3/16"-------1/4"----
6010, 6011----40-85-----75-125----110-165----140-210-----210-315
6013----------40-90---- 80-130----105-180----150-230-----250-350
7018----------60-100---110-165---150-220----200-275-----320-400
K9Jeep
K9JEEP is offline
post #6 of 6 Old 10-16-2003, 06:40 AM
K9JEEP
Registered Abuser
K9JEEP's Avatar
Bama... if you're just laying practice beads and not joining metal, just turn it down. No hard set rules on this, you use the amerage that feels comfortable to you and your welding style.
K9Jeep
K9JEEP is offline
First welding projects: welding cart and rock sliders johnsoninc86 Fabrication Shop 13 12-11-2011 11:48 PM
MAP welding question... TJaefick Fabrication Shop 2 01-14-2010 10:58 AM
Welding Question ScotZ Fabrication Shop 4 07-03-2009 05:05 PM
94' XJ Instrument Panel Not Glowing LordBronz Audio, CB & Ham Radios, GPS, & Electrical 3 05-26-2009 10:56 AM
Welding question AznDrgn Fabrication Shop 5 12-16-2006 07:27 AM
