Galvanize Removal - JeepForum.com
post #1 of 17 Old 11-05-2008, 08:40 AM Thread Starter
5artist5
5artist5's Avatar
1972 CJ5
Galvanize Removal
I have some galvanized pipe i need to weld and then continue to heat up real hot on a regular basis. How can I remove the galvanize? I glass bead blasted the outside and that seemed to work pretty good I think but it there something I can dip them in to eat away any leftover stuff and anything on the inside?
KI6RIC
72 CJ5 258-3spd d30-d20-d44
Originally Posted by Bsktbll109 View Post
Does your rearend guy do gears?
5artist5 is offline
post #2 of 17 Old 11-05-2008, 08:44 AM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
maybe an acid wash?
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #3 of 17 Old 11-05-2008, 08:46 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
good question. i dont know, but i know welding galvanized pipe isn't good for you. Makes you sick and supposedly removes calcium from your bones (old wives tale?)
http://www.sperkoengineering.com/htm...Galvanized.pdf
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 17 Old 11-05-2008, 09:51 AM
BrandNew
metal fume fever may be in your future... use a respirator and an exhaust
Selling your tire carrier?! send me a PM i want it
BrandNew is offline
post #5 of 17 Old 11-05-2008, 09:57 AM
BrandNew
do you have to use galvanized steel?
BrandNew is offline
post #6 of 17 Old 11-05-2008, 10:31 AM Thread Starter
5artist5
5artist5's Avatar
1972 CJ5
Well that's what I have. None of the home supply stores carry black pipe in big enough dia. for what I need.
KI6RIC
5artist5 is offline
post #7 of 17 Old 11-05-2008, 10:56 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
An acid bath is the only thing I can think of. Nasty stuff.
Side note: whatcha makin???
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #8 of 17 Old 11-05-2008, 10:58 AM Thread Starter
5artist5
5artist5's Avatar
1972 CJ5
What sort of acid and where would I get it?
I am making a small gas forge. These pipes will hold the burners.
KI6RIC
5artist5 is offline
post #9 of 17 Old 11-05-2008, 11:02 AM
rustywrangler
The only time I have had stuff acid washed was when I paid for it so I do not know the name. Your gonna want to get that pipe REALLY CLEAN for what your making.
Maybe a muriadic acid or the like. check with a local metal platter. They would be in the know on what to use.
post #10 of 17 Old 11-05-2008, 07:54 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Muriatic Acid will take off the zinc. Not sure how to do it without leaving a "zinc residue" though.. maybe wash it a few times?
BESRK is offline
post #11 of 17 Old 11-05-2008, 08:31 PM
Unlimited04
isnt that stuff really nasty? Like inhalation hazard bad? its HCl, so its like take the skin off your hand bad, then has nasty fumes that will kill you bad. I'd think you'd need to completely submerse the metal too. Maybe the galvanized welding is the lesser of two evils....
http://en.wikipedia.org/wiki/Hydrochloric_acid
maybe check the local steel supply stores and see if they have any scrap Schedule laying around from other orders.
Useful Write-Ups:
Funny:
post #12 of 17 Old 11-05-2008, 08:34 PM
flatlander757
Drink a glass of milk before and after welding or grinding anything galvanized and you won't get sick.
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #13 of 17 Old 11-05-2008, 09:00 PM
joe's_yj
joe's_yj's Avatar
wire wheel, flap disc or just weld it and use a respirator
my build up
Originally Posted by tawdr77 View Post
The cheapest way to get a significant power increase over a stock 2.5l, would be to pull it out and put in a 5hp briggs & stratton engine.
joe's_yj is offline
post #14 of 17 Old 11-06-2008, 09:14 PM
BrandNew
too bad your not in texas i had alot of pipe
BrandNew is offline
post #15 of 17 Old 11-07-2008, 06:46 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
It is nasty stuff. I have a tank that I built that has a solution of Muriatic Acid and water. I use it to clean mill scale off my bumpers.
I use a respirator and face shield when messing with it. Yeah.. it burns the cuts in your hands a bit if you submerge them.
You could also fill a spray bottle with a 50/50 mix of acid/water and spray the pipe down outdoors and then rinse with water. I used to clean my bumpers that way.
But.. um.. yeah.. Muriatic Acid is nasty.
BESRK is offline
YJ Fender Removal tlgraham General Jeep & Off-Road Equipment 2 07-15-2008 07:11 PM
CJ7 Engine Removal sabu Engines & Drivetrain 1 07-15-2008 06:05 PM
cat removal Matt Gertsch Street Jeep Forum 2 05-30-2008 05:33 AM
yj tub removal canonball General Jeep & Off-Road Equipment 1 06-30-2006 08:53 PM
CJ5 Tub Removal swampstander General Jeep & Off-Road Equipment 2 06-25-2006 07:47 AM
