Future project build idea - JeepForum.com
post #1 of 14 Old 08-21-2013, 04:36 AM Thread Starter
Repauli1
I am liking the idea of designing a tire carrier that swings out, but when the spare is needed it swings down to the ground, so that you can unfasten the spare and tip it up and roll off the carrier. It's a pain in the *** lifting a heavy tire/wheel, and trying to start the lug at same time by yourself.
So the tire would be sandwiched between gate and carrier, what my concerns are, is the distance that the assembly extends out, I don't want it slamming the ground when accenting or descending a sharp angle. In other words I don't want the carrier to become a skid... I know I can mount it high, but the higher it is, the less the rear view.
If you have a carrier with the frame on the outside, I would like to hear your trailing experiences!!
2008 JKUX
Drink Micro-Brews, better yet make your own!
Repauli1 is offline
post #2 of 14 Old 08-21-2013, 05:36 AM
Oman Jeep
Oman Jeep's Avatar
A simpler solution - design your tire carrier with a section of tubing sticking out where the centre hub of the wheel is. This allows you to lift the tire up and set it down on that tube, then free spin it to the correct rotation on the wheel studs, and then push it back into place. Also helps to have that tubing cut on a wedge angle (longer at the top side) so it's easier to find the centre. When lifting it, you now only have to get roughly in place rather than exactly in place.
Solves the alignment concern but you still have to lift it. Not such a problem in the sandy areas as the sand polishes the tire rubber so it's pretty much nice and clean most of the time. A swing-down tire solution is good if you don't want to be hugging a heavy muddy mess... in that case just get a rear camera for the visibility issues.
Oman Jeep is offline
post #3 of 14 Old 08-21-2013, 06:42 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
I've been toying with the idea in the shop. It's been done, just a matter of new ways to do it cost effectively. Here was the "first" of it's kind a few years back. Great idea...not cost effective. I'm looking to change that.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #4 of 14 Old 08-21-2013, 07:25 PM Thread Starter
Repauli1
I am the mud type, so I def want swing down. I like the self centering though for other carrier ideas. Thanks for FB
2008 JKUX
Repauli1 is offline
post #5 of 14 Old 08-21-2013, 07:26 PM Thread Starter
Repauli1
Video Link: http://www.youtube.com/watch?v=xLFrE04S0iA
Did your shop fab this? If yes what was the sell price? Is it still a current product?
2008 JKUX
Repauli1 is offline
post #6 of 14 Old 08-21-2013, 07:38 PM
Tomb Raider
Addicted...
No. That was built by a now defunct company called HD customs.
post #7 of 14 Old 08-22-2013, 02:06 AM
AveCat
http://www.quadratec.com/products/12107_300X_07_PG.htm
2012 Wrangler JK 3.6 W/ 6 Speed bought 2/15/13
2.5" Rock Krawler Lift - Bilstein 5100s - 315/70/17 Duratracs - AEV Control Arms
TruckLite - Rigid
AveCat is offline
post #8 of 14 Old 08-25-2013, 08:58 PM
Lifted96ZJ
1973 CJ5
I've always liked this.
http://shop.jeeptubes.com/product.sc...1&categoryId=3
Genright makes a similar one also but it opens to the side, not up and down
Build Thread
http://www.jeepforum.com/forum/f8/1973-cj5-trail-rig-hunting-rig-build-1403107/
Lifted96ZJ is offline
post #9 of 14 Old 09-02-2013, 09:22 AM
aggiejon
1979 CJ7
You could weld a piece of pipe with an o.d. That is slightly less than the diameter of the hub. The. You can rest it in place on the hub and spin to line up lugs
aggiejon is offline
post #10 of 14 Old 09-11-2013, 08:06 AM
firefighter315
This might be just a little late in posting, but this is one project I've saved from here on JF. NashvilleTJ had some really good ideas when he came up with this one.
http://www.jeepforum.com/forum/f37/s...rrier-1128388/
My YJ Build Thread
firefighter315 is offline
post #11 of 14 Old 10-01-2015, 10:29 AM Thread Starter
Repauli1
Went different direction
2008 JKUX
Repauli1 is offline
post #12 of 14 Old 10-01-2015, 10:42 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I'm older than you and manage to get it done. Maybe a gym membership instead? Or, just redesign the present mount to not have the lug alignment issue, so simply rotating the hoisted tire will align it.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #13 of 14 Old 10-10-2015, 12:25 AM
fayceoff
fayceoff's Avatar
Or you could put one of Harbor Freight's $55 ATV winches at the top of your tire carrier and use it to raise and lower the tire... That's what I'd do if I had anything bigger than a 33. I like to think I'm fairly strong, but working smarter > working harder.
"It's almost always cheaper to it right than it is to do it twice." - Dad
"Be polite. Be professional. But have a plan to kill everyone you meet." - Gen. James Mattis
fayceoff is offline
post #14 of 14 Old 10-10-2015, 03:52 PM
dwilliams35
How about just hitting the junkyard and getting one of the little winches that they use to lift the spare on pickups?
dwilliams35 is offline
