-   Fabrication Shop (http://www.jeepforum.com/forum/f37/)
-   -   Future project build idea (http://www.jeepforum.com/forum/f37/future-project-build-idea-1565124/)
Repauli1 08-21-2013 04:36 AM
I am liking the idea of designing a tire carrier that swings out, but when the spare is needed it swings down to the ground, so that you can unfasten the spare and tip it up and roll off the carrier. It's a pain in the *** lifting a heavy tire/wheel, and trying to start the lug at same time by yourself.
So the tire would be sandwiched between gate and carrier, what my concerns are, is the distance that the assembly extends out, I don't want it slamming the ground when accenting or descending a sharp angle. In other words I don't want the carrier to become a skid... I know I can mount it high, but the higher it is, the less the rear view.
If you have a carrier with the frame on the outside, I would like to hear your trailing experiences!!
Oman Jeep 08-21-2013 05:36 AM
A simpler solution - design your tire carrier with a section of tubing sticking out where the centre hub of the wheel is. This allows you to lift the tire up and set it down on that tube, then free spin it to the correct rotation on the wheel studs, and then push it back into place. Also helps to have that tubing cut on a wedge angle (longer at the top side) so it's easier to find the centre. When lifting it, you now only have to get roughly in place rather than exactly in place.
Solves the alignment concern but you still have to lift it. Not such a problem in the sandy areas as the sand polishes the tire rubber so it's pretty much nice and clean most of the time. A swing-down tire solution is good if you don't want to be hugging a heavy muddy mess... in that case just get a rear camera for the visibility issues.
Tomb Raider 08-21-2013 06:42 PM
I've been toying with the idea in the shop. It's been done, just a matter of new ways to do it cost effectively. Here was the "first" of it's kind a few years back. Great idea...not cost effective. I'm looking to change that.
Repauli1 08-21-2013 07:25 PM
I am the mud type, so I def want swing down. I like the self centering though for other carrier ideas. Thanks for FB
Repauli1 08-21-2013 07:26 PM
Video Link: http://www.youtube.com/watch?v=xLFrE04S0iA
Did your shop fab this? If yes what was the sell price? Is it still a current product?
Tomb Raider 08-21-2013 07:38 PM
No. That was built by a now defunct company called HD customs.
AveCat 08-22-2013 02:06 AM
http://www.quadratec.com/products/12107_300X_07_PG.htm
Lifted96ZJ 08-25-2013 08:58 PM
I've always liked this.
http://shop.jeeptubes.com/product.sc...1&categoryId=3
Genright makes a similar one also but it opens to the side, not up and down
aggiejon 09-02-2013 09:22 AM
You could weld a piece of pipe with an o.d. That is slightly less than the diameter of the hub. The. You can rest it in place on the hub and spin to line up lugs
firefighter315 09-11-2013 08:06 AM
This might be just a little late in posting, but this is one project I've saved from here on JF. NashvilleTJ had some really good ideas when he came up with this one.
http://www.jeepforum.com/forum/f37/s...rrier-1128388/
Repauli1 10-01-2015 10:29 AM
1 Attachment(s)
Went different direction
JeeperDon 10-01-2015 10:42 AM
I'm older than you and manage to get it done. Maybe a gym membership instead? Or, just redesign the present mount to not have the lug alignment issue, so simply rotating the hoisted tire will align it.
:cheers2:
fayceoff 10-10-2015 12:25 AM
4 Attachment(s)
Or you could put one of Harbor Freight's $55 ATV winches at the top of your tire carrier and use it to raise and lower the tire... That's what I'd do if I had anything bigger than a 33. I like to think I'm fairly strong, but working smarter > working harder.
dwilliams35 10-10-2015 03:52 PM
How about just hitting the junkyard and getting one of the little winches that they use to lift the spare on pickups?
The time now is 12:21 AM.
