Fullsize Chevy Axles In Cj-5 - JeepForum.com
post #1 of 3 Old 07-31-2004, 05:18 PM Thread Starter
heywoodyablowme
HI, new to the forum I need some help with the steering on my jeep. I just put chevy axels in A 76 cj-5! Can anyone tell me if they make a kit for this. Thanks
heywoodyablowme is offline
post #2 of 3 Old 07-31-2004, 06:59 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Did you go spring over or spring under? I don't know specifically of any kit on the market... Might try a steering linkage from a Wagoneer and modify (probably lengthen) as necessary. Or, you could pick up some DOM tubing and tap the ends for either tie rod ends or heim joints. When I put my D44 under my CJ I picked up a length of this Tubing and used it for my tie rod and drag link.. it's 1 1/4" x 5/16" wall. I tapped it for 3/4" fine threads and use chromoly heim joints at all 4 joints. Ended up spending about $200 on the setup but it's pretty tough.
BESRK is offline
post #3 of 3 Old 08-02-2004, 12:34 AM Thread Starter
heywoodyablowme
I put the axles under the springs to give it just a little more lift ! I'll try to look though the salvage yard for the right stuff and i guess I'll just have to make something work . Thanks
5.3 chevy in the tj CETROV Engines & Drivetrain 3 08-30-2007 04:46 AM
V8 Conversion/ Chevy Axles Markj Fabrication Shop 22 12-10-2003 06:35 PM
What axles does a 77 chevy scottsdale all wheeldrive truck have? bigsteve3184 General Jeep & Off-Road Equipment 7 07-11-2003 12:16 AM
Chevy TPI? Jeepfreak81 Engines & Drivetrain 6 10-28-2002 10:21 PM
chevy 305 sasquatch1 Engines & Drivetrain 2 09-05-2002 04:56 PM
