fuel tank dents - JeepForum.com
post #1 of 14 Old 01-30-2011, 06:51 PM Thread Starter
Nick_Knipp
1986 MJ Comanche
fuel tank dents
ive got a steel tank off the MJ thats got alot of bad dents, it needs to be fixed so the fuel pump can sit right in it. any ideas?
"Don't curse in your profile"
-The Moderators
'86 MJ XLS 4x4 2.8L 3spd longbed buckets
'12 MK Sport 2.4L AT rescue green
Nick_Knipp is offline
post #2 of 14 Old 01-30-2011, 07:22 PM
jpywell52
1979 CJ7
WARNING! I'VE ONLY DONE THIS ON SMALL TANKS AND ALWAYS CLEANED THEM THOROUGHLY & FILLED THEM WITH WATER FIRST TO PREVENT AN EXPLOSION!!
I've done this on motorcycles but never scaled it up to a 15 gallon tank. Maybe others here can weight in? I brazed some rod to the low spots or you can buy on those spot weld guns that spot welds a rod to the sheet metal and then used a used a slide hammer. Go slow, be gentle, apply heat around the area you are trying to pull out but not too much heat.
jpywell52 is offline
post #3 of 14 Old 01-30-2011, 07:23 PM
jpywell52
1979 CJ7
Sorry for all the caveats but I don't want my advice killing anyone.
post #4 of 14 Old 01-30-2011, 08:38 PM Thread Starter
Nick_Knipp
1986 MJ Comanche
dont worry ive been burnt before, and that was a long time ago so im aware.
the fuel system is spotless atm. ill wait for others to chime in
-The Moderators
post #5 of 14 Old 01-30-2011, 08:45 PM
jpywell52
1979 CJ7
Right on, well good luck to you. The other option if you can reach the dents from inside is to just use a hammer.
post #6 of 14 Old 01-30-2011, 08:53 PM Thread Starter
Nick_Knipp
1986 MJ Comanche
thanks man, and yeah i cant get my hand in there, too tight
-The Moderators
post #7 of 14 Old 01-30-2011, 09:00 PM
jpywell52
1979 CJ7
all else fails you can try to find a very strong small monkey they have smaller arms...
post #8 of 14 Old 01-30-2011, 09:03 PM Thread Starter
Nick_Knipp
1986 MJ Comanche
nah he'd be too smart to mess with a gas tank
-The Moderators
post #9 of 14 Old 01-30-2011, 09:05 PM
jpywell52
1979 CJ7
right right, don't know what i was thinking...good point.
post #10 of 14 Old 01-30-2011, 09:09 PM Thread Starter
Nick_Knipp
1986 MJ Comanche
-The Moderators
post #11 of 14 Old 01-31-2011, 07:19 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Assuming the dents are along the bottom.. maybe you could pull the sending unit and get to the areas with some makeshift punches/spoons/hammers...etc. Maybe use some "shaped wood" as a punch.. to avoid sparks. Round off the end of a 2x4?
BESRK is offline
post #12 of 14 Old 01-31-2011, 10:08 PM
asjeep
could buy a new one? http://motionoffroad.com/catalog/ind...roducts_id=922
2002 TJ SE
asjeep is offline
post #13 of 14 Old 01-31-2011, 10:34 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
Once again, only been used on smaller tanks for motorcycles.
At the Bike shop i worked out, we would make the tank as air tight as possible, heat the affected area and fill the tank with compressed air. Never done it on a large tank, but works great on small tanks.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #14 of 14 Old 02-01-2011, 01:01 AM Thread Starter
Nick_Knipp
1986 MJ Comanche
thanks all, but i managed to get the sending unit back in the tank and locked. now i just gotta fix that leak coming off the rubber gasket (where wires go in)
-The Moderators
fuel tank build Nick-cj-7-1980 Fabrication Shop 1 08-12-2010 05:22 PM
Advice on pulling dents ScottHarr_TJ Fabrication Shop 11 01-06-2009 04:39 PM
Dents on Hood drerict General Jeep & Off-Road Equipment 1 07-21-2008 03:51 PM
small dents 1986cherokee Street Jeep Forum 1 06-25-2008 10:15 PM
Hail Dents 27mtaylor General Jeep & Off-Road Equipment 6 03-31-2008 06:25 PM
