Fuel Cell ...make one or buy one and it's location - Page 2 - JeepForum.com
post #16 of 26 Old 08-05-2014, 06:19 AM
jason m
Nothing but the facts
jason m's Avatar
I used SS steel 16g and 1/8" a-36 steel. The steel tank I coated the inside and as far as I know its still in use after 9 years in use. Its a tank that hold a fluid, Alu is best SS or low carbon steels work just as good. Just the treat the low carbon steel after and it will last.
Take a look at any old Mack saddle tank is a heavy steel tank, now they are Alu for weight but back in the day they used steel.
Jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
And on the 8th day, God created the 14 bolt...
The happiest people don't have the best of everything, they make the best of everything.
jason m is offline
post #17 of 26 Old 08-05-2014, 01:57 PM
dirtdudeaz
1983 CJ7
Fuel safe is expensive but a great brand; we used them in a few desert cars I helped build
Summit has a bunch of different brands including Jazz that are decently priced as well.
Unless you have good tig welding experience or aluminum welding experience, access to a welder and press brake, I would say let the pros do it. Last thing you want is to have a behind or under the seat tank fail when flipped over or in a crash; or anywhere for that matter. Then you also don't have to worry about all the fittings, valves, liners, baffles, etc...
dirtdudeaz is offline
post #18 of 26 Old 08-06-2014, 09:07 AM
94XJS
1994 XJ Cherokee
I do have MIG/TIG experience with aluminum and access to shop equipment. I have been to Summit Racing and have noticed that the guts are where the cost is on a fuel cell. I'm not really a cheapskate as much as I enjoy the reverse engineering, design and fabrication of the build. If anyone knows of other forums or threads more specific to design pros and cons, let me know. Thanks for your input!
94XJS is offline
post #19 of 26 Old 08-06-2014, 02:46 PM
dirtdudeaz
1983 CJ7
Essentially you buy a bladder, baffle foam, fill plate, gasket, etc... build a box to hold the bladder snuggly. You will probably find that the bladder is almost as much as a brand new cell assembly, but nonetheless, fabricating things is fun sometimes too!
post #20 of 26 Old 08-06-2014, 03:11 PM
youngjeepr
Why would you need to run a bladder? I assume you would use one if you didn't trust the welds. But any other reason?
88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
youngjeepr is offline
post #21 of 26 Old 08-06-2014, 03:54 PM
dirtdudeaz
1983 CJ7
The main reason I know of (and why most racing organizations require it) is because of crash protection. If you roll, get hit, hit something, etc..., and the container gets crushed; a bladder will deform and bend to the new shape of the can. If you use just a can, you don't get that protection and risk spilling fuel everywhere and on you/passengers/ground/vehicle and hopefully there is no heat source nearby....
post #22 of 26 Old 08-06-2014, 05:40 PM
youngjeepr
Makes sense I didn't think about getting in a crash/roll
post #23 of 26 Old 08-09-2014, 02:04 PM
jason m
jason m's Avatar
I mig welded both the ss steel one and the steel ones. Check for leaks with air pressure inside the tanks and then just coated the inside of the steel ones. A bladder is nice but not needed, look at 90% of the older cars and trucks ( 80-90's) they were stamped steel 20g. Now they are plastic for better fuel economy.
Racing requires a bladder for obvious reasons keeping spectators safe along with drivers, plus our crash's in the woods or on the street don't see speeds over 100mph were a steel or type off tank being talked about can be ripped apart.
Jason.
jason m is offline
post #24 of 26 Old 08-09-2014, 07:42 PM
Jim1611
Jim1611's Avatar
I built my own. Used 12 gauge for all the outside panels and 16 gauge for the baffles. I took some detailed pictures along the way and they're posted on my build thread, it's in my signature line. It's allot of work but rewarding.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #25 of 26 Old 08-12-2014, 05:37 PM
youngjeepr
Any idea of what page the tank build is on? Or could you post a picture of your baffle setup?
post #26 of 26 Old 08-12-2014, 07:37 PM
Jim1611
Jim1611's Avatar
If you want go here http://www.jeepforum.com/forum/f8/ji.../index218.html. It's scattered towards the end too with other work going on.
Here's the baffles
My build thread
Jim1611 is offline
Fuel cell Sidewinder General Jeep & Off-Road Equipment 2 11-05-2009 06:08 PM
Fuel cell ArrizX General Jeep & Off-Road Equipment 1 04-27-2009 05:55 PM
Fuel Cell rednorseman General Jeep & Off-Road Equipment 4 12-15-2007 04:26 PM
Fuel Cell cconn General Jeep & Off-Road Equipment 2 08-03-2007 11:33 AM
What Fuel Pump do I need for RCI Fuel Cell?? HootenTJ General Jeep & Off-Road Equipment 1 10-02-2006 12:55 PM
