Fuel Cell ...make one or buy one and it's location - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Fuel Cell ...make one or buy one and it's location
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 05-22-2005, 05:25 PM   #1
Dangle
What would be involved in fabbing up a fuel cell?? what type of materials are needed, what type of welding, and questions of the sort. Im looking to stretch the jeep and need to do something about my gas tank. Im not opposed to buying a fuel cell but they seem expensive, and was curious if they could be made for much cheaper. also can 2 fuel cells be connected some how that are located in different spots??I have my back seat out and rear storage, and was thinking about putting a fuel cell behind each seat, like a 10 gallon or something, maybe less, but if they could be connected to draw from each other I could have a 20 gallon tank that is out of the way...thanks for the help...if anyone has made their own or knows about this, all advice is appreciated...thanks
98 TjX
4.5 RE SF, 1" body, 1" MML, 35" MTR's,, SYE & Driveshaft, Dana 44 in the rear, 7" wheelbase stretch, multiple skids protecting front to back, Flat Fendered, O.R.O U-Turn, PSC P-Pump, Vanco Hydroboost, Aussie locker in front and some other bullsh#t
REDNECK JEEP CLUB MEMBER #227
FORTI ET FIDELI NIHIL DIFFICILE
Dangle is offline   Reply With Quote Quick reply to this message
Unread 05-22-2005, 06:17 PM   #2
got4-Lo
make one out of a keg
stretched *** tj
[URL]webwheeling.com[/URL]
got4-Lo is offline   Reply With Quote Quick reply to this message
Unread 05-22-2005, 08:12 PM   #3
Dangle
really??? cause i have 6 of those hanging around...
98 TjX
Unread 05-23-2005, 12:10 AM   #4
got4-Lo
ya i have seen it done. ill find some info for ya
stretched *** tj
Unread 05-24-2005, 09:29 PM   #5
Dangle
Id appreciate that, but I dont see where one of those would fit in the jeep??? is it cut up and then fabricated?? I guess the info will tell me..thanks
98 TjX
Unread 05-25-2005, 07:03 AM   #6
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Unless you're really proficient at welding, I'd just pony up and buy a cell. I picked one of the aluminum 15 gallon cells with a sender for less than $200 from Summit. I also picked up AN fittings and hose to plumb it. It was easy to mount.. 4 tabs on the bottom. Looks good and didn't eat up all the space behind the front seats in my CJ5. The vent line also has a built in roll over check valve. I like it.
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote Quick reply to this message
Unread 05-25-2005, 09:34 AM   #7
Dangle
is that 15 gallon enough for you??? Ill have to look at their website, but I was thinking about going with 2 10 gallons behind each seat to get a little more gas in there...does anyone know if I could succesfully connect two tanks together???If not, i may just end up goinig with that 15 gallon...thanks guys
98 TjX
Unread 05-25-2005, 07:41 PM   #8
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
15 gallons will allow me to wheel all day and still have about a 1/4 tank.. with a SBC 350..
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
Unread 05-25-2005, 10:21 PM   #9
90wrangler
Don't know where you wheel, but I only go through about 5 gallons a day, rock crawling with my 350 tbi. Short drive to the trails from the campground.
I have a 12 gallon poly fuel cell with the sump in the bottom.'
Drawback is no fuel sender but I've never ran it out of gass.
There should be plenty of room to put two in but I'd just get a larger tank.
Check Summit, Jegs, etc. for a 16 to 20 gallon tank. There usually the same height.
If you build one, you will be concerned with internal corrosion on a steel tank, expense, strength and fittings welding your own aluminum tank.
90wrangler
SOA, F 8.8, Detroit, Klune-V, 35"TSL-SX
And way too much Redneck Engineering
Before the computer:
A hard drive was a long trip on the road (trail),, and if you had a 3.5" floppy,, you just hoped nobody found out!
90wrangler is offline   Reply With Quote Quick reply to this message
Unread 06-06-2005, 08:24 PM   #10
YJMCBoy
2010 JK Wrangler
theres a catalog called Lefthander Chassis who has a lot of parts for racecars. I race, and the team uses them for all of our parts. give em a try. to be honest, I don't know how expensive they are, but i know that they have some nice cells.
2010 JK 4-Door Unlimited Sport- Soft top, V6, 6-speed standard, bone stock for now
YJMCBoy is offline   Reply With Quote Quick reply to this message
Unread 06-22-2005, 01:22 AM   #11
94CherokeeXJ
Are these hydrogen fuel cells or what? I've seen some buzz about fuel cells but never a full explanation. If theyre hydrogen, what has to be done to the engine to accomodate it? Sorry if this is off-topic.
94CherokeeXJ is offline   Reply With Quote Quick reply to this message
Unread 06-22-2005, 09:30 AM   #12
redneckjeepr
fuel cell is just another name for a fuel tank.
99 Jeep Wrangler Sport, 4.0 I6, 5-speed manual, Dana 44 rear, 3.73 gears, 4"(3.5") Procomp front, 4.5" RE rear, 33x12.5 BFG mudders on 15x10 black rockcrawlers, warn rockcrawler front bumper w/ warn 9500ti winch, warn rear rockcrawler w/ tire carrier, currie SYE, front Detroit locker
redneckjeepr is offline   Reply With Quote Quick reply to this message
Unread 08-04-2014, 11:39 AM   #13
94XJS
1994 XJ Cherokee
Curious about fuel starvation on steep inclines. Fuel pick-up, sumps etc. I want to build a tank just to try it and because I want to make the best use of space in my 94XJ tuber. Lefthanders typically have the pick-up on the right side because the fuel is forced to the outside of the turn. I'm always standing on the nose or laying flat on my back, right side, left side... What's the best way to scavenge all the fuel avoiding loss of power at a bad point on the trail?
94XJS is offline   Reply With Quote Quick reply to this message
Unread 08-04-2014, 12:25 PM   #14
222Doc
In the R/c Plane world they use a flexible pick up, weighted. it just follows gravity.
http://www.parker4wheelers.net
www.bullhead4wheelersinc.com
222Doc is online now   Reply With Quote Quick reply to this message
Unread 08-05-2014, 01:00 AM   #15
youngjeepr
With as small as a 15 gallon cell is I think you would have to be running really low on fuel to starve the pickup.
I was going to build an aluminum cell but after pricing everything out (I already have the aluminum) it would be cheaper to buy one.
I still might throw one together and see what I can come up with as far as mounting an in tank pump and a fill cap.
[COLOR="Red"][/COLOR][SIZE="5"][/SIZE]88 YJ- 4.7l stroker, AW4, SOA, 8.8, hp D30 powertrax no slip,3" front stretch with waggy springs, stock replacement springs in the rear, 35/12.5 r15 goodyear kevlars
[URL="http://www.jeepforum.com/forum/f319/"][SIZE="4"][COLOR="Red"][CENTER][B]Utah Jeep Crew[/B][/CENTER][/COLOR][/SIZE][/URL]
[URL="http://www.jeepforum.com/forum/f22/youngjeeprs-build-take-2-a-2012985/"][COLOR="Red"][U][B][CENTER][SIZE="4"]Build Thread[/SIZE][/CENTER][/B][/U][/COLOR][/URL]
youngjeepr is offline   Reply With Quote Quick reply to this message
