Started building this bumper a few weeks ago and now its almost finished (need paint). This is the first thing i'v fabricated for the jeep since i bought my welder a few months ago so sorry for all the pics. i'm happy with the way it came out :2thumbsup: All done with Hobart 187 and an angle grinder (man do i want a plasma cutter, chop saw, and drill press now! :rofl
Let me know what you all think. i'll run you through the build...
First, this is the steel i started with, 2x4" 3/16 thick rectangle for the bumper and 1/4" plate for the top and winch/fairlead mount
Cut the ends at the angle i wanted and also cut the holes for my shackle mounts that are welded on both sides of the bumper.
Shackles welded in place
Then tacked and welded the end caps in place
Finished end after grinding and smoothing with a flap disc
Tacked the top plate to the bumper while fitting everything to the frame
Thats how the bumper sat for the last few weeks while i waited for this :2thumbsup:
Now i could continue working on the winch and fairlead mount. Started fitting this together
Tacked into place
placed the winch and roller on to make sure everything fit before burning it all in
Stitch welded the fairlead mount to the bumper and winch plate. This is the front
Back
This is just to show how i offset the welds on the front and back
Okay so that finished up the fabricating part. Here it is mounted up unpainted. Whatcha think?
Thanks :thumbsup:
good catch, the front bolt holes for the winch feet ended up right at the back of the rectangular tube. i had to notch the tube just alittle bit to clear the bolt head so i could get a wrench on it. It was a tight fit, i couldnt move the winch back because of my stock sway bar and also wanted to keep from moving the bumper forward any
I actually like the 48" wide look. i mostly did it to protect the front end while i still have the stock fenders. i figure i could always chop the ends off later down the road when i go tube fenders
Thanks for the compliments guys! i had a lot of fun building it
I think i spent around $120 for everything. i feel like thats pretty good since i got a new bumper and winch plate all in one! you know the price of those if you buy them :laugh: Although, the steel could probably be found cheaper than the local place i got mine since they tend to charge a lot for small pieces
Well i had the heaters running all day and shot some paint. A few coats of self etch primer and then Krylon satin black. Now its inside curing.
I'll get a few shots after i get it all put back together. Hopefully i have some time tomorrow.
Well, got it all put back together this afternoon.
I'm really proud of the way it came out being my first project. Everything fits and looks better than i expected.
Here is the finished product. Thanks for the kind words guys :wave:
Man I wish i could build a jeep like your's :drool: haha. I admire the skills it takes to build something like that with a 140, imagine the things you'd get yourself into with a 220v :rofl:
The HH187 is a nice machine :thumbsup: This is my first welder so i'm alittle biased but i like it! and i'm certainly getting addicted to fabricating
wow thats pretty clever! Im not gonna lie every time I need to tack something like that I try to hold it there and then try to hold the gun in the other hand and tack it and I always have a hard time and get very annoyed with it I am going to have to try that next time.
I always knew I was one of the smartest crayons in the box.
Your bumper looks very nice too, I wish I had a 220v as well and a plasma :drool:
Thanks, whenever i try and hold something in place and hit it with a tack it always ends up off center or crooked.
After building this with an angle grinder and cut off disks i really wish i had a plasma cutter as well :drool: i'v been looking at them but being a student and having no income right now hinders my decision. I'm hoping i can look into one over the summer when i'm making alittle money
The only thing that I would have done differently is on the 45 degree angle on the ends. I would have only taken the 45 degree angle about half way up the width of the 4" tube and left about 2" of it straight up and down if you know what I mean.
It wouldn't leave such a sharp corner on the ends of the bumper and looks cleaner IMO.
Thanks
I thought about doing that but it just made it easier for me to make a clean cut and endcap for the tube doing it this way. Also, i think it's unique since most bumpers are built with the 2" left straight up like your talking about.
Thanks :thumbsup: However, this is the first thing i'v ever fabbed up. I actually just bought my first welder a few months ago and have been practicing with that on scraps till i decided i'd try this little project.
Next on the list will probably be a rear bumper and tire carrier to go with the front, also thinking of making some rocker guards to replace my frame mounted sliders. I was just messing with some leftovers from this build today to see if i could build a steering box skid and incorporate it into this front bumper. I'll add that here if i get around to building that
I started messing with building a steering box skid today. Here is what i have so far...
Began by finding the angle i wanted and then cut two pieces of left over 1/4" plate, welded them up and smoothed it out
Then i made some cardboard templates. This is from the drivers side
This is the passenger side
This is where i'm at now
on hold because i ran out of cutting disks :brickwall
I was looking at pics of steering box skids to kind of get an idea on mounting it. my plan it to have the bottom bolt of the bumper go through the front, and the lowest bolt from the steering box hold the one side. I see that some skids (like the warn) have a 3rd bracket that mounts the other side to the round frame crossmember. Is that neccesary?
I suppose i could add an additional tab to my bumper so that i would have 2 bolts on the front and one on the side.
Any suggestions are appreciated
Here is a few pics of the lower mounts and the bottom of the bumper
Here is the underneath side with the bolts for the winch, I think i mentioned in a post above that to clear the factory sway bar the winch barely fits with the bumper tight against the frame. I had to grind the bumper slightly so i could get a wrench on the front bolts. you can kinda see it in this pic
Hopefully these were what you were looking for
Let me know if i can do anything else to help
you may as well start learning underwater welding lol,,it pays real good:teehee:
im gonna do the same gaurd myself when i get off my but and feel intergetic again..it comes in spurts for me,the sunshine state isnt so sunny at the moment...23 degrees last night whoooo hoooo:wave:
Haha thanks! I don't know about a career in underwater welding but i definitely would love to keep doing fabrication projects like these. I'm just having way too much fun with this :2thumbsup: lol
I feel ya on the cold weather. It's been highs of 30 here all week
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
